Date/Time: Mon, 25 Nov 2024 10:20:14 +0000
No real time quote received
View Count: 214
[2024-03-07 05:32:44] |
User189399 - Posts: 43 |
I have subscribed Denail US futures and checked my services is activated but I found I received delayed quote (Comex) instead of real time quote recently. Note I have updated to the most current SC version. Pls help to fix it.
[2024-03-07 06:12:06] |
Sierra_Chart Engineering - Posts: 17172 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-07 12:55:25] |
2024-03-07 20:41:31.035 | Trade activity files set size: 1770 2024-03-07 20:41:31.197 | Created the DTC Protocol server. 2024-03-07 20:41:31.204 | DTC Protocol Server listening on port 11197. 2024-03-07 20:41:31.204 | Reading Internal Order ID file. 2024-03-07 20:41:31.627 | Reading Trade Orders file. 2024-03-07 20:41:31.627 | Reading Trade Positions file. 2024-03-07 20:41:31.628 | Reading Trade Account Data files. 2024-03-07 20:41:31.645 | UDPListener (1788). Port 22902 | Listening on UDP port 22902. 2024-03-07 20:41:31.645 | Software version: 2610 64-bit 2024-03-07 20:41:31.645 | Primary Thread ID: 105020 2024-03-07 20:41:31.645 | Usage end date: 2024-05-25 2024-03-07 20:41:31.645 | Enabled for: Advanced Features 2. 2024-03-07 20:41:31.645 | Enabled for: Sierra Chart Historical Data Service. 2024-03-07 20:41:31.645 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-03-07 20:41:31.645 | Enabled for: Delayed Denali Exchange Data Feed. 2024-03-07 20:41:31.645 | Enabled for exchange2: CME (Trading Account Required) 2024-03-07 20:41:31.645 | Enabled for exchange2: CBOT (Trading Account Required) 2024-03-07 20:41:31.645 | Enabled for exchange2: COMEX (Trading Account Required) 2024-03-07 20:41:31.645 | Enabled for exchange2: NYMEX (Trading Account Required) 2024-03-07 20:41:31.645 | Enabled for exchange2: NASDAQ TotalView US stock data 2024-03-07 20:41:31.645 | Allow Support for Sierra Chart Data Feeds is disabled. 2024-03-07 20:41:31.645 | Current selected Data/Trading service: SC Data - All Services 2024-03-07 20:41:31.645 | Custom symbol settings values: enabled 2024-03-07 20:41:31.645 | Chart Update Interval: 500 2024-03-07 20:41:31.645 | Intraday Data Storage Time Unit: 0 2024-03-07 20:41:31.645 | Time Zone: +08:00:00 (HKT+08) 2024-03-07 20:41:31.645 | 2024-03-07 12:41:31 Local computer time in UTC 2024-03-07 20:41:31.645 | 2024-03-07 20:41:31 Local computer time in SC Time Zone 2024-03-07 20:41:31.645 | 2024-03-07 12:41:27 Server time in UTC 2024-03-07 20:41:31.645 | Local computer UTC time and Server UTC time difference: 2 seconds. 2024-03-07 20:41:31.645 | Program path: C:\AMP_SC\ 2024-03-07 20:41:31.645 | Data Files path: C:\AMP_SC\Data\ 2024-03-07 20:41:31.645 | OS Version Number: 10.0 2024-03-07 20:41:31.645 | Locale Setting: C 2024-03-07 20:41:31.647 | DLLs: 0625_Seven_in_One_Advanced_Order_Flow_Tool_30_9_2019_64.dll, 2019_Indicator_Finalized_1_9_2019.dll, ATM_V6_64.dll, AutoDrawRS_V1_1.dll, AutoDrawRS_V1_1_64.dll, AutoDrawRS_V1_64.dll, AutoDrawRS_V2_1_64.dll, AutomatedTradeManagementBySubgraph_V2.dll, DrawPOC_64.dll, DrawPOC_V1_64.dll, GMACD_V1.dll, GMACD_V1_64.dll, Guppy_MACD.dll, Guppy_MACD_64.dll, Heikin_123_TradeSys_BT_V1_64.dll, Heikin_TradeSys_V1_64.dll, Heikin_TradeSys_V2_1_64.dll, HSI_ST_SignalSys_V1_64.dll, itrend_b1.dll, itrend_b1_64.dll, MyTradeSys.dll 2024-03-07 20:41:31.647 | Allowed protected custom studies: AutoDrawRS_StudyV1_1, AutoDrawRS_Study_V2_0, DrawPOC_V1, GMACD_V1, RT_OF_Tools_V1, RT_TrendChartFF_V1_0, RT_TrendChartStock_V1_0, RT_TrendChart_V1_0, RT_TrendChart_V3_0 2024-03-07 20:41:31.647 | Crash reporter started: true 2024-03-07 20:41:31.647 | 2024-03-07 20:41:31.686 | Created the DTC Protocol historical data server. 2024-03-07 20:41:31.693 | HD Server Manager | Listening on port 11196. 2024-03-07 20:41:31.693 | Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. 