Date/Time: Wed, 27 Nov 2024 04:59:12 +0000
Problems connecting after RTH
View Count: 1049
[2014-08-02 19:25:25]
EllenT - Posts: 21
Hi
I've been having problems connecting to Sierra charts after regular hours, both on weekdays and weekends since the last two weeks.
I keep getting the message, "Waiting to connect" but nothing happens. Below is a copy log. Please resolve this issue and let me know so I know.
Elaine
Software version: 1137 | 2014-08-02 15:11:55
Usage end date: 2014-12-01 | 2014-08-02 15:11:55
Enabled for: Advanced Features. | 2014-08-02 15:11:55
Enabled for: Advanced Features 2. | 2014-08-02 15:11:55
Enabled for: Sierra Chart Historical Data Service. | 2014-08-02 15:11:55
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-08-02 15:11:55
Active service: OEC FIX/FAST | 2014-08-02 15:11:55
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-08-02 15:11:55
2014-08-02 15:11:55 Local computer clock time | 2014-08-02 15:11:55
2014-08-02 19:11:55 GMT time | 2014-08-02 15:11:55
2014-08-02 15:11:55 Time zone adjusted time | 2014-08-02 15:11:55
Time difference to server time: 6 seconds. | 2014-08-02 15:11:55
Program path: C:\SierraChart\ | 2014-08-02 15:11:55
Data Files path: C:\SierraChart\Data\ | 2014-08-02 15:11:55
OS Version Number: 6.1 | 2014-08-02 15:11:55
Checking for new symbol settings for oec | 2014-08-02 15:11:55
Symbol settings are up-to-date for oec | 2014-08-02 15:11:56
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:12:00
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:12:00
The network socket is connected. | 2014-08-02 15:12:00
Starting SSL connection on the socket. | 2014-08-02 15:12:00
SSL socket is connected. | 2014-08-02 15:12:01
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:12:01
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:12:01
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:12:01
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:12:01
The SSL socket was shut down. | 2014-08-02 15:12:01
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:12:01
Socket has been shutdown and closed. | 2014-08-02 15:12:01
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:12:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:12:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:12:01
Disconnected from Open E Cry. | 2014-08-02 15:12:01
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:12:01
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:12:04
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:12:04
The network socket is connected. | 2014-08-02 15:12:04
Starting SSL connection on the socket. | 2014-08-02 15:12:04
SSL socket is connected. | 2014-08-02 15:12:04
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:12:04
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:12:04
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:12:04
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:12:04
The SSL socket was shut down. | 2014-08-02 15:12:04
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:12:04
Socket has been shutdown and closed. | 2014-08-02 15:12:04
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:12:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:12:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:12:04
Disconnected from Open E Cry. | 2014-08-02 15:12:04
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:12:04
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:12:07
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:12:07
The network socket is connected. | 2014-08-02 15:12:08
Starting SSL connection on the socket. | 2014-08-02 15:12:08
SSL socket is connected. | 2014-08-02 15:12:08
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:12:08
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:12:08
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:12:08
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:12:08
The SSL socket was shut down. | 2014-08-02 15:12:08
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:12:08
Socket has been shutdown and closed. | 2014-08-02 15:12:08
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:12:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:12:08
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:12:08
Disconnected from Open E Cry. | 2014-08-02 15:12:08
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:12:08
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:12:11
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:12:11
The network socket is connected. | 2014-08-02 15:12:11
Starting SSL connection on the socket. | 2014-08-02 15:12:11
SSL socket is connected. | 2014-08-02 15:12:12
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:12:12
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:12:12
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:12:12
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:12:12
The SSL socket was shut down. | 2014-08-02 15:12:12
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:12:12
Socket has been shutdown and closed. | 2014-08-02 15:12:12
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:12:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:12:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:12:12
Disconnected from Open E Cry. | 2014-08-02 15:12:12
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:12:12
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:12:15
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:12:15
The network socket is connected. | 2014-08-02 15:12:15
Starting SSL connection on the socket. | 2014-08-02 15:12:15
SSL socket is connected. | 2014-08-02 15:12:16
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:12:16
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:12:16
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:12:16
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:12:16
The SSL socket was shut down. | 2014-08-02 15:12:16
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:12:16
Socket has been shutdown and closed. | 2014-08-02 15:12:16
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:12:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:12:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:12:16
Disconnected from Open E Cry. | 2014-08-02 15:12:16
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:12:16
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:12:19
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:12:19
The network socket is connected. | 2014-08-02 15:12:19
Starting SSL connection on the socket. | 2014-08-02 15:12:19
SSL socket is connected. | 2014-08-02 15:12:20
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:12:20
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:12:20
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:12:20
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:12:20
The SSL socket was shut down. | 2014-08-02 15:12:20
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:12:20
Socket has been shutdown and closed. | 2014-08-02 15:12:20
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:12:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:12:20
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:12:20
Disconnected from Open E Cry. | 2014-08-02 15:12:20
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:12:20
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:12:23
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:12:23
The network socket is connected. | 2014-08-02 15:12:23
Starting SSL connection on the socket. | 2014-08-02 15:12:23
SSL socket is connected. | 2014-08-02 15:12:24
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:12:24
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:12:24
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:12:24
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:12:24
The SSL socket was shut down. | 2014-08-02 15:12:24
