Date/Time: Tue, 26 Nov 2024 10:42:36 +0000
Unable to edit/modify and Delete extended rectangle tool
View Count: 263
[2023-12-05 11:46:44] |
User519646 - Posts: 15 |
Hello , We are having issues with editing, modifying and deleting extended rectangle tool, please help. When we use new drawing with extended rectangle tool we can do all the modifications but the existing rectangles are not responding |
Screenshot 2023-12-05 165535.png / V - Attached On 2023-12-05 11:45:08 UTC - Size: 191.26 KB - 72 views Attachment Deleted. |
[2023-12-05 17:17:31] |
John - SC Support - Posts: 36286 |
Make sure you have the options for editing/modifying/deleting added to the right-mouse options for drawings by selecting "Global Settings >> Customize Chart Drawing Menu". Refer to the following: Global Settings Menu: Customize Chart Drawing Menu (Global Settings menu) Also, check your setting for "Tools >> Tool Settings >> General >> Support Interior Rectangle Selection", as you might want to set this to "Yes". Refer to the following: Chart Drawing Tools: Support Interior Rectangle Selection (Global Settings >> Tool Settings >> General >> Tool Options) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-05 18:12:09] |
The issue is still there, While using tools menu , erase drawing mode all the rectangular selection are numbered as 1. In these selections the right button menu and also tools menu are not working
Screenshot 2023-12-05 233947.png / V - Attached On 2023-12-05 18:11:52 UTC - Size: 73.42 KB - 62 views |
[2023-12-05 18:42:51] |
Are these drawings created from a custom study?
[2023-12-05 20:11:12] |
no, but problem is solved, Thanks for your support
