Date/Time: Sat, 11 May 2024 08:06:32 +0000
[User Discussion] - TPO session chart, want to extend yesterdays value area
View Count: 74
[2024-03-22 14:35:27] |
User436410 - Posts: 1 |
Hi This is my TPO chatrt for the ES for the three session. Blue is the RTH/cash session. I want to extend the high and low of the value area of yesterdays RTH TPO (blue) into the future/today/into the following session. I don't want to extend the HL value areas form the other (ETH/grey) session. I drew the red rectangle to illustrate this. Tried lots of indicator and tools to no avail. https://www.sierrachart.com/image.php?Image=171111788955.png |
[2024-03-22 15:50:34] |
John - SC Support - Posts: 31534 |
The only way to do this would be to open a separate chart for the same symbol and add the "TPO Value Area Lines" study to that chart and have it setup in the same way as the Value Area lines in the TPO study on the original chart. Then you would need to add the Spreadsheet Study to the chart with the "TPO Value Area Lines" and manipulate the data so that it is displaying the values you want across the time frames that you want. Then use the "Study/Price Overlay" to overlay the Spreadsheet Study to the TPO Chart to display the lines as you want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
