Date/Time: Mon, 16 Sep 2024 19:44:39 +0000
VS 2564
View Count: 412
[2023-11-29 21:47:40] |
Crtfyd - Posts: 278 |
Downloaded the new version 2564. Noticed that the CLOCK-Real Time Study used to simulate the time when doing Replay Chart. Now it just shows the Real Time like when not doing a Replay. So, its hard to tell now when a time bar (eg:1 min bar) is close to finish. Date Time Of Last Edit: 2023-11-29 21:51:36
[2023-11-29 23:48:10] |
User719512 - Posts: 245 |
Not that this will help you with your issue, but I do not see this behavior on my v2565 (pre-release) install. I have not tried to repro on 2564 like you are using and posting just as a data point. By the way, I use the Countdown Timer study to know when a bar might close, not the r/t clock (which should work either way). |
[2023-11-30 01:18:39] |
User719512 Thx, I'll use the Countdown Timer study until a fix. I imagine although its called "Real Time" clock, since the Replay is suppose to simulate the Real time, it should show the Real time that the info was printed, as the data that is affiliated with it. We don't need another Real-time clock in addition to our laptop clock bc using Replay means we're not concerned with Real time. Only during Live market conditions is the easy glance at Real-time Clock applicable I think. |
[2023-11-30 17:04:02] |
John - SC Support - Posts: 34455 |
We are not seeing what you are stating. The "Clock - Real Time" shows the time of the most recent bar during a replay, as you are wanting it to. If this is not working for you, then please give us a screenshot of what you are seeing by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-30 19:47:46] |
I don't understand that you don't see it? That's a screen cap of a Replay. The Replay is now on the bar 9:41... yet the clock says 15:10:12 (which is when I was playing the Replay) In previous version, the clock would read 9:41 as well, since that's the point the replay is at.(therefore simulating the real time on the Replay) |
[2023-11-30 22:29:29] |
When we run a replay, the "Clock - Real Time" shows the time of the replay. So it is working as you want it to. We can not reproduce what you are seeing. Again, please give us an image of what you are seeing. Also, attach the chart that is showing this issue to this thread by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-30 22:53:27] |
The image is attached to the first post
[2023-12-01 01:04:12] |
Sierra_Chart Engineering - Posts: 16387 |
Provide us that chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
