Date/Time: Mon, 16 Sep 2024 20:18:20 +0000
TPO Chart Unmerging itself
View Count: 195
[2023-11-20 19:40:42] |
Gabriel Poinsot - Posts: 2 |
Hello Support Team, It happened since a week or so ago, didn't change any settings or at least that I'm not aware of... but now my MP/TPO chart is unmerging itself every time I close my chartbook and re open it, and that for every chartbook I have. I of course make sure I save before I close the chartbook. Any reasons why or how can that be fixed ? I am on the version 2563, live data. Kind Regards, Gabriel. |
[2023-11-20 19:45:39] |
Sierra_Chart Engineering - Posts: 16387 |
We want you to update to version 2564. This problem is resolved now. Instructions to update: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
