Date/Time: Mon, 16 Sep 2024 19:27:05 +0000
Problem with flatten Order
View Count: 211
[2023-12-03 17:09:03] |
User110584 - Posts: 5 |
Hello, on Thursday, I tried to flatten a position four times in 1 minute without success (see screenshot). What is the cause of this error message? Is it a data feed issue (Rithmic) or an internet problem? Thank you in advance for your response. Best regards, Nico Date Time Of Last Edit: 2023-12-03 17:12:23
CapturepourSierra2.jpg / V - Attached On 2023-12-03 17:12:17 UTC - Size: 73.36 KB - 57 views |
[2023-12-03 18:29:14] |
Sierra_Chart Engineering - Posts: 16387 |
The cause of this is Rithmic is not acknowledging the order. Maybe there was also a connectivity issue. In our experience more than likely it is an issue on the Rithmic side.
