Date/Time: Wed, 08 May 2024 19:41:49 +0000
No Data
View Count: 1523
[2013-05-06 10:50:29] |
LukeScisl - Posts: 18 |
I have a problem, when i ran the program today i see that all charts stopped at 3 IV 2013.Is there any problem with the continuity?
[2013-05-06 10:53:44] |
Yesterday I installed a new version of the program. do I need press somewhere to unlock data? |
[2013-05-06 11:01:26] |
The service you are currently using is End of Day delayed. Use the Sierra Chart Historical Data Service which is documented here: http://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html#UsingSCHDS The delay will only be 30 minutes maximum. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
