Date/Time: Sun, 05 May 2024 12:56:40 +0000
Recentering DOM on chart
View Count: 3040
[2013-05-06 14:29:56] |
pe1111112 - Posts: 35 |
First of all, the way you guys show the DOM on the chart is awesome. I have a question, though. Sometimes price goes up or down so far that I can't see all the bid/ask levels. How do I move the entire chart up or down to recenter them? I tried Trade > Re-Center Trade DOM Scales but that didn't do anything. The only solution I've found is to left click and drag on the prices and move the cursor up or down, but that just compresses everything. I want to keep the scale the same but actually move the chart up or down in the window. How do I do this? Thanks. |
dom on chart.png / V - Attached On 2013-05-06 14:28:08 UTC - Size: 14.71 KB - 654 views |
[2013-05-06 14:45:52] |
Sawtooth - Posts: 3993 |
If you choose Interactive Scale Move, a left click/drag on the y-axis will move the whole chart. Hold the Ctrl key with a left click/drag and the scale shrinks/expands. If you choose Interactive Scale Range, then vice versa. You can also use the Hand tool. Global Settings >> Tool Settings >> After Singe Tool Use Change To: Hand. Also, check Support Vertical Scaling/Movement With Hand Tool. |
[2013-05-06 14:50:54] |
ctrl+left click is what I wanted. Thanks! |
[2013-05-06 14:54:33] |
You can also double-click the price axis to recenter. |
[2013-05-06 14:59:38] |
After I messed up the range the other day I tried double clicking to fix it and it worked. I appreciate the help.
[2013-05-07 00:56:51] |
Complete documentation for Interactive Scale Move can be found here: http://www.sierrachart.com/index.php?l=doc/doc_Scaling.html#InteractiveScaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-19 08:12:44] |
User263711 - Posts: 11 |
How do I recenter 3 charts with same symbol altogether at the same time?
Re-center 3 charts.png / V - Attached On 2022-05-19 08:12:42 UTC - Size: 140.52 KB - 112 views |
[2022-06-01 18:36:03] |
You can do a re-center for all Chart/Trading DOMs: Trade Menu: Re-Center Trade DOM Scales (Trade menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
