Date/Time: Mon, 25 Nov 2024 07:57:50 +0000
How to update payment information
View Count: 442
[2024-02-27 17:00:40]
User806937 - Posts: 7
How do I update my credit card payment information from my cell phone.
[2024-02-27 17:58:48]
The process is the same regardless of where you are making the change. Since you are setup for automatic payments, you need to first remove the existing card by going to the "Payments" page, scrolling to the bottom and selecting the button for "Manage Automatic Payments" in the section for "Automatic Payments with Stripe". Follow the instructions to remove the old card setup.
Then select the same button again to enter the new card information.
You can access the Payments page at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit#MoveToTop
[2024-03-16 17:23:59]
User911458 - Posts: 6
Hi. I'm also wondering if there are any restrictions or requirements for the new credit card that I should consider? Are there any deadlines or limitations for changing the card before the next billing cycle? I'm contemplating making the change but I'm not entirely sure if I have enough information.Recently, I encountered the issue of choosing the right payment method for online casinos. There are many different options, each with its own advantages and disadvantages. However, I stumbled upon https://casinosanalyzer.com/online-casinos/sms and found a very interesting payment method using SMS. As I delved into it, I realized that it's actually very convenient.
Date Time Of Last Edit: 2024-03-27 10:40:06
[2024-03-18 14:13:04]
You are not setup for any automatic payments. Therefore you enter your card information at the time that you make the payment. We do not care what kind of card you use, as long as it is supported by our processors.
