Date/Time: Tue, 26 Nov 2024 00:18:37 +0000
Lot of disconnects... Any ideas?
View Count: 258
[2024-01-18 17:21:12]
esMike - Posts: 69
I get a lot of disconnects. Dunno why. Sometimes only like 3-5 disconnects per day, but today it's horrible.
My VDSL is stable, no Fec errors or OH frame errors or anything showing up.
Anyone got any ideas?
Teton CME Order Routing | Firm: AMP | 2024-01-18 12:14:12.712
Teton CME Order Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 | 2024-01-18 12:14:12.712
Error getting address info for ds23.sierracharts.com. Windows error code 11001: No such host is known. | 2024-01-18 12:14:19.753 *
DTC Client socket (3) | CloseSocket call. | 2024-01-18 12:14:19.753
Denali Data Feed | Failed connections: 1 | 2024-01-18 12:14:19.753
DTC Client socket (0) | CloseSocket call. | 2024-01-18 12:14:19.753
Denali Data Feed | Disconnected from the server. | 2024-01-18 12:14:19.753
Denali Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-01-18 12:14:19.753
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2024-01-18 12:14:19.753
DTC Client socket (1) | New receive buffer size: 0 | 2024-01-18 12:14:19.753
DTC Client socket (1) | Connecting to IP: 208.185.224.130. | 2024-01-18 12:14:19.753
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2024-01-18 12:14:20.342 *
Denali Data Feed | Connecting to the server ds13.sierracharts.com. Port 10048 | 2024-01-18 12:14:21.741
DTC Client socket (2) | Creating socket. | 2024-01-18 12:14:21.742
DTC Client socket (2) | New receive buffer size: 0 | 2024-01-18 12:14:21.742
DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2024-01-18 12:14:21.742
DTC Client socket (1) | Connect event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2024-01-18 12:14:26.046 *
DTC Client socket (2) | Connect event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2024-01-18 12:14:26.046 *
DTC Client socket (1) | CloseSocket call. | 2024-01-18 12:14:26.046
DTC Client socket (2) | CloseSocket call. | 2024-01-18 12:14:26.046
DTC Client socket (1) | Closed. | 2024-01-18 12:14:26.046
Teton CME Order Routing | Failed connections: 2 | 2024-01-18 12:14:26.046
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2024-01-18 12:14:26.046
Select 'File >> Disconnect' to prevent further connection attempts. | 2024-01-18 12:14:26.046
Denali Data Feed | Failed connections: 2 | 2024-01-18 12:14:26.046
DTC Client socket (0) | CloseSocket call. | 2024-01-18 12:14:26.046
Denali Data Feed | Disconnected from the server. | 2024-01-18 12:14:26.046
DTC Client socket (2) | Closed. | 2024-01-18 12:14:26.046
Denali Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-01-18 12:14:26.046
DTC Client socket (0) | CloseSocket call. | 2024-01-18 12:14:26.054
Teton CME Order Routing | Disconnected. | 2024-01-18 12:14:26.054
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2024-01-18 12:14:26.054
Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443 | 2024-01-18 12:14:28.039
Teton CME Order Routing | Firm: AMP | 2024-01-18 12:14:28.054
Teton CME Order Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 | 2024-01-18 12:14:28.054
DTC Client socket (1) | Using previously cached IP address because unable to resolve domain name | 2024-01-18 12:14:40.078
DTC Client socket (1) | Creating socket. | 2024-01-18 12:14:40.078
DTC Client socket (1) | New receive buffer size: 0 | 2024-01-18 12:14:40.078
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-01-18 12:14:40.078
Denali Data Feed | Network connection to server complete. | 2024-01-18 12:14:40.252
Denali Data Feed | Starting socket receive thread. | 2024-01-18 12:14:40.252
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-01-18 12:14:40.252
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2024-01-18 12:14:40.253
DTC Client socket (2) | New receive buffer size: 0 | 2024-01-18 12:14:40.253
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2024-01-18 12:14:40.253
Teton CME Order Routing | Network connection to server complete. | 2024-01-18 12:14:40.481
Teton CME Order Routing | Starting socket receive thread. | 2024-01-18 12:14:40.481
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2024-01-18 12:14:40.481
Denali Data Feed | Setting DTC encoding to Binary VLS | 2024-01-18 12:14:40.557
Denali Data Feed | Sending logon request message. | 2024-01-18 12:14:40.557
Denali Data Feed | Received logon response. | 2024-01-18 12:14:40.791
Denali Data Feed | Server Name: RealTimeServer. | 2024-01-18 12:14:40.791
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-01-18 12:14:40.791
Denali Data Feed | Logon error received from server: Maximum connections reached. | 2024-01-18 12:14:40.791
Denali Data Feed | Failed connections: 3 | 2024-01-18 12:14:40.791
