Date/Time: Mon, 25 Nov 2024 12:19:59 +0000
Chart value/crosshair now has black boxes after upgrade
View Count: 298
[2024-03-04 15:45:32] |
rlotz1 - Posts: 11 |
The crosshair boxes for time/date and right side value are now black aftr latest upgrade. I can't find the setting to change in Global Graphics. Thanks,Rick. screenshot below |
[2024-03-04 17:23:42] |
Refer to the following: Graphics Settings: Chart Values: Price and Time Boxes Text Color For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-04 17:50:51] |
Thanks John,but that didn't work. I reverted to ver. 2568 and everything works as it always did. Also ver. 2576 works. Something must have changed in ver 2609.
[2024-03-04 20:57:23] |
The change in 2609 (or one of the releases around it) was for this new setting that controls the color of the text in the Price and Time boxes. By default it is set to Black, so it needs to be changed. If you were changing this and it was not changing the color of the text in the Price and Time boxes, then most likely you were not changing the color in the correct section. Keep in mind there are Global Graphics Settings and Chart Graphics Settings. The use of one or the other is controlled by the option in the Graphics Settings - Chart for "Use Global Graphics Settings Instead of These Settings". Refer to the following: Graphics Settings: Using Different Color and Graphics Settings for Specific Charts If you were changing one and it was not affecting the chart, then most likely you were setup to use the other option. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
