Date/Time: Mon, 25 Nov 2024 13:25:15 +0000
Data
View Count: 185
[2024-02-28 22:33:35]
CWST - Posts: 6
Hi , for some reason i dont seem to have any trading data on my chart for today 28/02/2024, any reason why?
[2024-02-28 22:33:50]
What is one symbol for which you are having an issue?
[2024-02-28 23:50:41]
CWST - Posts: 6
MGCJ24_FUT_CME, CLJ24_FUT_CME, ESH24-CME
[2024-02-29 16:00:21]
Depending on your setting for "Global Settings >> Data/Trade Service Settings >> Main Settings >> Current Selected Service", either the first two symbols are incorrect, or the third one is. With your chartbooks open, please select "Edit >> Translate Symbols to Current Service". This will update the symbols to be what is needed for your current service.
If you continue to have an issue after the above, then follow these instructions to get us your Message Log:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