2024-03-07 20:41:31.742 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2024-03-07 20:41:31.902 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2024-03-07 20:41:31.902 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2024-03-07 20:41:32.243 | Received 5 login tokens. 2024-03-07 20:41:34.217 | Requested user files to download. 2024-03-07 20:41:36.002 | Symbol settings MD5 received. Request ID: 1. 2024-03-07 20:41:36.002 | Symbol settings are up-to-date for scdataallservices. 2024-03-07 20:41:36.218 | 2024-03-07 20:41:36.218 | SC Data - All Services | Connected to server complete. 2024-03-07 20:41:36.218 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-03-07 20:42:04.199 | File >> Disconnect selected. 2024-03-07 20:42:04.199 | SC Data - All Services | Disconnected. 2024-03-07 20:42:06.464 | 2024-03-07 20:42:06.464 | SC Data - All Services | Connected to server complete. 2024-03-07 20:42:06.464 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-03-07 20:49:24.548 | GCJ24-COMEX 1 Min #1 | Reloading chart. 2024-03-07 20:49:24.965 | GCJ24-COMEX 1 Min #1 | Chart data loading complete. 2024-03-07 20:49:25.057 | Mapping GCJ24-COMEX to GCJ24. Service code: comex 2024-03-07 20:49:25.057 | Using symbol data fast lookup vector 2024-03-07 20:49:25.058 | Delayed Data Feed | Starting real-time market data updates for: GCJ24-COMEX (GCJ24). ID: 1 Service code: comex 2024-03-07 20:49:25.065 | Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 2024-03-07 20:49:25.073 | Delayed Data Feed | Requesting security definition data for: GCJ24-COMEX (GCJ24). ID: 1 2024-03-07 20:49:25.073 | Starting DelayedDownloadMonitoringTimer 2024-03-07 20:49:25.073 | Starting HDTimeoutTimer 2024-03-07 20:49:25.073 | Added historical Intraday data request for GCJ24-COMEX to the queue. 2024-03-07 20:49:25.073 | Intraday data recording state for symbol GCJ24-COMEX is set to download 'Pending'. 2024-03-07 20:49:25.073 | DTC Client socket (1) | Creating socket. 2024-03-07 20:49:25.073 | DTC Client socket (1) | New receive buffer size: 0 2024-03-07 20:49:25.073 | DTC Client socket (1) | Connecting to IP: 38.103.112.184. 2024-03-07 20:49:25.081 | Triggering next historical data download in queue. 2024-03-07 20:49:25.109 | Delaying start of download for GCJ24-COMEX. 2024-03-07 20:49:25.275 | Delayed Data Feed | Network connection to server complete. 2024-03-07 20:49:25.275 | Delayed Data Feed | Starting socket receive thread. 2024-03-07 20:49:25.275 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-03-07 20:49:25.501 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2024-03-07 20:49:25.501 | Delayed Data Feed | Sending logon request message. 2024-03-07 20:49:26.023 | Delayed Data Feed | Received logon response. 2024-03-07 20:49:26.023 | Delayed Data Feed | Server Name: SC Realtime Server. 2024-03-07 20:49:26.023 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2024-03-07 20:49:26.023 | Delayed Data Feed | Successfully connected. 2024-03-07 20:49:26.023 | Delayed Data Feed | Trading is not supported. 2024-03-07 20:49:26.023 | Delayed Data Feed | MarketDepthIsSupported: 1 2024-03-07 20:49:26.023 | Delayed Data Feed | Restarting real-time data updates for symbol: GCJ24-COMEX -> GCJ24 2024-03-07 20:49:26.306 | Delayed Data Feed | Received security definition for symbol GCJ24-COMEX 2024-03-07 20:49:31.937 | HD Request # 1 | Downloading Intraday chart data for GCJ24-COMEX to the file GCJ24-COMEX.scid. Service: comex 2024-03-07 20:49:31.937 | HD Request # 1 | Download start date-time: 2024-03-07 20:31:00.000000. File last date-time: 2024-03-07 20:31:00.751000 2024-03-07 20:49:31.937 | HD Request # 1 | Using server: ds26.sierracharts.com port 10149 2024-03-07 20:49:32.012 | Socket (2) | Creating socket. 2024-03-07 20:49:32.012 | Socket (2) | New receive buffer size: 0 2024-03-07 20:49:32.012 | Socket (2) | Connecting to IP: 38.103.112.197. 