Date/Time: Sun, 12 May 2024 14:01:01 +0000
How can I change the color of column header on DOM
View Count: 75
[2024-03-22 04:08:21] |
User928437 - Posts: 1 |
Please refer to my attached screenshot. https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=97741 |
2024-03-21_23-57-01.jpg / V - Attached On 2024-03-22 04:02:44 UTC - Size: 96.31 KB - 28 views Attachment Deleted. |
[2024-03-22 14:17:57] |
John - SC Support - Posts: 31555 |
The settings that change the color of the "Buy/Sell" at the top of the columns are the following: - Chart/Trade DOM Buy Order Quantity Text - Chart/Trade DOM Sell Order Quantity Text Note that this will also change the color of the order quantities in the Buy/Sell columns if you have them displayed. But for the setup you show in your image, this will not be an issue, as you are using the combined Bid/Buy column. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
