Date/Time: Tue, 26 Nov 2024 08:24:00 +0000
No longer getting updates on chart after switching plan to base advanced
View Count: 202
[2023-12-08 14:01:18]
User349850 - Posts: 3
Hi, I've been using the Integrated Advanced plan with top of the book CME data and haven't had issues for the last couple months. I switched to a base advanced plan last night with the same data feed and I'm no longer getting any updates to any chart. It is connected to the "SC Data - All Services" service. Is there something I need to configure to fix this?
[2023-12-08 14:30:29]
Sierra_Chart Engineering - Posts: 17179
We do see why there is a problem.
One question we have is do you want delayed futures data? Or real time. You will not be able to get real-time data on the Service Package you have.
Date Time Of Last Edit: 2023-12-08 14:30:44
[2023-12-08 14:37:47]
Oh, I need real-time data. I was under the impression that base advanced allowed for that. Is there any way to switch to the integrated advanced so that I can get real time updates?
[2023-12-08 15:14:45]
We have changed your Service Package to 11 now. You will start to get real-time data in a few minutes. If not, restart Sierra Chart.
Date Time Of Last Edit: 2023-12-08 15:15:11
[2023-12-08 15:19:23]
Great. Thanks.