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:12:24
Socket has been shutdown and closed. | 2014-08-02 15:12:24
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:12:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:12:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:12:24
Disconnected from Open E Cry. | 2014-08-02 15:12:24
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:12:24
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:12:27
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:12:27
The network socket is connected. | 2014-08-02 15:12:27
Starting SSL connection on the socket. | 2014-08-02 15:12:27
SSL socket is connected. | 2014-08-02 15:12:27
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:12:28
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:12:28
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:12:28
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:12:28
The SSL socket was shut down. | 2014-08-02 15:12:28
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:12:28
Socket has been shutdown and closed. | 2014-08-02 15:12:28
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:12:28
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:12:28
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:12:28
Disconnected from Open E Cry. | 2014-08-02 15:12:28
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:12:28
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:12:31
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:12:31
The network socket is connected. | 2014-08-02 15:12:31
Starting SSL connection on the socket. | 2014-08-02 15:12:31
SSL socket is connected. | 2014-08-02 15:12:31
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:12:32
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:12:32
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:12:32
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:12:32
The SSL socket was shut down. | 2014-08-02 15:12:32
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:12:32
Socket has been shutdown and closed. | 2014-08-02 15:12:32
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:12:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:12:32
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:12:32
Disconnected from Open E Cry. | 2014-08-02 15:12:32
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:12:32
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:12:35
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:12:35
The network socket is connected. | 2014-08-02 15:12:35
Starting SSL connection on the socket. | 2014-08-02 15:12:35
SSL socket is connected. | 2014-08-02 15:12:36
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:12:36
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:12:36
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:12:36
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:12:36
The SSL socket was shut down. | 2014-08-02 15:12:36
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:12:36
Socket has been shutdown and closed. | 2014-08-02 15:12:36
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:12:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:12:36
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:12:36
Disconnected from Open E Cry. | 2014-08-02 15:12:36
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:12:36
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:12:39
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:12:39
The network socket is connected. | 2014-08-02 15:12:39
Starting SSL connection on the socket. | 2014-08-02 15:12:39
SSL socket is connected. | 2014-08-02 15:12:40
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:12:40
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:12:40
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:12:40
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:12:40
The SSL socket was shut down. | 2014-08-02 15:12:40
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:12:40
Socket has been shutdown and closed. | 2014-08-02 15:12:40
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:12:40
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:12:40
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:12:40
Disconnected from Open E Cry. | 2014-08-02 15:12:40
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:12:40
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:12:43
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:12:43
The network socket is connected. | 2014-08-02 15:12:43
Starting SSL connection on the socket. | 2014-08-02 15:12:43
SSL socket is connected. | 2014-08-02 15:12:43
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:12:44
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:12:44
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:12:44
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:12:44
The SSL socket was shut down. | 2014-08-02 15:12:44
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:12:44
Socket has been shutdown and closed. | 2014-08-02 15:12:44
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:12:44
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:12:44
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:12:44
Disconnected from Open E Cry. | 2014-08-02 15:12:44
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:12:44
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:12:47
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:12:47
The network socket is connected. | 2014-08-02 15:12:47
Starting SSL connection on the socket. | 2014-08-02 15:12:47
SSL socket is connected. | 2014-08-02 15:12:48
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:12:48
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:12:48
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:12:48
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:12:48
The SSL socket was shut down. | 2014-08-02 15:12:48
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:12:48
Socket has been shutdown and closed. | 2014-08-02 15:12:48
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:12:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:12:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:12:48
Disconnected from Open E Cry. | 2014-08-02 15:12:48
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:12:48
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:12:51
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:12:51
The network socket is connected. | 2014-08-02 15:12:51
Starting SSL connection on the socket. | 2014-08-02 15:12:51
SSL socket is connected. | 2014-08-02 15:12:52
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:12:52
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:12:52
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:12:52
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:12:52
The SSL socket was shut down. | 2014-08-02 15:12:52
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:12:52
Socket has been shutdown and closed. | 2014-08-02 15:12:52
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:12:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:12:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:12:52
Disconnected from Open E Cry. | 2014-08-02 15:12:52
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:12:52
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:12:55
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:12:55
The network socket is connected. | 2014-08-02 15:12:56
Starting SSL connection on the socket. | 2014-08-02 15:12:56
SSL socket is connected. | 2014-08-02 15:12:56
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:12:56
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:12:56
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:12:56
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:12:56
The SSL socket was shut down. | 2014-08-02 15:12:56
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:12:56
