Date/Time: Mon, 25 Nov 2024 22:21:10 +0000
tick charts
View Count: 441
[2024-01-19 16:26:25]
User565747 - Posts: 16
is it possible to have a tick chart i use on tos a 2000tick , wondering if sierra also has tat withing a footprint
[2024-01-19 17:48:25]
John - SC Support - Posts: 36283
Yes, you can do this. Refer to the following:
Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Number of Trades Per Bar (Chart >> Chart Settings menu)
[2024-01-21 05:07:03]
do i need to change time zone settings if i lived in los angeles ?? i notice that the start time on session when it shows the black background starts at 930am , wick in my time 3 hours already past since market open
[2024-01-22 15:05:03]
It is your choice on what Time Zone and Session Times you use. Just keep in mind that the Start Time for your Session Times is going to determine the bar times.
If you live in Los Angeles and have your Time Zone set to Pacific US Time and you are trading the CME Group (which is in Chicago), then you would want to have your Session Start Time set to the starting time of the market in your time zone, which would be 06:30 (08:30 Central US Time).
Time Zone Setting
Chart Session Times
[2024-01-22 15:46:09]
ok so what will happen if i just leave it at global time zone
[2024-01-22 17:45:14]
When a chart is set to "Use Global Time Zone", then it is going to use whatever the "Global Time Zone" is set to. That option is set through "Global Settings >> Time Zone".
Therefore, you would need to look at how you have that Global Time Zone set to determine what you want to do.
We recommend setting the "Global Time Zone" to the time zone you want to use for most, if not all, of your charts and then only changing the individual charts time zone for specific reasons. You would then set your Session Times based on the Global Time Zone setting.
[2024-01-25 05:55:22]
so i was customizing my footprint chart and dom, i was able to finished all my dom is working fine but the footprint chart it got stuck on my screen it doesnt move at all , can this be fixed?
[2024-01-25 16:05:53]
Start by reviewing the information at the following link:
