Date/Time: Tue, 26 Nov 2024 14:41:28 +0000
Rithmic constant disconnecting (Prop Trading account)
View Count: 268
[2023-11-14 15:54:46] |
meeks - Posts: 7 |
Hello, My Rithmic keeps disconnecting and attempting to reconnect. I am trying to link my prop trading account (TakeProfit Trader) and entered my Rithmic login credentials in the Global Settings, but it keeps disconnecting. Are you able to assist? The message log is below - (Log removed) DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:50:45.177 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:50:45.177 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:50:45.177 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2023-11-14 10:50:45.200 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:50:45.200 DTC Client socket (2) | Closed. | 2023-11-14 10:50:45.200 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:50:47.175 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:50:47.175 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:50:47.175 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:50:47.175 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:50:47.175 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:50:47.203 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:50:47.203 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:50:47.203 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:50:47.203 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:50:47.289 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:50:47.289 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:50:47.289 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:50:47.289 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:50:47.289 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:50:47.289 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:50:47.289 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:50:47.289 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:50:47.289 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:50:47.289 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:50:47.317 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:50:47.317 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:50:47.317 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:50:47.317 DTC Client socket (2) | Closed. | 2023-11-14 10:50:47.317 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:50:47.317 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:50:47.317 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:50:47.317 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:50:49.311 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:50:49.311 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:50:49.311 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:50:49.311 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:50:49.311 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:50:49.342 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:50:49.342 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:50:49.342 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:50:49.342 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:50:49.439 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:50:49.439 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:50:49.439 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:50:49.439 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:50:49.439 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:50:49.439 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:50:49.439 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:50:49.439 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:50:49.439 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:50:49.439 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:50:49.466 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:50:49.466 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:50:49.466 DTC Client socket (2) | Closed. | 2023-11-14 10:50:49.466 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:50:49.466 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:50:49.466 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:50:49.466 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:50:49.466 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:50:51.460 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:50:51.460 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:50:51.461 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:50:51.461 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:50:51.461 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:50:51.491 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:50:51.491 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:50:51.491 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:50:51.491 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:50:51.569 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:50:51.569 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:50:51.569 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:50:51.569 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:50:51.569 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:50:51.569 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:50:51.569 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:50:51.569 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:50:51.569 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:50:51.569 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:50:51.603 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:50:51.605 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:50:51.605 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:50:51.605 DTC Client socket (2) | Closed. | 2023-11-14 10:50:51.605 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:50:51.606 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:50:51.606 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:50:51.606 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:50:53.608 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:50:53.608 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:50:53.610 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:50:53.610 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:50:53.610 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:50:53.634 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:50:53.634 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:50:53.634 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:50:53.634 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:50:53.713 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:50:53.713 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:50:53.713 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:50:53.713 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:50:53.713 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:50:53.713 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:50:53.713 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:50:53.713 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:50:53.713 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:50:53.713 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:50:53.737 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:50:53.737 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:50:53.737 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:50:53.737 DTC Client socket (2) | Closed. | 2023-11-14 10:50:53.737 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:50:53.737 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:50:53.737 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:50:53.737 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:50:55.735 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:50:55.735 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:50:55.735 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:50:55.735 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:50:55.735 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:50:55.759 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:50:55.759 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:50:55.760 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:50:55.760 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:50:55.837 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:50:55.837 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:50:55.837 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:50:55.837 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:50:55.837 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:50:55.837 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:50:55.837 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:50:55.837 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:50:55.837 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:50:55.837 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:50:55.863 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:50:55.863 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:50:55.863 DTC Client socket (2) | Closed. | 2023-11-14 10:50:55.863 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:50:55.863 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:50:55.863 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:50:55.863 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:50:55.863 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:50:57.864 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:50:57.864 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:50:57.864 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:50:57.864 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:50:57.864 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:50:57.891 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:50:57.891 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:50:57.891 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:50:57.891 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:50:57.975 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:50:57.975 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:50:57.975 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:50:57.975 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:50:57.975 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:50:57.975 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:50:57.975 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:50:57.975 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:50:57.975 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:50:57.975 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:50:58.002 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:50:58.003 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:50:58.003 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:50:58.003 DTC Client socket (2) | Closed. | 2023-11-14 10:50:58.003 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:50:58.004 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:50:58.004 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:50:58.004 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:50:59.998 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:50:59.998 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:50:59.998 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:50:59.998 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:50:59.998 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:00.023 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:00.023 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:00.023 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:00.023 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:00.109 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:00.109 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:00.109 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:00.109 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:00.109 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:00.109 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:00.109 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:00.109 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:00.109 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:00.109 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:00.135 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:00.135 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:00.135 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:00.135 DTC Client socket (2) | Closed. | 2023-11-14 10:51:00.135 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:00.135 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:00.135 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:00.135 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:02.144 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:02.144 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:02.144 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:02.144 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:02.145 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:02.169 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:02.169 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:02.169 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:02.169 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:02.245 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:02.245 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:02.245 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:02.245 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:02.245 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:02.245 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:02.245 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:02.245 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:02.245 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:02.245 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:02.270 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:02.270 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:02.270 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:02.270 DTC Client socket (2) | Closed. | 2023-11-14 10:51:02.270 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:02.270 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:02.270 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:02.270 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:04.260 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:04.260 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:04.260 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:04.260 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:04.260 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:04.288 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:04.288 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:04.288 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:04.288 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:04.369 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:04.369 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:04.369 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:04.369 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:04.369 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:04.369 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:04.369 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:04.369 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:04.369 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:04.369 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:04.395 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:04.395 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:04.395 DTC Client socket (2) | Closed. | 2023-11-14 10:51:04.395 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:04.395 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:04.396 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:04.396 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:04.396 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:06.390 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:06.390 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:06.390 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:06.390 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:06.390 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:06.420 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:06.420 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:06.420 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:06.420 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:06.533 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:06.533 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:06.533 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:06.533 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:06.533 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:06.533 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:06.533 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:06.533 