Socket has been shutdown and closed. | 2014-08-02 15:12:56
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:12:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:12:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:12:56
Disconnected from Open E Cry. | 2014-08-02 15:12:56
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:12:56
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:12:59
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:12:59
The network socket is connected. | 2014-08-02 15:13:00
Starting SSL connection on the socket. | 2014-08-02 15:13:00
SSL socket is connected. | 2014-08-02 15:13:00
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:13:00
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:13:00
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:13:00
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:13:00
The SSL socket was shut down. | 2014-08-02 15:13:00
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:13:00
Socket has been shutdown and closed. | 2014-08-02 15:13:00
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:13:00
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:13:00
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:13:00
Disconnected from Open E Cry. | 2014-08-02 15:13:00
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:13:00
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:13:03
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:13:03
The network socket is connected. | 2014-08-02 15:13:03
Starting SSL connection on the socket. | 2014-08-02 15:13:03
SSL socket is connected. | 2014-08-02 15:13:04
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:13:04
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:13:04
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:13:04
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:13:04
The SSL socket was shut down. | 2014-08-02 15:13:04
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:13:04
Socket has been shutdown and closed. | 2014-08-02 15:13:04
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:13:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:13:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:13:04
Disconnected from Open E Cry. | 2014-08-02 15:13:04
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:13:04
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:13:07
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:13:07
The network socket is connected. | 2014-08-02 15:13:07
Starting SSL connection on the socket. | 2014-08-02 15:13:07
SSL socket is connected. | 2014-08-02 15:13:08
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:13:08
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:13:08
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:13:08
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:13:08
The SSL socket was shut down. | 2014-08-02 15:13:08
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:13:08
Socket has been shutdown and closed. | 2014-08-02 15:13:08
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:13:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:13:08
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:13:08
Disconnected from Open E Cry. | 2014-08-02 15:13:08
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:13:08
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:13:11
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:13:11
The network socket is connected. | 2014-08-02 15:13:11
Starting SSL connection on the socket. | 2014-08-02 15:13:11
SSL socket is connected. | 2014-08-02 15:13:11
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:13:11
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:13:12
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:13:12
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:13:12
The SSL socket was shut down. | 2014-08-02 15:13:12
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:13:12
Socket has been shutdown and closed. | 2014-08-02 15:13:12
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:13:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:13:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:13:12
Disconnected from Open E Cry. | 2014-08-02 15:13:12
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:13:12
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:13:15
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:13:15
The network socket is connected. | 2014-08-02 15:13:15
Starting SSL connection on the socket. | 2014-08-02 15:13:15
SSL socket is connected. | 2014-08-02 15:13:15
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:13:15
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:13:15
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:13:15
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:13:15
The SSL socket was shut down. | 2014-08-02 15:13:15
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:13:15
Socket has been shutdown and closed. | 2014-08-02 15:13:15
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:13:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:13:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:13:15
Disconnected from Open E Cry. | 2014-08-02 15:13:15
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:13:15
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:13:18
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:13:18
The network socket is connected. | 2014-08-02 15:13:19
Starting SSL connection on the socket. | 2014-08-02 15:13:19
SSL socket is connected. | 2014-08-02 15:13:19
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:13:19
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:13:19
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:13:19
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:13:19
The SSL socket was shut down. | 2014-08-02 15:13:19
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:13:19
Socket has been shutdown and closed. | 2014-08-02 15:13:19
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:13:19
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:13:19
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:13:19
Disconnected from Open E Cry. | 2014-08-02 15:13:19
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:13:19
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:13:22
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:13:22
The network socket is connected. | 2014-08-02 15:13:23
Starting SSL connection on the socket. | 2014-08-02 15:13:23
SSL socket is connected. | 2014-08-02 15:13:23
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:13:23
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:13:23
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:13:23
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:13:23
The SSL socket was shut down. | 2014-08-02 15:13:23
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:13:23
Socket has been shutdown and closed. | 2014-08-02 15:13:23
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:13:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:13:23
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:13:23
Disconnected from Open E Cry. | 2014-08-02 15:13:23
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:13:23
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:13:26
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:13:26
The network socket is connected. | 2014-08-02 15:13:26
Starting SSL connection on the socket. | 2014-08-02 15:13:26
SSL socket is connected. | 2014-08-02 15:13:27
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:13:27
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:13:27
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:13:27
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:13:27
The SSL socket was shut down. | 2014-08-02 15:13:27
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:13:27
