Date/Time: Mon, 25 Nov 2024 22:45:28 +0000
Time Setting
View Count: 133
[2024-01-25 20:22:38]
User509566 - Posts: 1
I went to Global Settings - Time Zone Settings, and was unable to change my Siera Chart time to EST. What do I need to do?
[2024-01-25 21:50:25]
John - SC Support - Posts: 36285
What exactly is not working? Were not able to select the time zone you wanted in the Global Time Zone Settings? If not, what happened?
If you have a particular chart that has not changed to the Global Time Zone setting, then that would be because that chart is set to use a specific time zone and not the Global Time Zone. If you want it to use the Global Time Zone then change the setting for "Chart >> Chart Settings >> Session Time >> Time Zone" to "Use Global Time Zone". Refer to the following:
Chart Settings: Time Zone (List) (Chart >> Chart Settings >> Session Times menu)
