Date/Time: Sun, 12 May 2024 13:20:50 +0000
Teton not providing futures spread margins
View Count: 239
[2024-03-12 20:55:40] |
User720879 - Posts: 27 |
I have been trying to trade spreads through my broker Ironbeam with Teton and I can only trade Calendar spreads, the reason I am told is that Teton is not providing the margin values so the trades are being rejected. I can find the symbols for Butterflies and some condors plus Inter market spreads but cannot trade them in my live account, please advise? Example log 2024-03-11 15:54:28.046 | Teton CME Order Routing (Order reject). Info: Trade Order Error - LastTradingDateForSymbol is not known. Need to resubmit order. Text: Tag: CLTrailStop.twconfig. Internal Order ID: 8721. Service Order ID: 1946225. Symbol: HOM24-HOQ24.FUT_SPREAD.CME. Account: xxxxxxxx |
[2024-03-12 23:24:52] |
Sierra_Chart Engineering - Posts: 14319 |
This is true. Margin for spreads other than calendar spreads need to be manually set by the clearing firm for Teton order routing. That rejection message you provided above, does not relate to this though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-13 07:11:29] |
My apologies for the wrong error message my bad! So is there a solution to this, do I need to move to another data provider? or is this something that will be resolved in the future as Teton does provide the symbol, should it not provide the other variables required to trade it? Please advise |
[2024-03-13 15:14:58] |
Who is the clearing firm that you use? We will see about providing margins for more complex spreads. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-03-13 15:15:24
[2024-03-13 16:16:16] |
Ironbeam I believe
[2024-03-13 21:18:15] |
Yes they were asking us about this. Ok we need to think about this.
[2024-03-14 14:09:32] |
Thank you, please let me know the conclusion
[2024-04-05 00:33:24] |
We apologize for the delay. The best we can do right now is if you tell us the particular category of spreads you need to trade (give us some examples), we can set up the necessary Symbol Settings for them and have Ironbeam manually set the margin for them. Although we do not know if they would agree. We will try. Maybe they could set a default high-margin which is always going to be good. Although they may not want to do this at all. The CME does not provide any API to give it a complex spread symbol, and it comes back with a margin. It requires all the components be parsed out by us, and then they have to be given to a calculator to resolve the margin. We do this a little different with calendar spreads but the concept is similar. And we just support margins for simple calendar spreads. The other possibility is to use CQG for these more complex spreads which Sierra Chart supports. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-05 00:34:38
[2024-04-08 14:47:25] |
Can you please advise, what I would need to do to use CQG and have the same service I currently have (replace like for like, exchanges, DOM etc)
[2024-04-08 22:23:28] |
To use CQG do I need to deactivate Denali services in control panel? or can I test CQG on another instance/installation first?
[2024-04-09 14:54:02] |
I have moved to CQG, I now cannot chart or trade any spreads, please advise I was guided towards this solution by the broker and your support and now have no solution? |
[2024-04-09 15:21:37] |
You do need to continue to use the Denali Exchange Data Feed when using CQG. Do not deactivate that. Here are the CQG set up instructions: CQG Trading Platform Service: Setup Instructions To translate the symbols in your existing Chartbooks, use this Edit menu command: Edit Menu: Edit >> Translate Symbols To Current Service You need to open a spread chart using the standard Denali symbol: Denali Exchange Data Feed: Using Denali Futures Spread Data with Trading Service And then set the Trade and Current Quote Symbol to the CQG spread symbol. You will have to determine what that is. : CQG Trading Platform Service: CQG Symbol Format CQG spread symbols are terrible because they do not use exchange standard symbols and they are not clear in their formatting. We wish we had a better solution for you, but we cannot offer that short-term. We really do dislike CQG but this is the best we can do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-09 15:23:05
