Date/Time: Tue, 26 Nov 2024 01:47:34 +0000
Rithmic feed
View Count: 157
[2024-01-16 15:09:05]
User416156 - Posts: 7
Since I'm with Top Step, I need to use the Rithmic feed. I also pay for a Denali feed through Sierra, and my understanding is that this should be used to provide current market/historical market data, as the Rithmic service is not reliable for this. Please can you advise on how I should set up my charts so that they use Denali as required, but I am also connected to Top Step via Rithmic. Thanks.
[2024-01-16 16:15:19]
John - SC Support - Posts: 36286
As long as your account is in good standing, meaning that you have the exchange activated and that your "Verified Until" date is in the future, then the only other thing you need to verify is that the setting for "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" is set to "Yes".
In this case, regardless of the Service you are connected to, you will get the data from our Denali feed for the exchanges you have active. Any other data would come from the service you are connected to. Refer to the following for more on this:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
