Date/Time: Mon, 25 Nov 2024 14:29:20 +0000
Volume At Price Threshold Alert V2 (Multiple, Non-adjacent Imbalance Alert)
View Count: 267
[2024-02-25 02:14:24]
User269923 - Posts: 3
Is it possible to have the Volume At Price Threshold Alert V2 study alert off of multiple bid/ask volume imbalances in a bar that are not necessarily adjacent/stacked?
Thanks.
Date Time Of Last Edit: 2024-02-25 02:20:43
[2024-02-26 16:37:51]
John - SC Support - Posts: 36241
It does not matter if they are adjacent or not. The same rules apply for getting a sound alert when there are a certain number of visual alerts shown for a bar. The easiest way is to use the "Count of Alerts" subgraph and set that equal to the number you want. For example, if you want an alert when there are 3 visual cues, then you would write the following formula for the alert:
=ID1.SG59 >= 3
Refer to the following:
Volume at Price Threshold Alert V2: Count of Alerts Subgraph
Study/Chart Alerts And Scanning
General Settings Window: Alerts (Global Settings >> General Settings)