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:06.533 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:06.533 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:06.576 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:06.576 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:06.576 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:06.576 DTC Client socket (2) | Closed. | 2023-11-14 10:51:06.576 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:06.576 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:06.576 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:06.576 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:08.571 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:08.571 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:08.574 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:08.574 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:08.574 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:08.607 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:08.607 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:08.607 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:08.607 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:08.684 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:08.684 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:08.684 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:08.684 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:08.684 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:08.684 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:08.684 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:08.684 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:08.684 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:08.684 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:08.709 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:08.709 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:08.709 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:08.709 DTC Client socket (2) | Closed. | 2023-11-14 10:51:08.709 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:08.709 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:08.709 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:08.709 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:10.708 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:10.708 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:10.708 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:10.708 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:10.708 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:10.732 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:10.732 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:10.732 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:10.732 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:10.811 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:10.811 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:10.811 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:10.811 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:10.811 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:10.811 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:10.811 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:10.811 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:10.811 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:10.811 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:10.836 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:10.836 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:10.836 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:10.836 DTC Client socket (2) | Closed. | 2023-11-14 10:51:10.837 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:10.837 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:10.837 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:10.837 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:12.842 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:12.842 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:12.843 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:12.843 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:12.843 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:12.869 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:12.869 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:12.869 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:12.869 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:12.955 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:12.955 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:12.955 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:12.955 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:12.955 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:12.955 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:12.955 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:12.955 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:12.955 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:12.955 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:12.982 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:12.990 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:12.990 DTC Client socket (2) | Closed. | 2023-11-14 10:51:12.990 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:12.990 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:12.990 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:12.990 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:12.990 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:14.987 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:14.987 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:14.988 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:14.988 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:14.988 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:15.013 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:15.013 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:15.013 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:15.013 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:15.093 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:15.093 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:15.093 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:15.093 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:15.093 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:15.093 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:15.093 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:15.093 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:15.093 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:15.093 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:15.118 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:15.118 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:15.118 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:15.118 DTC Client socket (2) | Closed. | 2023-11-14 10:51:15.118 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:15.119 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:15.119 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:15.119 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:17.126 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:17.126 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:17.126 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:17.126 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:17.126 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:17.151 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:17.151 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:17.151 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:17.151 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:17.229 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:17.229 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:17.229 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:17.229 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:17.229 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:17.229 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:17.229 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:17.229 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:17.229 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:17.229 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:17.255 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:17.255 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:17.255 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:17.255 DTC Client socket (2) | Closed. | 2023-11-14 10:51:17.255 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:17.255 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:17.255 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:17.255 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:19.241 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:19.241 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:19.241 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:19.241 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:19.241 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:19.267 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:19.267 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:19.267 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:19.267 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:19.346 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:19.346 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:19.346 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:19.346 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:19.346 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:19.346 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:19.346 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:19.346 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:19.346 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:19.346 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:19.370 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:19.370 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:19.370 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:19.370 DTC Client socket (2) | Closed. | 2023-11-14 10:51:19.370 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:19.370 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:19.370 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:19.370 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:21.368 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:21.369 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:21.369 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:21.369 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:21.369 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:21.397 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:21.397 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:21.397 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:21.397 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:21.482 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:21.482 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:21.482 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:21.482 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:21.482 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:21.482 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:21.482 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:21.482 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:21.482 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:21.482 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:21.509 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:21.509 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:21.509 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:21.509 DTC Client socket (2) | Closed. | 2023-11-14 10:51:21.509 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:21.510 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:21.510 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:21.510 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:23.507 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:23.507 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:23.510 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:23.510 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:23.510 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:23.538 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:23.538 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:23.538 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:23.538 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:23.622 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:23.622 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:23.622 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:23.622 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:23.622 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:23.622 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:23.622 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:23.622 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:23.622 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:23.622 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:23.651 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:23.651 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:23.651 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:23.651 DTC Client socket (2) | Closed. | 2023-11-14 10:51:23.651 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:23.651 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:23.651 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:23.651 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:25.661 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:25.661 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:25.661 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:25.661 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:25.661 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:25.685 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:25.685 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:25.685 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:25.685 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:25.807 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:25.807 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:25.807 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:25.807 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:25.807 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:25.807 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:25.807 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:25.807 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:25.807 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:25.807 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:25.833 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:25.833 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:25.833 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:25.833 DTC Client socket (2) | Closed. | 2023-11-14 10:51:25.833 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:25.833 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:25.833 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:25.833 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:27.826 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:27.826 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:27.826 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:27.826 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:27.826 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:27.850 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:27.850 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:27.850 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:27.850 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:27.926 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:27.926 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:27.926 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:27.926 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:27.926 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:27.926 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:27.926 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:27.926 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:27.926 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:27.926 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:27.952 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:27.953 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:27.953 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:27.953 DTC Client socket (2) | Closed. | 2023-11-14 10:51:27.953 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:27.953 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:27.953 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:27.953 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:29.969 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:29.969 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:29.969 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:29.969 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:29.969 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:29.998 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:29.998 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:29.998 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:29.998 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:30.081 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:30.081 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:30.081 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:30.081 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:30.081 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:30.081 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:30.081 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:30.081 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:30.081 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:30.081 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:30.109 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:30.109 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:30.109 DTC Client socket (2) | Closed. | 2023-11-14 10:51:30.109 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:30.109 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:30.109 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:30.109 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:30.109 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:32.111 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:32.111 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:32.111 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:32.111 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:32.111 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:32.137 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:32.137 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:32.137 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:32.137 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:32.221 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:32.221 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:32.221 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:32.221 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:32.221 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:32.221 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:32.221 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:32.221 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:32.221 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:32.221 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:32.249 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:32.249 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:32.249 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:32.250 DTC Client socket (2) | Closed. | 2023-11-14 10:51:32.250 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:32.250 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:32.250 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:32.250 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:34.247 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:34.247 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:34.248 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:34.248 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:34.248 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:34.274 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:34.274 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:34.274 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:34.274 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:34.365 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:34.365 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:34.365 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:34.365 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:34.365 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:34.365 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:34.366 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:34.366 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:34.366 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:34.366 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:34.392 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:34.392 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:34.392 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:34.392 DTC Client socket (2) | Closed. | 2023-11-14 10:51:34.392 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:34.392 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:34.392 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:34.392 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:36.393 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:36.393 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:36.393 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:36.393 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:36.393 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:36.418 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:36.418 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:36.418 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:36.418 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:36.503 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:36.503 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:36.503 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:36.503 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:36.503 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:36.503 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:36.503 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:36.503 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:36.503 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:36.503 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:36.528 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:36.528 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:36.528 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:36.528 DTC Client socket (2) | Closed. | 2023-11-14 10:51:36.528 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:36.529 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:36.529 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:36.529 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:38.549 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:38.549 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:38.554 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:38.554 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:38.554 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:38.582 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:38.582 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:38.582 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:38.582 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:38.664 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:38.664 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:38.664 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:38.664 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:38.664 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:38.664 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:38.664 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:38.664 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:38.664 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:38.664 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:38.693 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:38.693 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:38.693 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:38.693 DTC Client socket (2) | Closed. | 2023-11-14 10:51:38.693 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:38.694 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:38.694 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:38.694 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:40.680 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:40.680 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:40.681 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:40.681 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:40.681 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:40.704 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:40.704 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:40.705 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:40.705 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:40.789 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:40.790 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:40.790 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:40.790 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:40.790 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:40.790 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:40.790 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:40.790 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:40.790 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:40.790 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:40.816 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:40.816 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:40.816 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:40.816 DTC Client socket (2) | Closed. | 2023-11-14 10:51:40.816 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:40.816 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:40.816 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:40.816 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:42.813 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:42.813 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:42.814 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:42.814 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:42.814 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:42.838 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:42.838 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:42.839 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:42.839 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:42.916 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:42.916 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:42.916 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:42.916 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:42.916 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:42.916 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:42.916 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:42.916 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:42.916 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:42.916 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:42.941 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:42.951 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:42.951 DTC Client socket (2) | Closed. | 2023-11-14 10:51:42.951 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:42.951 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:42.952 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:42.952 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:42.952 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:44.997 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:44.997 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:44.997 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:44.997 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:44.997 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:45.026 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:45.026 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:45.026 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:45.026 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:45.165 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:45.165 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:45.165 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:45.165 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:45.165 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:45.165 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:45.165 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:45.165 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:45.165 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:45.165 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:45.199 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:45.199 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:45.199 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:45.199 DTC Client socket (2) | Closed. | 2023-11-14 10:51:45.199 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:45.200 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:45.200 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:45.200 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:47.204 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:47.204 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:47.205 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:47.205 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:47.205 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:47.229 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:47.229 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:47.229 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:47.229 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:47.307 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:47.307 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:47.307 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:47.307 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:47.307 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:47.307 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:47.307 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:47.307 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:47.307 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:47.307 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:47.331 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:47.331 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:47.331 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:47.331 DTC Client socket (2) | Closed. | 2023-11-14 10:51:47.331 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:47.331 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:47.331 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:47.331 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:49.321 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:49.321 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:49.321 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:49.321 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:49.321 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:49.347 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:49.347 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:49.347 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:49.347 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:49.423 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:49.423 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:49.423 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:49.423 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:49.423 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:49.423 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:49.423 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:49.423 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:49.423 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:49.423 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:49.448 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:49.455 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:49.455 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:49.455 DTC Client socket (2) | Closed. | 2023-11-14 10:51:49.455 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:49.455 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:49.455 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:49.455 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:51.500 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:51.500 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:51.500 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:51.500 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:51.500 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:51.532 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:51.532 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:51.532 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:51.532 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:51.628 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:51.628 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:51.628 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:51.628 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:51.628 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:51.628 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:51.628 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:51.628 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:51.628 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:51.628 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:51.655 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:51.655 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:51.655 DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2023-11-14 10:51:51.655 * DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:51.655 DTC Client socket (2) | Closed. | 2023-11-14 10:51:51.655 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:51.655 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:51.655 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:51.655 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:53.658 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:53.658 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:53.662 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:53.662 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:53.662 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:53.685 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:53.685 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:53.686 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:53.686 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:53.762 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:53.762 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:53.762 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:53.762 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:53.762 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:53.762 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:53.762 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:53.762 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:53.762 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:53.762 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:53.787 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:53.787 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:53.787 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:53.787 DTC Client socket (2) | Closed. | 2023-11-14 10:51:53.787 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:53.787 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:53.787 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:53.787 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:55.787 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:55.787 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:55.788 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:55.788 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:55.788 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:55.814 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:55.814 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:55.814 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:55.814 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:55.897 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:55.897 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:55.897 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:55.897 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:55.897 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:55.897 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:55.897 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:55.897 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:55.897 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:55.897 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:55.926 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:55.926 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:55.926 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:55.926 DTC Client socket (2) | Closed. | 2023-11-14 10:51:55.926 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:55.926 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:55.926 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:55.926 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:51:57.920 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:51:57.920 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:51:57.921 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:51:57.921 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:51:57.921 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:51:57.952 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:51:57.952 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:51:57.958 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:51:57.958 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:51:58.044 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:51:58.044 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:51:58.044 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:51:58.044 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:51:58.044 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:51:58.044 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:58.044 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:51:58.044 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:58.044 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:51:58.044 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:51:58.071 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:51:58.071 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:51:58.071 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:51:58.071 DTC Client socket (2) | Closed. | 2023-11-14 10:51:58.071 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:51:58.071 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:51:58.071 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:51:58.071 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:00.070 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:00.070 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:00.070 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:00.070 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:00.070 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:00.120 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:00.120 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:00.121 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:00.121 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:00.202 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:00.202 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:00.202 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:00.202 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:00.202 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:00.202 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:00.202 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:00.202 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:00.202 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:00.202 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:00.230 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:00.230 DTC Client socket (2) | Max send buffers used during socket life: 3 | 2023-11-14 10:52:00.230 DTC Client socket (2) | Max send buffer size during socket life: 1207 | 2023-11-14 10:52:00.230 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:00.230 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:00.230 DTC Client socket (2) | Closed. | 2023-11-14 10:52:00.231 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:00.231 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:00.231 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:00.231 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:02.235 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:02.236 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:02.237 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:02.237 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:02.237 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:02.264 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:02.264 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:02.264 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:02.264 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:02.350 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:02.350 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:02.350 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:02.350 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:02.350 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:02.350 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:02.350 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:02.350 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:02.350 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:02.350 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:02.376 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:02.376 DTC Client socket (2) | Max send buffers used during socket life: 3 | 2023-11-14 10:52:02.376 DTC Client socket (2) | Max send buffer size during socket life: 1207 | 2023-11-14 10:52:02.376 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:02.376 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2023-11-14 10:52:02.377 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:02.377 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:02.377 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:02.377 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2023-11-14 10:52:02.402 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:02.402 DTC Client socket (2) | Closed. | 2023-11-14 10:52:02.402 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:04.371 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:04.371 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:04.372 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:04.372 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:04.372 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:04.396 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:04.396 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:04.396 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:04.396 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:04.498 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:04.498 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:04.498 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:04.498 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:04.498 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:04.498 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:04.498 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:04.498 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:04.498 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:04.498 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:04.525 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:04.530 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:04.530 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:04.531 DTC Client socket (2) | Closed. | 2023-11-14 10:52:04.531 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:04.531 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:04.531 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:04.531 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:06.545 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:06.546 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:06.546 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:06.546 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:06.546 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:06.571 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:06.571 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:06.571 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:06.571 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:06.649 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:06.649 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:06.649 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:06.649 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:06.649 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:06.649 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:06.649 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:06.649 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:06.649 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:06.649 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:06.675 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:06.675 DTC Client socket (2) | Max send buffers used during socket life: 3 | 2023-11-14 10:52:06.675 DTC Client socket (2) | Max send buffer size during socket life: 1207 | 2023-11-14 10:52:06.675 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:06.675 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:06.675 DTC Client socket (2) | Closed. | 2023-11-14 10:52:06.675 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:06.675 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:06.675 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:06.675 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:08.663 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:08.663 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:08.668 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:08.668 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:08.668 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:08.696 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:08.696 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:08.696 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:08.696 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:08.779 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:08.779 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:08.779 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:08.779 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:08.779 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:08.779 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:08.779 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:08.779 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:08.779 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:08.779 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:08.806 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:08.806 DTC Client socket (2) | Max send buffers used during socket life: 3 | 2023-11-14 10:52:08.806 DTC Client socket (2) | Max send buffer size during socket life: 1207 | 2023-11-14 10:52:08.806 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:08.807 DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2023-11-14 10:52:08.807 * DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:08.807 DTC Client socket (2) | Closed. | 2023-11-14 10:52:08.807 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:08.807 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:08.807 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:08.807 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:10.813 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:10.813 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:10.813 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:10.813 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:10.813 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:10.838 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:10.838 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:10.838 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:10.838 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:10.915 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:10.915 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:10.915 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:10.915 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:10.915 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:10.915 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:10.915 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:10.915 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:10.915 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:10.915 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:10.941 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:10.953 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:10.954 DTC Client socket (2) | Closed. | 2023-11-14 10:52:10.954 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:10.954 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:10.954 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:10.954 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:10.954 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:13.003 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:13.003 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:13.003 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:13.003 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:13.003 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:13.029 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:13.029 