Date/Time: Sun, 12 May 2024 19:30:20 +0000
[Locked] - Notice - CQG/Rithmic/IB: Crypto Currency Data Requires Separate Installation
View Count: 133
[2024-03-14 10:12:35] |
Sierra_Chart Engineering - Posts: 14323 |
If you are using CQG, Rithmic or Interactive Brokers and you want to receive crypto currency data from Binance or BitMex or other exchanges. Install a separate installation of Sierra Chart: Using Multiple Data and Trading Services at the Same Time And follow the instructions here: Cryptocurrency / Bitcoin Data and Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
