Date/Time: Tue, 30 Apr 2024 15:02:39 +0000
How to use some programed fils
View Count: 1696
[2013-05-05 20:39:18] |
User25261 - Posts: 24 |
Hi, I have a friend who send me a Files(look at the attached) but I don't know how to open it and use it for SC? How I can use some other files which was made for Ninja trader?it must be converted to SC or what? Thanks |
OSC divergence code.txt - Attached On 2013-05-05 20:35:44 UTC - Size: 6.23 KB - 612 views |
[2013-05-06 10:40:27] |
This study/indicator code will need to be converted to work with Sierra Chart. It cannot be directly used as it is. Documentation for the Sierra Chart Custom Study Interface and Language can be found here: http://www.sierrachart.com/index.php?l=doc/doc_CreatingDLLs.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