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:13.029 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:13.029 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:13.127 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:13.127 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:13.127 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:13.127 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:13.127 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:13.127 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:13.127 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:13.127 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:13.127 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:13.127 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:13.154 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:13.154 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:13.154 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:13.154 DTC Client socket (2) | Closed. | 2023-11-14 10:52:13.154 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:13.155 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:13.155 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:13.155 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:15.161 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:15.161 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:15.161 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:15.161 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:15.161 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:15.186 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:15.186 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:15.186 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:15.186 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:15.264 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:15.264 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:15.264 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:15.264 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:15.264 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:15.264 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:15.264 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:15.264 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:15.264 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:15.264 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:15.290 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:15.290 DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2023-11-14 10:52:15.290 * DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:15.290 DTC Client socket (2) | Closed. | 2023-11-14 10:52:15.290 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:15.290 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:15.290 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:15.290 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:15.290 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:17.302 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:17.302 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:17.303 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:17.303 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:17.303 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:17.327 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:17.327 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:17.327 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:17.327 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:17.409 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:17.409 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:17.409 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:17.409 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:17.409 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:17.409 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:17.409 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:17.409 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:17.409 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:17.409 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:17.435 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:17.435 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:17.435 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:17.435 DTC Client socket (2) | Closed. | 2023-11-14 10:52:17.435 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:17.435 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:17.435 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:17.435 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:19.428 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:19.428 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:19.429 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:19.429 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:19.429 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:19.465 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:19.465 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:19.465 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:19.465 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:19.542 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:19.542 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:19.542 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:19.542 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:19.542 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:19.542 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:19.542 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:19.542 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:19.542 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:19.542 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:19.567 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:19.567 DTC Client socket (2) | Max send buffers used during socket life: 3 | 2023-11-14 10:52:19.567 DTC Client socket (2) | Max send buffer size during socket life: 1207 | 2023-11-14 10:52:19.567 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:19.567 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:19.567 DTC Client socket (2) | Closed. | 2023-11-14 10:52:19.567 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:19.568 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:19.568 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:19.568 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:21.562 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:21.562 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:21.563 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:21.563 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:21.563 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:21.587 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:21.587 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:21.588 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:21.588 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:21.667 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:21.667 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:21.667 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:21.667 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:21.667 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:21.667 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:21.667 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:21.667 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:21.667 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:21.667 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:21.693 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:21.693 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:21.693 DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2023-11-14 10:52:21.693 * DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:21.693 DTC Client socket (2) | Closed. | 2023-11-14 10:52:21.693 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:21.693 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:21.693 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:21.693 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:23.689 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:23.689 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:23.695 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:23.695 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:23.695 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:23.720 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:23.720 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:23.720 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:23.720 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:23.799 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:23.799 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:23.799 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:23.799 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:23.799 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:23.799 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:23.799 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:23.799 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:23.799 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:23.799 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:23.824 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:23.824 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:23.824 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:23.824 DTC Client socket (2) | Closed. | 2023-11-14 10:52:23.824 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:23.825 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:23.825 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:23.825 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:25.826 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:25.826 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:25.826 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:25.826 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:25.826 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:25.950 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:25.950 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:25.950 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:25.950 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:26.052 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:26.052 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:26.052 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:26.052 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:26.052 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:26.052 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:26.052 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:26.052 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:26.052 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:26.052 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:26.078 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:26.078 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:26.078 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:26.079 DTC Client socket (2) | Closed. | 2023-11-14 10:52:26.079 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:26.079 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:26.079 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:26.079 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:28.069 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:28.069 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:28.070 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:28.070 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:28.070 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:28.100 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:28.100 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:28.100 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:28.100 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:28.186 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:28.186 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:28.186 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:28.186 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:28.186 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:28.186 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:28.186 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:28.186 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:28.186 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:28.186 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:28.215 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:28.215 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:28.215 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:28.215 DTC Client socket (2) | Closed. | 2023-11-14 10:52:28.215 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:28.215 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:28.215 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:28.215 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:30.222 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:30.222 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:30.223 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:30.223 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:30.223 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:30.261 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:30.261 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:30.261 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:30.261 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:30.346 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:30.346 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:30.346 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:30.346 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:30.346 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:30.346 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:30.346 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:30.346 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:30.346 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:30.346 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:30.374 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:30.374 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:30.374 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:30.374 DTC Client socket (2) | Closed. | 2023-11-14 10:52:30.374 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:30.374 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:30.374 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:30.374 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:32.371 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:32.371 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:32.371 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:32.371 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:32.371 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:32.398 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:32.398 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:32.398 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:32.398 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:32.503 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:32.503 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:32.503 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:32.503 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:32.503 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:32.503 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:32.503 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:32.503 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:32.503 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:32.503 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:32.529 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:32.529 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:32.529 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:32.529 DTC Client socket (2) | Closed. | 2023-11-14 10:52:32.529 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:32.529 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:32.529 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:32.529 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:34.529 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:34.529 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:34.529 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:34.529 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:34.529 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:34.565 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:34.565 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:34.565 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:34.565 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:34.659 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:34.659 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:34.659 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:34.659 