Date/Time: Tue, 26 Nov 2024 00:32:56 +0000
simulation mode not working
View Count: 215
[2024-01-17 14:45:11] |
kevveg - Posts: 4 |
i make my account for paper trade (simulation) but can't papper trade this is the window that opens when when i place my trades. help me please Trading Evaluator - Delayed | Received 0 historical account balance updates for account: kevinn. Inserting. | 2024-01-17 14:27:01.471 Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 | 2024-01-17 14:27:01.830 Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 | 2024-01-17 14:27:01.830 Trading Evaluator - Delayed | Requesting Trade Positions data. | 2024-01-17 14:27:11.130 TradeActivity files query time: 0.002974 seconds. Entries: 0. Current queries: 1 | 2024-01-17 14:27:47.467 TradeActivity files query time: 0.000209 seconds. Entries: 0. Current queries: 1 | 2024-01-17 14:27:55.053 TradeActivity files query time: 0.000210 seconds. Entries: 0. Current queries: 1 | 2024-01-17 14:28:10.457 TradeActivity files query time: 0.000208 seconds. Entries: 0. Current queries: 1 | 2024-01-17 14:28:25.392 TradeActivity files query time: 0.000215 seconds. Entries: 0. Current queries: 1 | 2024-01-17 14:28:34.570 TradeActivity files query time: 0.000216 seconds. Entries: 0. Current queries: 1 | 2024-01-17 14:29:12.412 TradeActivity files query time: 0.000247 seconds. Entries: 0. Current queries: 1 | 2024-01-17 14:29:19.484 Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 | 2024-01-17 14:29:25.832 Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 | 2024-01-17 14:29:25.832 TradeActivity files query time: 0.000217 seconds. Entries: 0. Current queries: 1 | 2024-01-17 14:29:26.046 Trading Evaluator - Delayed (Order reject). Info: Trade Order Error - Insufficient Account Value (NLV) for margin for order. Margin needed for symbol: 1947.00 USD. MarginPercent: 100%. Margin needed for Account: 1947.00. Account Value: 500.00. Max potential quantity: 1. Minimum required NLV: 50.00. Text: Parent order. Tag: 2TargetsWithCommonStop.twconfig. Internal Order ID: 133. Service Order ID: 2439524. Symbol: MNQH24. Account: kevinn | 2024-01-17 14:30:24.488 * Trading Evaluator - Delayed (Order reject). Info: Trade Order Error - Insufficient Account Value (NLV) for margin for order. Margin needed for symbol: 1947.00 USD. MarginPercent: 100%. Margin needed for Account: 1947.00. Account Value: 500.00. Max potential quantity: 1. Minimum required NLV: 50.00. Text: Parent order. Tag: 2TargetsWithCommonStop.twconfig. Internal Order ID: 136. Service Order ID: 2439527. Symbol: MNQH24. Account: kevinn | 2024-01-17 14:30:24.804 * Trading Evaluator - Delayed (Order reject). Info: Trade Order Error - Insufficient Account Value (NLV) for margin for order. Margin needed for symbol: 1947.00 USD. MarginPercent: 100%. Margin needed for Account: 1947.00. Account Value: 500.00. Max potential quantity: 1. Minimum required NLV: 50.00. Text: Parent order. Tag: 2TargetsWithCommonStop.twconfig. Internal Order ID: 139. Service Order ID: 2439530. Symbol: MNQH24. Account: kevinn | 2024-01-17 14:34:43.923 * Trading Evaluator - Delayed (Order reject). Info: Trade Order Error - Insufficient Account Value (NLV) for margin for order. Margin needed for symbol: 1947.00 USD. MarginPercent: 100%. Margin needed for Account: 1947.00. Account Value: 500.00. Max potential quantity: 1. Minimum required NLV: 50.00. Text: Parent order. Tag: 2TargetsWithCommonStop.twconfig. Internal Order ID: 142. Service Order ID: 2439533. Symbol: MNQH24. Account: kevinn | 2024-01-17 14:34:44.175 * Date Time Of Last Edit: 2024-01-17 18:14:58
[2024-01-17 15:12:32] |
kevveg - Posts: 4 |
also i click on (Trade Simulation Mode On) but i see is not checked. why is not letting me to checked it. this is the info you have for (how to setup simulation mode) To use the trade simulation feature, simply select Trade >> Trade Simulation Mode On on the menu and make sure it is checked. If trade simulation mode is active, then there will be a check mark by this menu command. If it is not active, then there will not be a check mark by this menu command. |
[2024-01-17 17:46:31] |
John - SC Support - Posts: 36286 |
You are connected to the "Trading Evaluator - Delayed". And the reason you are not able to place any trades with that service is that your account value is set to $500.00 and your Margin Requirement is 100%, therefore you would need an account value of $1947.00 in order to place the trade you are wanting to make. You need to either adjust your balance or your margin percentage. With regards to Trade Simulation Mode, since you are connected to the Trading Evalautor - Delayed, which is a simulation environment, you are not able to turn on Simulation Mode. If you want to work with the built-in Simulation Mode, then you should not be connecting to the Trading Evaluator - rather you should set your service to "SC Data - All Services". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-17 20:47:39] |
Sierra_Chart Engineering - Posts: 17178 |
Refer to:Simulated Futures Trading Service: Account Balance Adjustments And also refer to: Simulated Futures Trading Service: Using Internal Sierra Chart Trade Simulation Mode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