Denali Data Feed | Waiting for socket receive thread to end | 2024-01-18 12:14:40.791
DTC Client socket (1) | CloseSocket call. | 2024-01-18 12:14:40.791
Denali Data Feed | Disconnected from the server. | 2024-01-18 12:14:40.791
Denali Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-01-18 12:14:40.791
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-01-18 12:14:40.791
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-01-18 12:14:40.845
DTC Client socket (1) | Closed. | 2024-01-18 12:14:40.845
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2024-01-18 12:14:41.158
Teton CME Order Routing | Sending logon request message. | 2024-01-18 12:14:41.158
Teton CME Order Routing | Received logon response. | 2024-01-18 12:14:41.382
Teton CME Order Routing | Server Name: SC DTC Server. | 2024-01-18 12:14:41.382
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2024-01-18 12:14:41.382
Teton CME Order Routing | Logon error received from server: Secondary instance is not allowing connections to this server | 2024-01-18 12:14:41.382
Teton CME Order Routing | Failed connections: 3 | 2024-01-18 12:14:41.382
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2024-01-18 12:14:41.382
Select 'File >> Disconnect' to prevent further connection attempts. | 2024-01-18 12:14:41.382
Teton CME Order Routing | Waiting for socket receive thread to end | 2024-01-18 12:14:41.400
DTC Client socket (2) | CloseSocket call. | 2024-01-18 12:14:41.400
Teton CME Order Routing | Disconnected. | 2024-01-18 12:14:41.400
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2024-01-18 12:14:41.400
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2024-01-18 12:14:41.400
DTC Client socket (2) | Socket gracefully closed by remote side. | 2024-01-18 12:14:41.622
DTC Client socket (2) | Closed. | 2024-01-18 12:14:41.622
Denali Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 443 | 2024-01-18 12:14:42.791
DTC Client socket (1) | Creating socket. | 2024-01-18 12:14:42.965
DTC Client socket (1) | New receive buffer size: 0 | 2024-01-18 12:14:42.965
DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2024-01-18 12:14:42.965
Denali Data Feed | Network connection to server complete. | 2024-01-18 12:14:43.140
Denali Data Feed | Starting socket receive thread. | 2024-01-18 12:14:43.140
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-01-18 12:14:43.140
Teton CME Order Routing | Firm: AMP | 2024-01-18 12:14:43.398
Teton CME Order Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 | 2024-01-18 12:14:43.398
Denali Data Feed | Setting DTC encoding to Binary VLS | 2024-01-18 12:14:43.444
Denali Data Feed | Sending logon request message. | 2024-01-18 12:14:43.444
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2024-01-18 12:14:43.573
DTC Client socket (2) | New receive buffer size: 0 | 2024-01-18 12:14:43.573
DTC Client socket (2) | Connecting to IP: 38.89.227.130. | 2024-01-18 12:14:43.573
Teton CME Order Routing | Network connection to server complete. | 2024-01-18 12:14:43.804
Teton CME Order Routing | Starting socket receive thread. | 2024-01-18 12:14:43.804
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2024-01-18 12:14:43.804
Denali Data Feed | Received logon response. | 2024-01-18 12:14:44.194
Denali Data Feed | Server Name: SC Realtime Server. | 2024-01-18 12:14:44.194
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-01-18 12:14:44.194
Denali Data Feed | Successfully connected. | 2024-01-18 12:14:44.194
Denali Data Feed | Trading is not supported. | 2024-01-18 12:14:44.194
Denali Data Feed | Restarting real-time data updates for symbol: ESH24_FUT_CME -> ESH24 | 2024-01-18 12:14:44.194
Denali Data Feed | Restarting real-time data updates for symbol: MESH24_FUT_CME -> MESH24 | 2024-01-18 12:14:44.194
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2024-01-18 12:14:44.503
Teton CME Order Routing | Sending logon request message. | 2024-01-18 12:14:44.503
Denali Data Feed | Received security definition for symbol ESH24_FUT_CME | 2024-01-18 12:14:44.507
Denali Data Feed | Received security definition for symbol MESH24_FUT_CME | 2024-01-18 12:14:44.507
Teton CME Order Routing | Received logon response. | 2024-01-18 12:14:44.968
Teton CME Order Routing | Server Name: SC DTC Server. Build=48599. | 2024-01-18 12:14:44.968
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2024-01-18 12:14:44.968
Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2024-01-18 12:14:44.968
Teton CME Order Routing | Trading is supported. | 2024-01-18 12:14:44.968
Teton CME Order Routing | Order cancel and replace is supported. | 2024-01-18 12:14:44.968
Teton CME Order Routing | OCO Orders supported. | 2024-01-18 12:14:44.968