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:34.659 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:34.659 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:34.659 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:34.659 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:34.659 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:34.659 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:34.686 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:34.686 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:34.686 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:34.686 DTC Client socket (2) | Closed. | 2023-11-14 10:52:34.686 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:34.686 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:34.686 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:34.686 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:36.696 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:36.696 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:36.696 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:36.696 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:36.696 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:36.724 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:36.724 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:36.724 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:36.724 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:36.815 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:36.815 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:36.815 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:36.815 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:36.815 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:36.815 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:36.815 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:36.815 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:36.815 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:36.815 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:36.842 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:36.842 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:36.842 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:36.842 DTC Client socket (2) | Closed. | 2023-11-14 10:52:36.843 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:36.844 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:36.844 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:36.844 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:38.839 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:38.839 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:38.847 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:38.847 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:38.847 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:38.872 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:38.872 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:38.872 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:38.872 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:38.948 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:38.948 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:38.948 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:38.948 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:38.948 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:38.948 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:38.948 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:38.948 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:38.948 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:38.948 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:38.973 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:38.973 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:38.973 DTC Client socket (2) | Closed. | 2023-11-14 10:52:38.974 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:38.974 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:38.974 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:38.974 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:38.974 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:40.991 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:40.991 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:40.992 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:40.992 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:40.992 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:41.016 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:41.016 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:41.016 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:41.016 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:41.093 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:41.093 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:41.093 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:41.093 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:41.093 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:41.093 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:41.093 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:41.093 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:41.093 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:41.093 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:41.118 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:41.137 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:41.137 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:41.137 DTC Client socket (2) | Closed. | 2023-11-14 10:52:41.137 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:41.138 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:41.138 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:41.138 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:43.139 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:43.139 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:43.140 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:43.140 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:43.140 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:43.165 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:43.165 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:43.165 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:43.165 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:43.240 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:43.240 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:43.240 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:43.240 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:43.240 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:43.240 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:43.240 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:43.240 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:43.240 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:43.240 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:43.264 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:43.264 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:43.264 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:43.264 DTC Client socket (2) | Closed. | 2023-11-14 10:52:43.264 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:43.264 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:43.264 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:43.264 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:45.261 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:45.261 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:45.262 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:45.262 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:45.262 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:45.289 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:45.289 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:45.289 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:45.290 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:45.375 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:45.375 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:45.375 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:45.375 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:45.375 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:45.375 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:45.375 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:45.375 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:45.375 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:45.375 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:45.403 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:45.403 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:45.403 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:45.403 DTC Client socket (2) | Closed. | 2023-11-14 10:52:45.403 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:45.403 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:45.403 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:45.403 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:47.398 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:47.398 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:47.399 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:47.399 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:47.399 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:47.425 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:47.425 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:47.425 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:47.425 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:47.533 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:47.533 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:47.533 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:47.533 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:47.533 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:47.533 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:47.533 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:47.533 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:47.533 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:47.533 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:47.560 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:47.560 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:47.560 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:47.560 DTC Client socket (2) | Closed. | 2023-11-14 10:52:47.560 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:47.561 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:47.561 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:47.561 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:49.566 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:49.566 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:49.566 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:49.566 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:49.566 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:49.630 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:49.630 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:49.630 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:49.630 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:49.727 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:49.727 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:49.727 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:49.727 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:49.727 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:49.727 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:49.727 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:49.727 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:49.727 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:49.727 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:49.764 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:49.764 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:49.764 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:49.764 DTC Client socket (2) | Closed. | 2023-11-14 10:52:49.764 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:49.764 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:49.764 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:49.764 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:51.763 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:51.763 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:51.764 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:51.764 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:51.764 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:51.788 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:51.788 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:51.788 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:51.788 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:51.863 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:51.863 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:51.863 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:51.863 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:51.863 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:51.863 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:51.863 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:51.863 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:51.863 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:51.863 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:51.887 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:51.887 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:51.887 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:51.887 DTC Client socket (2) | Closed. | 2023-11-14 10:52:51.888 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:51.888 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:51.888 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:51.888 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:53.882 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:53.882 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:53.886 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:53.886 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:53.886 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:53.913 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:53.913 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:53.914 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:53.914 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:54.023 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:54.023 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:54.023 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:54.023 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:54.023 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:54.023 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:54.023 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:54.023 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:54.023 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:54.023 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:54.051 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:54.052 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:54.052 DTC Client socket (2) | Closed. | 2023-11-14 10:52:54.052 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:54.053 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:54.053 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:54.053 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:54.053 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:56.052 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:56.052 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:56.053 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:56.053 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:56.053 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:56.080 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:56.080 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:56.081 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:56.081 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:56.164 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:56.164 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:56.164 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:56.164 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:56.164 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:56.164 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:56.164 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:56.164 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:56.164 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:56.164 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:56.193 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:56.193 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:56.193 DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2023-11-14 10:52:56.193 * DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:56.193 DTC Client