Date/Time: Sat, 11 May 2024 18:28:20 +0000
Datafeed from CQG from Phillip Capital Malaysia
View Count: 113
[2024-03-22 16:41:04] |
AzharBasri - Posts: 16 |
Hi, I have an account with broker Phillip Capital Malaysia that provide datafeed for Bursa Malaysia Derivatives Exchange using CQG connection. How can I connect the CQG datafeed and use Sierra Chart? Is there anything I need my broker to do in order to enable it's connection in Sierra Chart? Thanks |
[2024-03-22 17:02:14] |
John - SC Support - Posts: 31538 |
You need to tell your broker to allow Sierra Chart to access that data. Refer to the following: CQG Trading Platform Service: Market Data Authorizations for Symbols/Exchanges Then just make sure you are entering the symbol in File >> Find Symbol using the proper CQG symbol and format. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