Teton CME Order Routing | Bracket Orders supported. | 2024-01-18 12:14:44.968
Teton CME Order Routing | Connected to server complete. | 2024-01-18 12:14:44.968
Denali Data Feed | Waiting for socket receive thread to end | 2024-01-18 12:14:44.968
DTC Client socket (1) | CloseSocket call. | 2024-01-18 12:14:44.969
Denali Data Feed | Disconnected from the server. | 2024-01-18 12:14:44.969
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-01-18 12:14:44.969
No download requests in the queue to start downloads for. | 2024-01-18 12:14:44.969
Updated verified funded futures trading account ending date to: 2024-02-17 17:14:44 | 2024-01-18 12:14:44.969
Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2024-01-18 12:14:44.970
Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2024-01-16 16:28:12.736533 | 2024-01-18 12:14:44.973
Mapping MESH24_FUT_CME to MESH24. Service code: cme | 2024-01-18 12:14:44.993
Using symbol data fast lookup vector | 2024-01-18 12:14:44.993
Denali Data Feed | Starting real-time market data updates for: MESH24_FUT_CME (MESH24). ID: 1 Service code: cme | 2024-01-18 12:14:44.993
Denali Data Feed | Connecting to the server ds27.sierracharts.com. Port 10048 | 2024-01-18 12:14:44.993
Denali Data Feed | Requesting security definition data for: MESH24_FUT_CME (MESH24). ID: 1 | 2024-01-18 12:14:44.993
Mapping ESH24_FUT_CME to ESH24. Service code: cme | 2024-01-18 12:14:44.993
Denali Data Feed | Starting real-time market data updates for: ESH24_FUT_CME (ESH24). ID: 2 Service code: cme | 2024-01-18 12:14:44.993
Denali Data Feed | Requesting security definition data for: ESH24_FUT_CME (ESH24). ID: 2 | 2024-01-18 12:14:44.993
Added historical Intraday data request for ESH24_FUT_CME to the queue. | 2024-01-18 12:14:44.993
Intraday data recording state for symbol ESH24_FUT_CME is set to download 'Pending'. | 2024-01-18 12:14:44.993
Triggering next historical data download in queue. | 2024-01-18 12:14:44.993
Delaying start of download for ESH24_FUT_CME. | 2024-01-18 12:14:45.000
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-01-18 12:14:45.148
DTC Client socket (1) | Closed. | 2024-01-18 12:14:45.148
DTC Client socket (3) | Creating socket. | 2024-01-18 12:14:45.168
DTC Client socket (3) | New receive buffer size: 0 | 2024-01-18 12:14:45.168
DTC Client socket (3) | Connecting to IP: 38.89.227.130. | 2024-01-18 12:14:45.168
Updated verified funded futures trading account ending date to: 2024-02-17 17:14:45 | 2024-01-18 12:14:45.206
Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=156139 | 2024-01-18 12:14:45.210
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESH24_FUT_CME | 2024-01-18 12:14:45.227
Teton CME Order Routing | Received security definition for symbol MESH24_FUT_CME | 2024-01-18 12:14:45.227
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH24_FUT_CME | 2024-01-18 12:14:45.227
Teton CME Order Routing | Received security definition for symbol ESH24_FUT_CME | 2024-01-18 12:14:45.227
Denali Data Feed | Network connection to server complete. | 2024-01-18 12:14:45.400
Denali Data Feed | Starting socket receive thread. | 2024-01-18 12:14:45.400
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-01-18 12:14:45.401
Denali Data Feed | Setting DTC encoding to Binary VLS | 2024-01-18 12:14:45.663
Denali Data Feed | Sending logon request message. | 2024-01-18 12:14:45.663
Denali Data Feed | Received logon response. | 2024-01-18 12:14:45.898
Denali Data Feed | Server Name: RealTimeServer. | 2024-01-18 12:14:45.898
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-01-18 12:14:45.898
Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-01-18 12:14:45.898
Denali Data Feed | Failed connections: 1 | 2024-01-18 12:14:45.898
Denali Data Feed | Waiting for socket receive thread to end | 2024-01-18 12:14:45.898
DTC Client socket (3) | CloseSocket call. | 2024-01-18 12:14:45.898
Denali Data Feed | Disconnected from the server. | 2024-01-18 12:14:45.898
Denali Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-01-18 12:14:45.898
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2024-01-18 12:14:45.898
DTC Client socket (3) | Socket gracefully closed by remote side. | 2024-01-18 12:14:46.128
DTC Client socket (3) | Closed. | 2024-01-18 12:14:46.128
Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048 | 2024-01-18 12:14:47.898
DTC Client socket (1) | Creating socket. | 2024-01-18 12:14:48.073
DTC Client socket (1) | New receive buffer size: 0 | 2024-01-18 12:14:48.073
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-01-18 12:14:48.073
Denali Data Feed | Network connection to server complete. | 2024-01-18 12:14:48.306
Denali Data Feed | Starting socket receive thread. | 2024-01-18 12:14:48.306