socket (2) | Closed. | 2023-11-14 10:52:56.193 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:56.194 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:56.194 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:56.194 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:52:58.202 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:52:58.202 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:52:58.203 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:52:58.203 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:52:58.203 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:52:58.238 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:52:58.238 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:52:58.238 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:52:58.238 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:52:58.325 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:52:58.325 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:52:58.325 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:52:58.325 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:52:58.325 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:52:58.325 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:58.325 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:52:58.325 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:58.325 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:52:58.325 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:52:58.353 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:52:58.353 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:52:58.353 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:52:58.353 DTC Client socket (2) | Closed. | 2023-11-14 10:52:58.353 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:52:58.353 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:52:58.353 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:52:58.353 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:00.355 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:00.355 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:00.356 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:00.356 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:00.356 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:00.383 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:00.383 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:00.383 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:00.383 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:00.472 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:00.472 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:00.472 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:00.472 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:00.472 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:00.472 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:00.472 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:00.472 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:00.472 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:00.473 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:00.501 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:00.501 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:00.501 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:00.502 DTC Client socket (2) | Closed. | 2023-11-14 10:53:00.502 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:00.502 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:00.502 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:00.502 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:02.531 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:02.531 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:02.531 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:02.531 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:02.531 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:02.559 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:02.559 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:02.559 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:02.559 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:02.647 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:02.647 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:02.647 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:02.647 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:02.647 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:02.647 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:02.647 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:02.647 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:02.647 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:02.647 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:02.675 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:02.675 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:02.675 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:02.675 DTC Client socket (2) | Closed. | 2023-11-14 10:53:02.675 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:02.675 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:02.675 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:02.675 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:04.677 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:04.677 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:04.677 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:04.677 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:04.677 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:04.702 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:04.702 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:04.702 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:04.702 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:04.804 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:04.804 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:04.804 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:04.804 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:04.804 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:04.804 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:04.804 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:04.804 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:04.804 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:04.804 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:04.829 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:04.829 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:04.829 DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2023-11-14 10:53:04.830 * DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:04.830 DTC Client socket (2) | Closed. | 2023-11-14 10:53:04.830 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:04.831 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:04.831 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:04.831 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:06.829 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:06.829 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:06.830 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:06.830 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:06.830 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:06.860 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:06.860 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:06.860 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:06.860 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:06.964 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:06.964 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:06.964 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:06.964 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:06.964 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:06.964 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:06.964 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:06.964 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:06.964 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:06.964 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:06.992 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:07.001 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:07.001 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:07.001 DTC Client socket (2) | Closed. | 2023-11-14 10:53:07.001 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:07.002 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:07.002 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:07.002 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:09.018 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:09.018 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:09.022 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:09.022 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:09.022 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:09.046 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:09.046 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:09.047 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:09.047 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:09.125 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:09.125 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:09.125 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:09.125 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:09.125 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:09.125 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:09.125 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:09.125 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:09.125 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:09.125 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:09.150 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:09.150 DTC Client socket (2) | Max send buffers used during socket life: 3 | 2023-11-14 10:53:09.150 DTC Client socket (2) | Max send buffer size during socket life: 1207 | 2023-11-14 10:53:09.150 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:09.150 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=840 | 2023-11-14 10:53:09.150 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:09.150 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:09.150 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:09.150 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2023-11-14 10:53:09.175 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:09.175 DTC Client socket (2) | Closed. | 2023-11-14 10:53:09.175 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:11.162 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:11.162 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:11.163 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:11.163 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:11.163 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:11.188 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:11.188 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:11.188 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:11.188 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:11.263 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:11.263 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:11.263 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:11.263 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:11.263 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:11.263 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:11.263 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:11.263 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:11.263 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:11.263 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:11.289 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:11.289 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:11.289 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:11.289 DTC Client socket (2) | Closed. | 2023-11-14 10:53:11.289 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:11.289 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:11.289 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:11.289 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:13.303 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:13.303 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:13.304 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:13.304 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:13.304 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:13.329 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:13.329 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:13.329 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:13.329 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:13.429 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:13.429 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:13.429 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:13.429 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:13.429 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:13.429 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:13.429 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:13.429 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:13.429 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:13.429 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:13.454 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:13.468 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:13.468 DTC Client socket (2) | Closed. | 2023-11-14 10:53:13.468 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:13.468 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:13.468 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:13.468 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:13.468 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:15.510 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:15.510 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:15.510 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:15.510 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:15.510 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:15.542 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:15.542 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:15.543 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:15.543 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:15.630 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:15.630 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:15.630 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:15.630 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:15.630 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:15.630 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:15.630 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:15.630 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:15.630 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:15.630 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:15.660 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:15.660 DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2023-11-14 10:53:15.660 * DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:15.660 DTC Client socket (2) | Closed. | 2023-11-14 10:53:15.660 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:15.660 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:15.661 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:15.661 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:15.661 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:17.647 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:17.647 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:17.648 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:17.648 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:17.648 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:17.675 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:17.675 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:17.675 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:17.675 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:17.757 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:17.757 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:17.757 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:17.757 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:17.757 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:17.757 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:17.757 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:17.757 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:17.757 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:17.757 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:17.784 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:17.784 DTC Client socket (2) | Max send buffers used during socket life: 3 | 2023-11-14 10:53:17.784 DTC Client socket (2) | Max send buffer size during socket life: 1207 | 2023-11-14 10:53:17.784 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:17.784 