Date/Time: Mon, 16 Sep 2024 19:38:55 +0000
Summary table for different studies values : best way to achieve this ?
View Count: 270
[2024-02-08 14:57:21] |
User217676 - Posts: 12 |
Hi, I would like to create a table that summaries all my main studies values for every time-frame I use. These studies are located in different charts in a single chartbook. The background of each cell has to be color coded so I can analyse the situation in a glimpse of an eye (3 colors : Green (bullish), white (neutral), red (bearish)) I made a "skeleton" of what should look like the table (see attached file). 1) Is there already an study that allows to do this kind of table ? 2) If not, what is the best way to achieve this ? Spreadsheet or custom study ? I've never used spreadsheet but my understanding is that it doesn't allow to color code the background of each cell ? Regards, Sébastien |
Table study.png / V - Attached On 2024-02-08 14:29:08 UTC - Size: 22.34 KB - 60 views Attachment Deleted. |
[2024-02-08 15:14:10] |
User43 - Posts: 101 |
The closest I know of to what you are looking for would be "Numbers Bars Calculated Values". Numbers Bars: Displaying Numeric Information Below Numbers Bars But that is only aggregating the values on the current chart. Looks like you need a custom study to achieve your goal. |
[2024-02-08 15:57:02] |
User431178 - Posts: 503 |
There is the option of the study summary window. Study Summary Window |
[2024-02-10 12:43:36] |
Thank you for your feedback. I didn't know the existence of the Study summary Window. It is doing the job well except for the custom background coloring. It's better than nothing until I find how to program a custom study to achieve my goal. |
