Date/Time: Tue, 26 Nov 2024 00:53:16 +0000
Cannot connect to prop firm
View Count: 294
[2024-01-17 12:53:59] |
User299985 - Posts: 6 |
Hi all, unfortunately I am not able to connect to prop firm "the trading pit" through Rithmic data feed, connection to account works (green status), but data feed is not coming in. Even when trying to use Denali data feed (and I dont have more than 3 connections up and running) its not working. I tried to use a DTS server, but then I dont have a trading connection anymore, no connection to the prop-account. Please could you help me? Christian |
[2024-01-17 15:30:14] |
Sierra_Chart Engineering - Posts: 17178 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-17 21:05:55] |
Thank you! The symbol is: MCLG4.NYMEX In the following the message log: 2024-01-17 21:01:37.349 | Software version: 2586 64-bit 2024-01-17 21:01:37.349 | Primary Thread ID: 8796 2024-01-17 21:01:37.349 | Usage end date: 2024-02-15 2024-01-17 21:01:37.349 | Enabled for: Sierra Chart Historical Data Service. 2024-01-17 21:01:37.349 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-01-17 21:01:37.349 | Enabled for: Delayed Denali Exchange Data Feed. 2024-01-17 21:01:37.349 | Enabled for exchange2: CME (Trading Account Required) 2024-01-17 21:01:37.349 | Enabled for exchange2: CBOT (Trading Account Required) 2024-01-17 21:01:37.349 | Enabled for exchange2: COMEX (Trading Account Required) 2024-01-17 21:01:37.349 | Enabled for exchange2: NYMEX (Trading Account Required) 2024-01-17 21:01:37.349 | Allow Support for Sierra Chart Data Feeds is disabled. 2024-01-17 21:01:37.349 | Current selected Data/Trading service: Rithmic Direct - DTC 2024-01-17 21:01:37.349 | Custom symbol settings values: enabled 2024-01-17 21:01:37.349 | Chart Update Interval: 500 2024-01-17 21:01:37.349 | Intraday Data Storage Time Unit: 1 2024-01-17 21:01:37.349 | Time Zone: +00:00:00 (UTC+00) 2024-01-17 21:01:37.349 | 2024-01-17 21:01:37 Local computer time in UTC 2024-01-17 21:01:37.349 | 2024-01-17 21:01:37 Local computer time in SC Time Zone 2024-01-17 21:01:37.349 | 2024-01-17 20:55:02 Server time in UTC 2024-01-17 21:01:37.349 | Local computer UTC time and Server UTC time difference: 0 seconds. 2024-01-17 21:01:37.349 | Program path: C:\SierrachartPit\ 2024-01-17 21:01:37.349 | Data Files path: C:\SierrachartPit\Data\ 2024-01-17 21:01:37.351 | OS Version Number: 10.0 2024-01-17 21:01:37.351 | Locale Setting: C 2024-01-17 21:01:37.353 | DLLs: sst_FreeBundle_64.dll, SST_LocalCopier_64.dll, UserContributedStudies_64.dll 2024-01-17 21:01:37.353 | Allowed protected custom studies: SST_FreeBundle, SST_LocalCopier 2024-01-17 21:01:37.353 | Crash reporter started: true 2024-01-17 21:01:37.353 | 2024-01-17 21:02:18.712 | MCLG4.NYMEX 1 Min #1 | Reloading chart. 2024-01-17 21:02:56.714 | File >> Disconnect selected. 2024-01-17 21:02:56.715 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-01-17 21:02:56.716 | DTC Client socket (1) | CloseSocket call. 2024-01-17 21:02:56.717 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-01-17 21:02:56.717 | Denali Data Feed | Waiting for socket receive thread to end 2024-01-17 21:02:56.718 | DTC Client socket (2) | CloseSocket call. 2024-01-17 21:02:56.718 | Denali Data Feed | Disconnected from the server. 2024-01-17 21:02:56.718 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-01-17 21:02:56.720 | Rithmic Direct - DTC | Disconnected. 2024-01-17 21:02:56.733 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-01-17 21:02:56.733 | DTC Client socket (1) | Closed. 2024-01-17 21:02:56.834 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-01-17 21:02:56.835 | DTC Client socket (2) | Closed. 2024-01-17 21:02:59.784 | 2024-01-17 21:02:59.785 | Rithmic Direct - DTC | Using server connection: TheTradingPit-Frankfurt-Aggregated 2024-01-17 21:02:59.788 | Rithmic Direct - DTC | Connecting to the server rsc-de.rithmic.com. Port 40844 2024-01-17 21:02:59.796 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-01-17 21:02:59.797 | DTC Client socket (1) | New receive buffer size: 0 2024-01-17 21:02:59.797 | DTC Client socket (1) | Connecting to IP: 184.104.190.18. 2024-01-17 21:02:59.825 | Rithmic Direct - DTC | Network connection to server complete. 2024-01-17 21:02:59.825 | Rithmic Direct - DTC | Starting socket receive thread. 2024-01-17 21:02:59.825 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-01-17 21:02:59.825 | Rithmic Direct - DTC | Sending logon request message. 2024-01-17 21:02:59.874 | Rithmic Direct - DTC | Received logon response. 2024-01-17 21:02:59.874 | Rithmic Direct - DTC | Server Name: . 2024-01-17 21:02:59.874 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-01-17 21:02:59.874 | Rithmic Direct - DTC | Successfully connected. 2024-01-17 21:02:59.874 | Rithmic Direct - DTC | Trading is supported. 2024-01-17 21:02:59.874 | Rithmic Direct - DTC | Order cancel and replace is supported. 2024-01-17 21:02:59.874 | Rithmic Direct - DTC | OCO Orders supported. 2024-01-17 21:02:59.874 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2024-01-17 21:02:59.874 | Rithmic Direct - DTC | Connected to server complete. 