Date/Time: Tue, 26 Nov 2024 04:43:59 +0000
Version 2578 error messages
View Count: 320
[2024-01-02 21:40:05] |
Technical - Posts: 158 |
I upgraded the software this morning and the message log started with these errors: 2024-01-02 12:06:47.775 | Listening socket (0). Port 11111 | Closed listening socket. 2024-01-02 12:06:47.781 | DTC Protocol Server listening on port 11111. 2024-01-02 12:06:47.783 | Listening socket (2960). Port 0 | Failed to bind socket to 0.0.0.0:11100. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. 2024-01-02 12:06:47.783 | Listening socket (0). Port 0 | Closed listening socket. 2024-01-02 12:36:47.766 | Listening socket (0). Port 11111 | Closed listening socket. 2024-01-02 12:36:47.769 | DTC Protocol Server listening on port 11111. 2024-01-02 12:36:47.771 | Listening socket (2872). Port 0 | Failed to bind socket to 0.0.0.0:11100. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. 2024-01-02 12:36:47.771 | Listening socket (0). Port 0 | Closed listening socket. 2024-01-02 13:06:47.767 | Listening socket (0). Port 11111 | Closed listening socket. 2024-01-02 13:06:47.771 | DTC Protocol Server listening on port 11111. 2024-01-02 13:06:47.774 | Listening socket (2840). Port 0 | Failed to bind socket to 0.0.0.0:11100. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. 2024-01-02 13:06:47.774 | Listening socket (0). Port 0 | Closed listening socket. The log appears to register one of these errors every 30 minutes or so. 2024-01-02 05:36:47.743 | Listening socket (2132). Port 0 | Failed to bind socket to 0.0.0.0:11100. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. 2024-01-02 05:36:48.016 | UDPListener (2168). Port 22903 | Error binding to UDP port: 22903. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. 2024-01-02 06:06:47.752 | Listening socket (2712). Port 0 | Failed to bind socket to 0.0.0.0:11100. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. 2024-01-02 06:36:47.758 | Listening socket (2628). Port 0 | Failed to bind socket to 0.0.0.0:11100. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. 2024-01-02 07:06:47.772 | Listening socket (2800). Port 0 | Failed to bind socket to 0.0.0.0:11100. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. 2024-01-02 07:36:47.743 | Listening socket (2140). Port 0 | Failed to bind socket to 0.0.0.0:11100. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. 2024-01-02 08:06:47.759 | Listening socket (2260). Port 0 | Failed to bind socket to 0.0.0.0:11100. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. 2024-01-02 08:36:47.824 | Listening socket (2832). Port 0 | Failed to bind socket to 0.0.0.0:11100. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. 2024-01-02 09:06:47.776 | Listening socket (2832). Port 0 | Failed to bind socket to 0.0.0.0:11100. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. 2024-01-02 09:36:47.926 | Listening socket (2820). Port 0 | Failed to bind socket to 0.0.0.0:11100. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. 2024-01-02 10:06:47.768 | Listening socket (2848). Port 0 | Failed to bind socket to 0.0.0.0:11100. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. 2024-01-02 10:36:47.775 | Listening socket (2880). Port 0 | Failed to bind socket to 0.0.0.0:11100. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. 2024-01-02 11:06:47.778 | Listening socket (2680). Port 0 | Failed to bind socket to 0.0.0.0:11100. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. 2024-01-02 11:36:47.778 | Listening socket (2928). Port 0 | Failed to bind socket to 0.0.0.0:11100. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. 2024-01-02 12:06:47.783 | Listening socket (2960). Port 0 | Failed to bind socket to 0.0.0.0:11100. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. 2024-01-02 12:36:47.771 | Listening socket (2872). Port 0 | Failed to bind socket to 0.0.0.0:11100. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. 2024-01-02 13:06:47.774 | Listening socket (2840). Port 0 | Failed to bind socket to 0.0.0.0:11100. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. |
[2024-01-02 21:48:02] |
John - SC Support - Posts: 36286 |
This should not have anything to do with the update. If this is in a Sub-Instance, then check your "Data/Trade Service Settings" and make sure that the entry on the "Main Settings" page for the "Server Address" is set to 127.0.0.1. It looks like this was changed to 0.0.0.0. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-02 23:36:11] |
Sierra_Chart Engineering - Posts: 17179 |
Set Global Settings >> Sierra Chart Server Settings >> DTC Protocol Server >> Additional Listening Port to 0 and press OK.
[2024-01-03 14:14:37] |
John: No change, was already set as you suggested. Sierra_Chart Engineering: That looks like it fixed it. |