Socket has been shutdown and closed. | 2014-08-02 15:13:27
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:13:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:13:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:13:27
Disconnected from Open E Cry. | 2014-08-02 15:13:27
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:13:27
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:13:30
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:13:30
The network socket is connected. | 2014-08-02 15:13:31
Starting SSL connection on the socket. | 2014-08-02 15:13:31
SSL socket is connected. | 2014-08-02 15:13:31
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:13:31
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:13:31
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:13:31
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:13:31
The SSL socket was shut down. | 2014-08-02 15:13:31
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:13:31
Socket has been shutdown and closed. | 2014-08-02 15:13:31
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:13:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:13:31
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:13:31
Disconnected from Open E Cry. | 2014-08-02 15:13:31
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:13:31
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:13:34
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:13:35
The network socket is connected. | 2014-08-02 15:13:35
Starting SSL connection on the socket. | 2014-08-02 15:13:35
SSL socket is connected. | 2014-08-02 15:13:35
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:13:35
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:13:35
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:13:35
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:13:35
The SSL socket was shut down. | 2014-08-02 15:13:35
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:13:35
Socket has been shutdown and closed. | 2014-08-02 15:13:35
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:13:35
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:13:35
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:13:35
Disconnected from Open E Cry. | 2014-08-02 15:13:35
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:13:35
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:13:38
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:13:38
The network socket is connected. | 2014-08-02 15:13:39
Starting SSL connection on the socket. | 2014-08-02 15:13:39
SSL socket is connected. | 2014-08-02 15:13:39
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:13:39
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:13:39
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:13:39
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:13:39
The SSL socket was shut down. | 2014-08-02 15:13:39
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:13:39
Socket has been shutdown and closed. | 2014-08-02 15:13:39
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:13:39
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:13:39
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:13:39
Disconnected from Open E Cry. | 2014-08-02 15:13:39
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:13:39
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:13:42
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:13:42
The network socket is connected. | 2014-08-02 15:13:43
Starting SSL connection on the socket. | 2014-08-02 15:13:43
SSL socket is connected. | 2014-08-02 15:13:43
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:13:43
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:13:43
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:13:43
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:13:43
The SSL socket was shut down. | 2014-08-02 15:13:43
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:13:43
Socket has been shutdown and closed. | 2014-08-02 15:13:43
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:13:43
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:13:43
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:13:43
Disconnected from Open E Cry. | 2014-08-02 15:13:43
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:13:43
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:13:46
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:13:46
The network socket is connected. | 2014-08-02 15:13:46
Starting SSL connection on the socket. | 2014-08-02 15:13:46
SSL socket is connected. | 2014-08-02 15:13:47
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:13:47
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:13:47
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:13:47
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:13:47
The SSL socket was shut down. | 2014-08-02 15:13:47
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:13:47
Socket has been shutdown and closed. | 2014-08-02 15:13:47
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:13:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:13:47
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:13:47
Disconnected from Open E Cry. | 2014-08-02 15:13:47
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:13:47
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:13:50
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:13:50
The network socket is connected. | 2014-08-02 15:13:50
Starting SSL connection on the socket. | 2014-08-02 15:13:50
SSL socket is connected. | 2014-08-02 15:13:50
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:13:51
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:13:51
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:13:51
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:13:51
The SSL socket was shut down. | 2014-08-02 15:13:51
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:13:51
Socket has been shutdown and closed. | 2014-08-02 15:13:51
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:13:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:13:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:13:51
Disconnected from Open E Cry. | 2014-08-02 15:13:51
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:13:51
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-02 15:13:54
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-02 15:13:54
The network socket is connected. | 2014-08-02 15:13:54
Starting SSL connection on the socket. | 2014-08-02 15:13:54
SSL socket is connected. | 2014-08-02 15:13:54
OEC FIX Trading: Sending the Logon message. | 2014-08-02 15:13:54
OEC FIX Trading: Received a Logout message. | 2014-08-02 15:13:55
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-08-02 15:13:55
SSL shutdown indicates not able to send 'close notify'. | 2014-08-02 15:13:55
The SSL socket was shut down. | 2014-08-02 15:13:55
The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-02 15:13:55
Socket has been shutdown and closed. | 2014-08-02 15:13:55
OEC FIX Trading: Logged out and disconnected. | 2014-08-02 15:13:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-02 15:13:55
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-02 15:13:55
Disconnected from Open E Cry. | 2014-08-02 15:13:55
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-08-02 15:13:55
[2014-08-02 21:26:15]
The reason you cannot connect at this time is because it is a weekend.:
https://www.sierrachart.com/index.php?page=doc/openecry.php#ServerAvailability
For other reasons you cannot connect at any other time, refer to this section here:
https://www.sierrachart.com/index.php?page=doc/openecry.php#OECConnectionProblem
Please be aware that you are connecting to a server that we do not control. It is an OEC server. You need to rely upon OEC for connection problems. We can only indicate what we believe the problem is but generally we cannot solve it.
