Date/Time: Mon, 16 Sep 2024 19:43:08 +0000
NQ tick size changed and depth does not match
View Count: 394
[2023-11-25 06:44:03] |
User736044 - Posts: 51 |
Hello, I changed the tick size in NQ from 0.25 to 0.50 to be able to see better but now the dom bid ask nrs don't mach what I have in the market depthh historical graph on the chart. I am wondering why that is. Thank You! |
[2023-11-27 16:33:42] |
John - SC Support - Posts: 34455 |
The Market Depth Historical Graph is going to display at the Tick Size that you have set - so every 0.50. But if you did not change the Market Depth, then those will continue to show at the actual traded tick size - 0.25. If you want to change the Bid/Ask Market Depth to be the same as the modified Tick Size, then you would need to change the "Chart >> Chart Settings >> Market Depth >> Market Depth Combine Increment in Ticks". Refer to the following: Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-28 06:46:03] |
Thanks for getting back to me. I made that change and now the discrepancy is worse, before on the dom it was on average 15-20 contracts more at the same level and now is over 30 more. Since the tick size is now 0.50 and i did what you said, what i did is, I changed it to 1 point in the market depth menu i think. I don't know what to do, i read in another post from you guys that changing the tick size should work. Thank You |
[2023-11-30 15:19:33] |
Please get us a screenshot of what you are seeing by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-01 06:10:44] |
Ok, I just found where the problem is. When I chart NQ and set MNQ as trade and Current quote symbol the dom does not match with Market Depth historical Graph. Is the dom info coming from the MNQ when I have it set this way?
[2023-12-01 06:29:01] |
Nevermind, I got it now. Thank You!