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-01-18 12:14:48.306
Denali Data Feed | Setting DTC encoding to Binary VLS | 2024-01-18 12:14:48.548
Denali Data Feed | Sending logon request message. | 2024-01-18 12:14:48.548
Denali Data Feed | Received logon response. | 2024-01-18 12:14:48.781
Denali Data Feed | Server Name: RealTimeServer. | 2024-01-18 12:14:48.781
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-01-18 12:14:48.781
Denali Data Feed | Logon error received from server: Maximum connections reached. | 2024-01-18 12:14:48.781
Denali Data Feed | Failed connections: 2 | 2024-01-18 12:14:48.781
Denali Data Feed | Waiting for socket receive thread to end | 2024-01-18 12:14:48.781
DTC Client socket (1) | CloseSocket call. | 2024-01-18 12:14:48.781
Denali Data Feed | Disconnected from the server. | 2024-01-18 12:14:48.781
Denali Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-01-18 12:14:48.781
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-01-18 12:14:48.781
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-01-18 12:14:49.008
DTC Client socket (1) | Closed. | 2024-01-18 12:14:49.008
Denali Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 443 | 2024-01-18 12:14:50.775
DTC Client socket (1) | Creating socket. | 2024-01-18 12:14:50.949
DTC Client socket (1) | New receive buffer size: 0 | 2024-01-18 12:14:50.949
DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2024-01-18 12:14:50.949
Denali Data Feed | Network connection to server complete. | 2024-01-18 12:14:51.128
Denali Data Feed | Starting socket receive thread. | 2024-01-18 12:14:51.128
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-01-18 12:14:51.128
Denali Data Feed | Setting DTC encoding to Binary VLS | 2024-01-18 12:14:51.433
Denali Data Feed | Sending logon request message. | 2024-01-18 12:14:51.433
Denali Data Feed | Received logon response. | 2024-01-18 12:14:51.671
Denali Data Feed | Server Name: RealTimeServer. | 2024-01-18 12:14:51.671
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-01-18 12:14:51.671
Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-01-18 12:14:51.671
Denali Data Feed | Failed connections: 3 | 2024-01-18 12:14:51.671
Denali Data Feed | Waiting for socket receive thread to end | 2024-01-18 12:14:51.671
DTC Client socket (1) | CloseSocket call. | 2024-01-18 12:14:51.672
Denali Data Feed | Disconnected from the server. | 2024-01-18 12:14:51.672
Denali Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2024-01-18 12:14:51.672
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-01-18 12:14:51.672
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-01-18 12:14:51.725
DTC Client socket (1) | Closed. | 2024-01-18 12:14:51.725
Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 443 | 2024-01-18 12:14:53.667
DTC Client socket (1) | Creating socket. | 2024-01-18 12:14:53.845
DTC Client socket (1) | New receive buffer size: 0 | 2024-01-18 12:14:53.845
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-01-18 12:14:53.845
Denali Data Feed | Network connection to server complete. | 2024-01-18 12:14:54.024
Denali Data Feed | Starting socket receive thread. | 2024-01-18 12:14:54.024
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2024-01-18 12:14:54.024
Denali Data Feed | Setting DTC encoding to Binary VLS | 2024-01-18 12:14:54.317
Denali Data Feed | Sending logon request message. | 2024-01-18 12:14:54.317
Denali Data Feed | Received logon response. | 2024-01-18 12:14:55.036
Denali Data Feed | Server Name: SC Realtime Server. | 2024-01-18 12:14:55.036
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2024-01-18 12:14:55.036
Denali Data Feed | Successfully connected. | 2024-01-18 12:14:55.036
[2024-01-18 17:25:19]
esMike - Posts: 69
This might give a hint... Whenever I compile studies, either through local C++ or remote. That definitely always triggers a disconnect shortly later.
[2024-01-18 21:43:45]
John - SC Support - Posts: 36286
Are you running Sierra Chart from multiple installations on one computer, or are you running from more than one computer at the same time?
[2024-01-19 05:12:33]
esMike - Posts: 69
Just one sierra on one PC.
[2024-01-19 05:33:34]
esMike - Posts: 69
Most my disconnects are 53 and 10060 errors. Just after 10053 disconnect usually get a 10060.
2024-01-19 00:32:06.249 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine.
[2024-01-19 06:20:09]
Sierra_Chart Engineering - Posts: 17178
You really need to check your Internet connectivity. This is very clearly an Internet connectivity issue. It is not something we have any control over ourselves.
For more information, refer to this help topic:
Data/Trading Service Connection and Symbol Issues
