Date/Time: Tue, 26 Nov 2024 12:25:14 +0000
daily chart current bar does not align vertically with correct date
View Count: 268
[2023-11-21 20:44:51]
User443772 - Posts: 12
Date for the current bar (the last bar) on a daily bar chart shows a date on the horizontal axis that is about 2 weeks into the future. I have three similar chartbooks with the same daily chart but only one has the date error. I have removed the lock fill space with no resolution; and I have deleted the data and reloaded without resolution.
[2023-11-21 21:02:39]
John - SC Support - Posts: 36286
Please give us a screenshot of what you are seeing by following these instructions:
Date Time Of Last Edit: 2023-11-21 21:02:53
[2023-11-22 14:13:06]
https://www.sierrachart.com/image.php?Image=1700662299801.png
[2023-11-22 16:17:46]
Where are those vertical broken lines with the dates coming from?
Also, ignore it for the moment and expand your bar spacing so you can see the actual date in the time scale at the bottom - or use your crosshair and the Tool Values Window to view the date for that bar. Most likely the bar is correct, but that vertical line is what is not correct.
[2023-11-23 16:44:03]
I will do what you suggest and get back to you. Note that I have two other chartbooks with the same daily chart that do not have any problem like I have described.
[2023-11-27 14:51:54]
https://www.sierrachart.com/image.php?Image=1701096201509.png
The crosshair shows the correct date but not the date on the horizontal axis. The vertical lines are part of a custom chartbook from AMT.
[2023-11-27 17:26:56]
From what we see the issue is that the vertical broken lines are showing incorrect dates, but everything else looks good. You need to either remove those lines or find a way to show it correctly, or simply accept what is shown.
