Date/Time: Mon, 25 Nov 2024 14:40:33 +0000
LIVE CHART ?
View Count: 196
[2024-02-26 22:19:03] |
jiannisalex - Posts: 9 |
Dear Sierra Chart support team, I am not a professional, could you please help understand if my chart is live or is it on simulation mode ? If it is on simulation, how can I change it to live ? Additionally, when I use the Crosshair, at the bottom of the chart there is totally black frame and I cannot see the corresponding time. I hope I was clear enough, Thank you very much in advance, Yours sincerely, Yiannis Alexakis |
[2024-02-27 15:56:44] |
John - SC Support - Posts: 36243 |
To determine if you are in Simulation Mode or live, you need to look at the Trade menu at the top and see if there is a checkmark next to "Simulation Mode On". If it has a checkmark next to it, then you are in Simulation Mode, otherwise you are live with whatever service you are set to connect to. Refer to the following: Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes With regards to the boxes in the Price and Time scales, there is a new setting for the color of the text, which defaults to black. You will need to update this item. Refer to the following: Graphics Settings: Chart Values: Price and Time Boxes Text Color For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
