Date/Time: Mon, 25 Nov 2024 20:23:16 +0000
Flux Micro mini SP 500
View Count: 255
[2024-02-02 17:49:22]
User525038 - Posts: 14
Bonjour
Je ne peux pas mettre sur mes graphiques le micro mini SP500 Mars 24, merci de me signaler si je doit changer quelque chose, je reçois le mini SP500.
Merci pour votre aide
Daniel
[2024-02-02 18:10:57]
John - SC Support - Posts: 36278
From Google Translate:
I can't put the micro mini SP500 on my graphics March 24, please let me know if I need to change something, I get the mini SP500.
There is no particular reason why you would be having any issues with the Micro S&P 500 (MES) as you are setup to get the data for the Full CME Group.
If you are continuing to have an issue, then we need to know exactly what you are seeing (are you getting no data, some data, delayed data, etc.) and then get us your Message Log by following these instructions (be sure to follow the instructions exactly so we only get the data for the one symbol):
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2024-02-02 20:20:46]
j'ai envoyé le journal des message suite au graphique micro mini SP500
AC1235732
Daniel
[2024-02-04 23:46:12]
Sierra_Chart Engineering - Posts: 17174
Disable Use Custom Symbol Settings Values.
If you still have a problem reopen the chart through File >> Find Symbol >> Futures-CME
Date Time Of Last Edit: 2024-02-04 23:46:35
