Date/Time: Mon, 25 Nov 2024 23:23:53 +0000
diff single line
View Count: 246
[2024-01-16 21:18:39]
User651547 - Posts: 59
Hi. how can i place two diff indicators on one same chart region ? for example RTY to NQ and NQ to RTY . both on the region number two. if i work on the RTY i can select RTY to NQ but how i add added diff indicator and set NQ to RTY ? the opposit one. also if i slect in both indicators region 2 , i no see nothing.
[2024-01-17 15:09:20]
John - SC Support - Posts: 36286
If you are using the "Difference (Bar)" study, then start by using the "Add Additional Symbol" to the chart and put in the secondary symbol you are using (such as NQ on an RTY chart). Then setup your first Difference (Bar) normally, although you can reference the Add Additional Study for the second symbol.
Then add another Difference (Bar) study and set the "Based On" to be the Add Additional Study with the secondary symbol (NQ for instance) and then set the 2nd symbol in the Inputs to the main symbol of the chart.
If you have both of these in the same region, then they will show as just two lines at the top and bottom of the region, due to the difference in the values. You would need to change one of the Difference (Bar) studies to be a scaling of either "Independent" or "Same as Region".
Refer to the following for reference:
Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study
Chart Scale and Scale Adjusting: Maintaining Same Scale for Multiple Graphs in Chart Region
[2024-01-19 07:45:18]
Sorry , it is really no clear . can you pls send me instruction ? ho to do it
[2024-01-19 16:06:07]
After we had given you the above information, we realized that what you are wanting to do is the same as multiplying by -1. Therefore, after you have your initial difference setup, you can use the following study to reverse the order:
Multiply Charts - Bar
[2024-01-20 11:58:57]
have you any video tutorials ?
[2024-01-22 14:31:06]
Our videos are located at the following location:
Video Library
But there are lots of videos on YouTube as well from other people.
[2024-01-22 15:16:59]
no dear . i can not find . send me link pls
[2024-01-22 17:37:00]
You can not find what? We gave you the link to our videos. Is this not working for you?