2024-01-17 21:02:59.876 | No download requests in the queue to start downloads for. 2024-01-17 21:02:59.876 | No download requests in the queue to start downloads for. 2024-01-17 21:02:59.876 | No download requests in the queue to start downloads for. 2024-01-17 21:02:59.876 | No download requests in the queue to start downloads for. 2024-01-17 21:03:00.337 | Using symbol data fast lookup vector 2024-01-17 21:03:00.337 | Rithmic Direct - DTC | Starting real-time market data updates for: MCLG4.NYMEX. ID: 1 Service code: rithmic.trading 2024-01-17 21:03:00.342 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-de.rithmic.com. Port 40847 2024-01-17 21:03:00.345 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2024-01-17 21:03:00.345 | DTC Client socket (2) | New receive buffer size: 0 2024-01-17 21:03:00.345 | DTC Client socket (2) | Connecting to IP: 184.104.190.18. 2024-01-17 21:03:00.347 | Rithmic Direct - DTC | Requesting security definition data for: MCLG4.NYMEX. ID: 1 2024-01-17 21:03:00.347 | Rithmic Direct - DTC | Using primary service for historical data for MCLG4.NYMEX 2024-01-17 21:03:00.348 | Starting DelayedDownloadMonitoringTimer 2024-01-17 21:03:00.348 | Starting HDTimeoutTimer 2024-01-17 21:03:00.348 | Historical data service client indicated that downloads are not enabled. Symbol: MCLG4.NYMEX. Data Type: Intraday data. 2024-01-17 21:03:00.348 | Historical data download ID 2 not found when removing ID from outstanding request set. 2024-01-17 21:03:00.348 | Real-time Intraday chart data file updates started for MCLG4.NYMEX 2024-01-17 21:03:00.349 | Opened cached Intraday file: C:\SierrachartPit\Data\MCLG4.NYMEX.scid. Thread ID: 8796 2024-01-17 21:03:00.349 | Intraday chart data file opened for MCLG4.NYMEX 2024-01-17 21:03:00.370 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-01-17 21:03:00.370 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-01-17 21:03:00.370 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-01-17 21:03:00.370 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-01-17 21:03:00.410 | Rithmic Direct - DTC (Data) | Received logon response. 2024-01-17 21:03:00.410 | Rithmic Direct - DTC (Data) | Server Name: . 2024-01-17 21:03:00.410 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-01-17 21:03:00.410 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-01-17 21:03:00.410 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-01-17 21:03:00.410 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-01-17 21:03:00.410 | Rithmic Direct - DTC | Using primary service for historical data for MCLG4.NYMEX 2024-01-17 21:03:00.410 | Historical data service client indicated that downloads are not enabled. Symbol: MCLG4.NYMEX. Data Type: Intraday data. 2024-01-17 21:03:00.410 | Historical data download ID 3 not found when removing ID from outstanding request set. 2024-01-17 21:03:00.410 | Real-time Intraday chart data file updates started for MCLG4.NYMEX 2024-01-17 21:03:00.410 | Opened cached Intraday file: C:\SierrachartPit\Data\MCLG4.NYMEX.scid. Thread ID: 8796 2024-01-17 21:03:00.410 | Intraday chart data file opened for MCLG4.NYMEX 2024-01-17 21:03:00.411 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLG4.NYMEX 2024-01-17 21:03:00.528 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLG4.NYMEX 2024-01-17 21:03:10.342 | Rithmic Direct - DTC | Starting real-time market data updates for: MCLH4.NYMEX. ID: 2 Service code: rithmic.trading 2024-01-17 21:03:10.342 | Rithmic Direct - DTC | Requesting security definition data for: MCLH4.NYMEX. ID: 2 2024-01-17 21:03:19.796 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Creating socket. Using TLS 1.2. 2024-01-17 21:03:19.797 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | New receive buffer size: 0 2024-01-17 21:03:19.797 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Connecting to IP: 38.79.0.89. 2024-01-17 21:03:20.484 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Socket gracefully closed by remote side. 2024-01-17 21:03:20.486 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Socket gracefully closed by remote side. 2024-01-17 21:03:20.492 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | CloseSocket call. 2024-01-17 21:03:20.492 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-01-17 21:03:20.492 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Closed. |
[2024-01-17 22:58:20] |
Set "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" to Yes. If you have changed this setting, then reconnect to the data feed after by selecting 'File >> Reconnect".
[2024-01-18 07:32:08] |
ok, thank you, this works! I have more than 3 Denali connections to different prop firms which I like to use on one device. Is there any option for me? I configured a DTC server, providing me data feed, but then how to enable trading with the prop firm account then simultaneously? |
[2024-01-18 09:08:34] |
If you have more than 3 different Rithmic connections than using the Denali data feed with them at the same time is not possible. You will need another Sierra Chart account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-01-18 09:08:41
[2024-01-18 09:45:46] |
OK, thank you!! Ticket can be closed.
