Date/Time: Tue, 26 Nov 2024 00:21:24 +0000
E mimi S&P 500 to Micro
View Count: 467
[2024-01-18 11:34:48] |
johnsierra - Posts: 4 |
Hi I would like to trade Micro E mini S&P500 contracts on the E mini S&Pcontract chart so Under Symbol settings performed I did the following please see screen shots Price display format list I get a drop-down menu and have selected 0.00001 Tick size does not show me a drop-down... So I put that in manually?0.000050 Value per tick does not give me a drop-down..So I put that in manually? $6.25 I have completed the above then pressed Ok, my VWAP chart started to load and once complet was not showing curent day also the cross hairs cursor seem to cover the price/time Please could you advice Best wishers John https://www.sierrachart.com/image.php?Image=1705577269651.png |
[2024-01-18 16:28:45] |
John - SC Support - Posts: 36286 |
There is no reason to change the Tick Size or the Price Display Format, as both the E-Mini S&P 500 (ES) and the Micro E-Mini S&P 500 (MES) have the same settings (.25 Tick Size, therefore a Price Display format of 0.01). The Currency Value per Tick does need to be changed to the value of the symbol you have set in the "Trade and Current Quote Symbol", so entering $6.25 is correct for this item. Please change the above and reload your chart and let us know if you are still having an issue. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-18 17:26:49] |
Thanks so much for the info the chart is working great However the crosshair cursor does not show up [ie with the big cross] only makes price and time stamps disappear please could you advice Best wishers John https://www.sierrachart.com/image.php?Image=1705598676501.png |
[2024-01-18 21:45:55] |
Your crosshairs color is set to White, which is the same as the background. There was a change in recent releases to not change the color if they are same. You will need to change the colors for the following items in the Graphics Settings to what you want them to be: - Chart Values: Color of the Price and Time Boxes - Chart Values: Crosshair For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
