Date/Time: Mon, 13 May 2024 01:41:14 +0000
Show order fill not showing
View Count: 124
[2024-03-06 17:57:02] |
Daniel Gonzalez - Posts: 13 |
Hello, My show order fill and order position do not show on my footprint. I have both settings turned on and am using the same symbol to trade as my footprint. Any help would be greatly appreciated. Thank you |
Screenshot 2024-03-06 at 11.53.30 AM.png / V - Attached On 2024-03-06 17:56:36 UTC - Size: 6.72 KB - 28 views |
[2024-03-06 19:11:11] |
John - SC Support - Posts: 31555 |
Refer to the following: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-21 19:12:14] |
I checked the settings and show order fills is still not showing up. I have attached a screenshot of where I entered and the chart does not show my fill.
Screenshot 2024-03-21 at 2.10.52 PM.png / V - Attached On 2024-03-21 19:12:00 UTC - Size: 197.53 KB - 25 views |
[2024-03-21 19:45:44] |
You have the option for "Trade >> Only Orders from Chart" enabled. Did this orders originate in this chart? If not, then the position and order fills will not show in this chart. Refer to item #2 at the following link: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-22 15:11:23] |
The issue is I only show the order fills & postions in simulation. Whenever I turn simulation off I no longer show order fills whenever I turn simulation off. I have not changed any settings from sim to regular trading.
[2024-03-22 16:07:15] |
You are only ever going to see the Order Fills for the currently selected trading account. So order fills from Simulation Mode will not show when you are not in Simulation Mode, as the simulation account is not selected. Refer to the following for how to select the Trading Account: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
