Date/Time: Tue, 26 Nov 2024 02:39:40 +0000
Changing a Study ID in Spreadsheet System For Trading
View Count: 234
[2024-01-09 20:18:54]
PeaceFrog - Posts: 105
Thank you for taking the time to answer my question.
I'd like to add 3 new studies into my "Studies to Graph" list in "Spreadsheet System For Trading" in the correct order.
For example, currently I have:
1 | ID1
2 | ID2
3 | ID3
4 | ID4
5 | ID5.
When I try to "Add >>" the new studies, even when I have the cursor on ID4, the new study appears as ID6, ie:
1 | ID1
2 | ID2
3 | ID3
4 | ID6
5 | ID7
6 | ID8
7 | ID4
8 | ID5
What I'd like to do is add the 3 new studies in between ID3 and ID4, so that ID4 becomes ID7 and ID5 becomes ID8, ie:
1 | ID1
2 | ID2
3 | ID3
4 | ID4 - new added in
5 | ID5 - new added in
6 | ID6 - new added in
7 | ID7 - previously ID4
8 | ID8 - previously ID5
How can I do this?
Thank you again for your help.
[2024-01-09 21:04:37]
John - SC Support - Posts: 36286
There is not a direct way to do this.
But, to renumber the IDs of studies, you can duplicate the study to a new number, remove the previous version of it, then add/duplicate another study to take the position of the missing number.
For example, from what you gave above. You want ID4 to become ID7, so duplicate the study in ID4, which will be ID5. Add the new study, which will take on ID4, since it is now the lowest number not used. Then continue to do this until you have what you want.
[2024-01-09 21:31:15]
Hi John. Thank you for responding and for your help. Much appreciated.
