Date/Time: Mon, 25 Nov 2024 09:22:49 +0000
NASDAQ global indices replacement
View Count: 438
[2024-01-02 16:22:21] |
User438057 - Posts: 49 |
You informed: 5. NASDAQ global indices is going to be discontinued. We will be replacing it with CBOE global indices which will include the volatility index and S&P 500. The Nasdaq indices are discontinued already. When will the replacement be availible? Thanks |
[2024-01-02 23:33:36] |
Sierra_Chart Engineering - Posts: 17172 |
Why do you say this, this is not true: The Nasdaq indices are discontinued already.
Regarding the timing of CBOT Global Indices, we do not know. It is also possible it will not be offered. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-03 08:51:05] |
Since January 2. none of my NQ??-NQGI symbols updates anymore, i.e. NQFR-NQGI, NQEURO-NQGI and others. I also updated to v.2578 with no change. |
[2024-01-03 08:57:50] |
User365411 - Posts: 189 |
For the majority of analyst and traders the only useful feed ( and welcome to add) from the CBOE is the Main section: https://www.cboe.com/us/indices/indicesproducts/#csmi_main Cboe Global Indices (CGI) contain index that are not Benchmark, so they are relatively useless. Date Time Of Last Edit: 2024-01-03 09:01:10
[2024-01-03 09:19:49] |
Regarding post #3, we do not observe any problem with this symbol: https://www.sierrachart.com/image.php?Image=1704273487481.png The others should be working fine as well. We do not observe problems with any of the ones we have tested. Refer to help topic 3: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-03 13:48:09] |
Edit/Download Data-Intraday Chart for one -NQGI symbol, then restarting Sierra did the job for all the others as well done.
[2024-03-12 17:35:58] |
Alex Q - Posts: 98 |
When will the CBOE global indices be available? Looking for an accurate SPX cash symbol.
