Date/Time: Sat, 11 May 2024 14:41:47 +0000
No data in a charts
View Count: 81
[2024-03-14 09:32:55] |
Nerijus - Posts: 3 |
Hello I am attaching screen shots. |
Ekrano nuotrauka 2024-03-14 111149.png / V - Attached On 2024-03-14 09:32:23 UTC - Size: 195.37 KB - 26 views Ekrano nuotrauka 2024-03-14 111754.png / V - Attached On 2024-03-14 09:32:27 UTC - Size: 121.63 KB - 25 views |
[2024-03-14 10:16:20] |
Sierra_Chart Engineering - Posts: 14313 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