2024-03-07 20:49:32.425 | HD Request # 1 | Setting DTC encoding to Binary VLS 2024-03-07 20:49:32.425 | HD Request # 1 | Sending historical data logon request message. 2024-03-07 20:49:32.902 | HD Request # 1 | Requesting Intraday data. Start date-time: 2024-03-07 20:31:00. Record interval: 0. Symbol: GCJ24 2024-03-07 20:49:33.104 | HD Request # 1 | Decompressing data. 2024-03-07 20:49:33.313 | HD Request # 1 | Receiving Intraday data for GCJ24-COMEX starting at 2024-03-07 20:31:00.038000 2024-03-07 20:49:33.317 | Socket (2) | CloseSocket call. 2024-03-07 20:49:33.317 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-03-07 20:49:33.318 | Historical data download thread signaled to stop. 2024-03-07 20:49:33.318 | HD Request # 1 | Timestamp of first Intraday data file record written: 2024-03-07 20:31:08.153000. 2024-03-07 20:49:33.318 | HD Request # 1 | Received 2325 Intraday data records from 2024-03-07 20:31:00.038000 to 2024-03-07 20:49:27.624006 (18.5 minutes. Delay: 5.7 seconds) and wrote 2317 records for GCJ24-COMEX 2024-03-07 20:49:33.319 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2024-03-07 12:49:27.624006 2024-03-07 20:49:33.320 | HD Request # 1 | Completion time: 2s. 2024-03-07 20:49:33.320 | HD Request # 1 | Intraday data download complete for GCJ24-COMEX. Unique request ID: 1 2024-03-07 20:49:33.320 | Removing historical data download ID 1. 2024-03-07 20:49:33.320 | Real-time Intraday chart data file updates started for GCJ24-COMEX 2024-03-07 20:49:33.320 | Intraday chart data file opened for GCJ24-COMEX 2024-03-07 20:49:33.320 | HD Request # 1 | Enabling Intraday chart updating for symbol. 2024-03-07 20:49:33.320 | 2024-03-07 20:49:33.320 | No download requests in the queue to start downloads for. 2024-03-07 20:49:33.520 | Socket (2) | Socket gracefully closed by remote side. 2024-03-07 20:49:33.521 | Socket (2) | Closed. 2024-03-07 20:49:33.565 | Opened cached Intraday file: C:\AMP_SC\Data\GCJ24-COMEX.scid. Thread ID: 105988 2024-03-07 20:51:30.327 | File >> Disconnect selected. 2024-03-07 20:51:30.327 | Delayed Data Feed | Waiting for socket receive thread to end 2024-03-07 20:51:30.327 | DTC Client socket (1) | CloseSocket call. 2024-03-07 20:51:30.327 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-03-07 20:51:30.327 | Delayed Data Feed | Disconnected from the server. 2024-03-07 20:51:30.327 | SC Data - All Services | Disconnected. 2024-03-07 20:51:30.723 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-03-07 20:51:30.723 | DTC Client socket (1) | Closed. 2024-03-07 20:51:38.319 | 2024-03-07 20:51:38.320 | SC Data - All Services | Connected to server complete. 2024-03-07 20:51:38.320 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-03-07 20:51:38.452 | Mapping GCJ24-COMEX to GCJ24. Service code: comex 2024-03-07 20:51:38.452 | Using symbol data fast lookup vector 2024-03-07 20:51:38.452 | Delayed Data Feed | Starting real-time market data updates for: GCJ24-COMEX (GCJ24). ID: 1 Service code: comex 2024-03-07 20:51:38.452 | Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 2024-03-07 20:51:38.453 | Delayed Data Feed | Requesting security definition data for: GCJ24-COMEX (GCJ24). ID: 1 2024-03-07 20:51:38.453 | Added historical Intraday data request for GCJ24-COMEX to the queue. 2024-03-07 20:51:38.453 | Intraday data recording state for symbol GCJ24-COMEX is set to download 'Pending'. 2024-03-07 20:51:38.453 | Triggering next historical data download in queue. 2024-03-07 20:51:38.479 | Delaying start of download for GCJ24-COMEX. 2024-03-07 20:51:38.528 | DTC Client socket (1) | Creating socket. 2024-03-07 20:51:38.528 | DTC Client socket (1) | New receive buffer size: 0 2024-03-07 20:51:38.528 | DTC Client socket (1) | Connecting to IP: 38.103.112.198. 2024-03-07 20:51:38.729 | Delayed Data Feed | Network connection to server complete. 2024-03-07 20:51:38.729 | Delayed Data Feed | Starting socket receive thread. 