Date/Time: Mon, 25 Nov 2024 06:47:30 +0000
TPO VAH-VAL-POC
View Count: 506
[2024-03-15 01:16:28] |
User377189 - Posts: 172 |
How do i get the TPO chart to label the VAH-VAL-POC and then have these labels show on number bars and tick chart?
[2024-03-15 13:39:38] |
There is not a way to get labels from the TPO Profile study. What you need to do is use the "TPO Value Area Lines" study on the Numbers Bars and Tick Chart and make sure you set the Inputs to match the TPO study you have on the other chart. You can then use the Name/Value Labels in TPO Value Area Lines study to get the labels. You can also use the "Study/Price Overlay" to get those labels into the TPO Profile chart. Refer to the following: TPO Value Area Lines Chart Studies: Subgraphs Tab >> Name and Value Labels Study/Price Overlay Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-16 18:26:27] |
the VAH and VAL are aligning but the POC is off but quite a bit. How can i rectify this
[2024-03-18 14:14:42] |
Please get us your charts by following these instructions (ignore the reference to 1 chart, we need the two charts you are using): Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-19 13:35:37] |
there should be three charts 1) TPO Chart 2) Numbers bars/footprint chart 3) 5-Min candlestick |
Private File |
[2024-03-19 15:28:46] |
There are a few reasons for differences between the chart with The "TPO Value Area Lines" study and the TPO chart: - The chart with the TPO Value Area lines is an 8-tick range chart. This would need to be a time-based chart where the bars can add up to 30 minute intervals (i.e. 1 minute, 5 minutes, 30 minutes, but not 7 minutes). - The Session Times for the two charts are different. - The TPO Value Area Lines is setup to reference 1 day back. This is not a problem, but just make sure that you are looking at the correct profile. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-19 16:16:50] |
Got it I just created a 30-min numbers chart with TPO Levels and then used study "study/price overaly" on the range numbers bar chart. This gives me prior day TPO levels on the numbers bar chart. If i merge TPO's on the TPO chart is there a way to get the merged TPO levels on numbers bar chart? |
[2024-03-19 16:48:19] |
Not directly. You would need another TPO Value Area Lines study with the Time Period set to be the same as the Merged profiles and then overlay that. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
