Date/Time: Sun, 24 Nov 2024 14:53:46 +0000
chart chat
View Count: 530
[2024-03-11 10:46:03] |
TheFibber - Posts: 83 |
hi i tried to connect to the chat but it doesnt' work. it looks like i'm connected but nothing appen when i try to use the chat . i attach some images. i tried to find some help in the manual but i didn't find
Screenshot 2024-03-11 114520.png / V - Attached On 2024-03-11 10:45:49 UTC - Size: 67.85 KB - 89 views Screenshot 2024-03-11 114428.png / V - Attached On 2024-03-11 10:45:54 UTC - Size: 34.91 KB - 64 views |
[2024-03-11 17:58:13] |
You have to find someone to chat with. You can search by their Sierra Chart Account Name. On the Chat window, select "Commands >> New Chat" and fill in the field and select the button to find people. Note that there is an option for whether your Account Name is searchable or not. On the Chat window select "Commands >> Settings" and note the top item for "Make my Username Searchable". This needs to be set to "Yes" on the account for someone you want to Chat with in order for you to be able to find and add them to a chat. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-12 11:18:11] |
ok thanks ..i miss my real intention thas is to use alarm with that chat as you told it's possible from now on, after the dismission of the classic alert by email
[2024-03-12 16:15:58] |
There are a few items that are still being worked out today. Refer to the information here: Notice: Sierra Chart Alert App and Telegram Replacing Email/SMS Alerts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-14 09:36:08] |
ok thanks. the chat is working..alerts goes to the chat . so it's ok..the problem is telegram. i configured as you told as you see from the attachment but nothing appear on the telegram chat...only into sierra chat
Screenshot 2024-03-14 103414.png / V - Attached On 2024-03-14 09:35:08 UTC - Size: 27.25 KB - 66 views Screenshot 2024-03-14 103305.png / V - Attached On 2024-03-14 09:36:00 UTC - Size: 31.07 KB - 62 views |
[2024-03-14 15:59:09] |
Make sure you are on the current Pre-Release (v 2616) and follow the instructions at the following link: Notice: Sierra Chart Alert App and Telegram Replacing Email/SMS Alerts | Post: 375015 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-03-17 01:12:35
[2024-03-15 13:26:34] |
i did it before. i've gopt all updated and i followed instructions. nothing
Screenshot 2024-03-15 142508.png / V - Attached On 2024-03-15 13:26:29 UTC - Size: 92.48 KB - 65 views |
[2024-03-15 14:29:51] |
Please refer to the last post at the following link: Notice: Sierra Chart Alert App and Telegram Replacing Email/SMS Alerts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-17 09:54:52] |
User103448 - Posts: 74 |
@John idk where to put this, but there are not taking screenshots of the chart anymore when a signal is triggered. This worked perfectly and were send to telegram until last week. Any Ideas? The signal/alert tho finds his way to telegram. BTW - Starting new Chat makes Sierra Crash right now. Using Current Update. Edit: Starting New Group works, but also with no screenshots taking. Date Time Of Last Edit: 2024-05-17 10:09:06
[2024-05-17 12:38:14] |
VLiviu - Posts: 223 |
when I click "new chat" SC crashes, it just disappears! happens every time |
[2024-05-17 19:30:47] |
Sierra_Chart Engineering - Posts: 17156 |
We are resolving this now: BTW - Starting new Chat makes Sierra Crash right now. Using Current Update. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