2024-03-07 20:51:38.730 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-03-07 20:51:38.969 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2024-03-07 20:51:38.969 | Delayed Data Feed | Sending logon request message. 2024-03-07 20:51:39.530 | Delayed Data Feed | Received logon response. 2024-03-07 20:51:39.530 | Delayed Data Feed | Server Name: SC Realtime Server. 2024-03-07 20:51:39.530 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2024-03-07 20:51:39.530 | Delayed Data Feed | Successfully connected. 2024-03-07 20:51:39.530 | Delayed Data Feed | Trading is not supported. 2024-03-07 20:51:39.530 | Delayed Data Feed | MarketDepthIsSupported: 1 2024-03-07 20:51:39.530 | Delayed Data Feed | Restarting real-time data updates for symbol: GCJ24-COMEX -> GCJ24 2024-03-07 20:51:39.811 | Delayed Data Feed | Received security definition for symbol GCJ24-COMEX 2024-03-07 20:51:44.402 | HD Request # 2 | Downloading Intraday chart data for GCJ24-COMEX to the file GCJ24-COMEX.scid. Service: comex 2024-03-07 20:51:44.403 | HD Request # 2 | Download start date-time: 2024-03-07 20:49:27.000000. File last date-time: 2024-03-07 20:49:27.624006 2024-03-07 20:51:44.403 | HD Request # 2 | Using server: ds28.sierracharts.com port 10150 2024-03-07 20:51:44.479 | Socket (2) | Creating socket. 2024-03-07 20:51:44.479 | Socket (2) | New receive buffer size: 0 2024-03-07 20:51:44.479 | Socket (2) | Connecting to IP: 38.103.112.187. 2024-03-07 20:51:44.889 | HD Request # 2 | Setting DTC encoding to Binary VLS 2024-03-07 20:51:44.889 | HD Request # 2 | Sending historical data logon request message. 2024-03-07 20:51:45.359 | HD Request # 2 | Requesting Intraday data. Start date-time: 2024-03-07 20:49:27. Record interval: 0. Symbol: GCJ24 2024-03-07 20:51:45.562 | HD Request # 2 | Decompressing data. 2024-03-07 20:51:45.763 | HD Request # 2 | Receiving Intraday data for GCJ24-COMEX starting at 2024-03-07 20:49:27.624000 2024-03-07 20:51:45.764 | Socket (2) | CloseSocket call. 2024-03-07 20:51:45.764 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-03-07 20:51:45.764 | Historical data download thread signaled to stop. 2024-03-07 20:51:45.764 | HD Request # 2 | Timestamp of first Intraday data file record written: 2024-03-07 20:49:32.233000. 2024-03-07 20:51:45.764 | HD Request # 2 | Received 274 Intraday data records from 2024-03-07 20:49:27.624000 to 2024-03-07 20:51:42.665000 (2.3 minutes. Delay: 3.1 seconds) and wrote 267 records for GCJ24-COMEX 2024-03-07 20:51:45.764 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2024-03-07 12:51:42.665000 2024-03-07 20:51:45.764 | HD Request # 2 | Completion time: 1s. 2024-03-07 20:51:45.764 | HD Request # 2 | Intraday data download complete for GCJ24-COMEX. Unique request ID: 2 2024-03-07 20:51:45.764 | Removing historical data download ID 2. 2024-03-07 20:51:45.764 | Real-time Intraday chart data file updates started for GCJ24-COMEX 2024-03-07 20:51:45.764 | Intraday chart data file opened for GCJ24-COMEX 2024-03-07 20:51:45.764 | HD Request # 2 | Enabling Intraday chart updating for symbol. 2024-03-07 20:51:45.764 | 2024-03-07 20:51:45.764 | No download requests in the queue to start downloads for. 2024-03-07 20:51:45.966 | Socket (2) | Socket gracefully closed by remote side. 2024-03-07 20:51:45.966 | Socket (2) | Closed. 2024-03-07 20:51:46.813 | Opened cached Intraday file: C:\AMP_SC\Data\GCJ24-COMEX.scid. Thread ID: 106124 |
[2024-03-07 16:01:03] |
The following item from your log is the problem: 2024-03-07 20:41:31.645 | Allow Support for Sierra Chart Data Feeds is disabled.
Select "Global Settings >> Data/Trade Service Settings" and on the "Common Settings" page set the option for "Allow Support for Sierra Chart Data Feeds" to "Yes". Then select OK to close that window and then select "File >> Reconnect". After this, you will be getting the real-time data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-07 16:46:05] |
It worked. Thanks
