Date/Time: Mon, 25 Nov 2024 08:27:34 +0000
Add Subgraph Studies to a study / customize existing study
View Count: 251
[2024-03-14 22:45:17]
roofishigh - Posts: 4
Hi, I use the subgraph studies on other studies to make my indicator, then i save the group of studies. But when I load the group of studies on a chart with other studies on it, the order of studies is not the same and I would have to do everything again each time I use the group of studies in a different framework.
So I'd like to know if it is possible to regroup all those studies in one custom study, like by adding subgraphs or any other way.
Thanks for your time.
[2024-03-15 13:28:43]
The only way to solve this is to remove the existing studies from the chart prior to adding the Study Collection. You can save the existing studies to another Study Collection and then reload it after the other one is loaded (assuming there are no references within those studies to each other). Refer to the following:
Study Collections: Adding a Study Collection Without Clearing Existing Studies On The Chart (Prompt to Remove Existing Studies)
