Date/Time: Mon, 20 May 2024 17:23:24 +0000
Show bar prices with percentage of vPOC
View Count: 137
[2024-02-06 12:19:25] |
pasarn - Posts: 3 |
Hello, is there a study that marks the price of a candle that has 95% of the volume of the vPOC? I have test it with the Volume At Price Threshold Alert. But I had no success. The screenshot shows an example of another software. The yellow prices have 95% of the POC volume Date Time Of Last Edit: 2024-02-06 12:21:20
Screenshot_198.png / V - Attached On 2024-02-06 12:18:24 UTC - Size: 67.43 KB - 36 views |
[2024-02-06 18:22:30] |
John - SC Support - Posts: 31745 |
There are a few different options, depending on what you want to do. First, within the Volume by Price study, there is the option for "Color Code Volume Bars Based on Percentage of POC". Refer to the following: Volume By Price Study: Color Code Volume Bars Based on Percentage of POC Within the Numbers Bars, any of the options that does a Percentage of Volume will allow you to setup the "Percent Compare Thresholds" and set a value of .95 to get a certain color. Refer to the information here: Numbers Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-05 11:10:13] |
pasarn - Posts: 3 |
Thangs. I have found an soulution. I add an second Numers Bar Indicator with Volume Profile Outline and set the Color by Based on Volume Percentage. Not really pretty but it works. I would also be happy with an option that works like the Stacked Inbaleces via the Volume at Price Alerte V2. I just need the prices to be highlighted. |
Screenshot_14.png / V - Attached On 2024-04-05 11:06:37 UTC - Size: 30.14 KB - 24 views |
