Date/Time: Mon, 06 May 2024 18:03:10 +0000
Links not working after 20
View Count: 1945
[2013-05-06 00:00:17] |
tyler - Posts: 14 |
Hi, SC seems to not support more than 20 links? I think you all should allow an unlimited amount of linked charts. As long as the computer/memory/RAM/whatever supports the amount, why limit the platform? If this is a limitation unique to my platform, any way to expand it or ideas for why it's limited? Thanks, Tyler |
[2013-05-06 00:14:47] |
There is no limit on the number of Link Numbers. You can enter any integer number. So you can do whatever you need. Just set this through Chart >> Chart Settings >> Advanced Settings 2 >> Chart Linking.
[2013-05-06 02:04:02] |
tyler - Posts: 14 |
Then there must be a mistake somewhere because when I follow those steps and click on the dropdown, it stops at 20. When entering any integer larger than 20, it doesn't work. Give it a shot on your platform. Let me know if it's different for you. |
[2013-05-06 02:09:01] |
Manually typing a number like 33 does work. However, when going back into Chart Settings we can see that it does not display. So we will correct that problem.
[2013-05-06 03:02:57] |
tyler - Posts: 14 |
Guys, I promise you it doesn't. I typed 33 in my chart 45. Then typed 33 in my chart 24. I changed the symbol in 45. 24 did not change. 24 still says L:33 in the top bar area and 45 now has no "L:33" or "L:anything". Tried it both ways and it never works. |
[2013-05-06 10:38:14] |
Please update to Sierra Chart version 971.
[2013-05-06 12:05:36] |
tyler - Posts: 14 |
You guys rule. Thank you. |
