Date/Time: Tue, 26 Nov 2024 10:26:26 +0000
FootPrint Data
View Count: 215
[2023-12-05 13:33:56]
Daren Hampton - Posts: 27
What settings or data changes do I need to do to get these numbers more accurate??
imageMCLF24_FUT_CME[M] 3000 Trades #3 _ Micro WTI Crude Oil - NY.png / V - Attached On 2023-12-05 13:33:01 UTC - Size: 210.92 KB - 71 views
[2023-12-05 14:03:42]
The volume overall is inaccurate
imageMCLF24_FUT_CME[M] #1 _ Micro WTI Crude Oil - NYMEX MCL Jan 2.png / V - Attached On 2023-12-05 14:03:24 UTC - Size: 202.67 KB - 57 views
[2023-12-05 17:25:26]
John - SC Support - Posts: 36286
Make sure your Intraday Storage Time Unit is set to 1 tick. Refer to the following:
Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings)
If you do change this, then you will want to delete the data for that symbol and redownload it to get the 1 tick data. Select that chart and then select "Edit >> Delete All Data and Download". You only need to do this once per symbol, not for every chart.