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:17.784 DTC Client socket (2) | Closed. | 2023-11-14 10:53:17.784 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:17.785 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:17.785 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:17.785 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:19.787 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:19.787 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:19.787 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:19.787 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:19.787 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:19.814 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:19.814 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:19.814 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:19.814 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:19.896 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:19.896 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:19.896 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:19.896 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:19.896 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:19.896 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:19.896 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:19.896 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:19.896 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:19.896 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:19.925 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:19.925 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:19.925 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:19.925 DTC Client socket (2) | Closed. | 2023-11-14 10:53:19.925 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:19.925 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:19.925 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:19.926 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:21.919 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:21.919 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:21.920 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:21.920 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:21.920 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:21.949 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:21.949 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:21.949 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:21.949 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:22.039 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:22.039 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:22.039 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:22.039 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:22.039 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:22.039 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:22.039 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:22.039 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:22.039 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:22.039 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:22.066 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:22.066 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:22.066 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:22.066 DTC Client socket (2) | Closed. | 2023-11-14 10:53:22.066 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:22.066 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:22.066 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:22.066 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:24.060 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:24.060 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:24.064 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:24.064 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:24.064 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:24.090 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:24.090 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:24.090 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:24.090 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:24.175 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:24.175 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:24.175 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:24.175 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:24.175 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:24.175 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:24.176 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:24.176 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:24.176 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:24.176 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:24.202 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:24.202 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:24.202 DTC Client socket (2) | Closed. | 2023-11-14 10:53:24.202 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:24.202 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:24.202 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:24.202 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:24.202 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:26.199 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:26.199 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:26.200 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:26.200 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:26.200 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:26.226 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:26.226 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:26.226 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:26.226 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:26.309 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:26.309 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:26.309 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:26.309 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:26.309 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:26.309 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:26.309 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:26.309 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:26.309 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:26.309 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:26.335 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:26.335 DTC Client socket (2) | Max send buffers used during socket life: 3 | 2023-11-14 10:53:26.335 DTC Client socket (2) | Max send buffer size during socket life: 1207 | 2023-11-14 10:53:26.335 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:26.335 DTC Client socket (2) | Closed. | 2023-11-14 10:53:26.335 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:26.335 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:26.336 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:26.336 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:26.336 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:28.337 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:28.337 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:28.338 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:28.338 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:28.338 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:28.367 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:28.367 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:28.367 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:28.367 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:28.453 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:28.453 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:28.453 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:28.453 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:28.453 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:28.453 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:28.453 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:28.453 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:28.453 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:28.453 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:28.480 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:28.504 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:28.504 DTC Client socket (2) | Closed. | 2023-11-14 10:53:28.504 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:28.504 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:28.504 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:28.504 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:28.504 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:30.579 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:30.579 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:30.579 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:30.579 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:30.579 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:30.621 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:30.621 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:30.621 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:30.621 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:30.698 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:30.698 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:30.698 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:30.698 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:30.698 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:30.698 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:30.698 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:30.698 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:30.698 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:30.698 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:30.725 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:30.725 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:30.725 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:30.725 DTC Client socket (2) | Closed. | 2023-11-14 10:53:30.725 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:30.725 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:30.725 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:30.725 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:32.727 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:32.727 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:32.728 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:32.728 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:32.728 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:32.753 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:32.753 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:32.753 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:32.753 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:32.831 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:32.831 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:32.831 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:32.831 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:32.831 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:32.831 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:32.831 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:32.831 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:32.831 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:32.831 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:32.855 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:32.855 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2023-11-14 10:53:32.855 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:32.855 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:32.855 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:32.855 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:32.855 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2023-11-14 10:53:32.880 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:32.880 DTC Client socket (2) | Closed. | 2023-11-14 10:53:32.880 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:34.850 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:34.850 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:34.851 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:34.851 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:34.851 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:34.879 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:34.879 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:34.879 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:34.879 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:34.973 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:34.973 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:34.973 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:34.973 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:34.973 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:34.974 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:34.974 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:34.974 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:34.974 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:34.974 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:35.001 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:35.005 DTC Client socket (2) | Max send buffers used during socket life: 3 | 2023-11-14 10:53:35.005 DTC Client socket (2) | Max send buffer size during socket life: 1207 | 2023-11-14 10:53:35.005 DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2023-11-14 10:53:35.005 * DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:35.005 DTC Client socket (2) | Closed. | 2023-11-14 10:53:35.005 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:35.005 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:35.006 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:35.006 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:35.006 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:37.045 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:37.045 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:37.045 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:37.045 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:37.045 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:37.077 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:37.077 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:37.077 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:37.077 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:37.160 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:37.160 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:37.160 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:37.160 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:37.160 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:37.160 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:37.161 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:37.161 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:37.161 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:37.161 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:37.189 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:37.189 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:37.189 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:37.189 DTC Client socket (2) | Closed. | 2023-11-14 10:53:37.189 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:37.189 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:37.189 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:37.189 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:39.186 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:39.186 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:39.193 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:39.193 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:39.193 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:39.221 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:39.221 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:39.221 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:39.221 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:39.305 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:39.305 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:39.305 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:39.305 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:39.305 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:39.305 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:39.305 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:39.305 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:39.305 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:39.305 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:39.333 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:39.333 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:39.333 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:39.333 DTC Client socket (2) | Closed. | 2023-11-14 10:53:39.333 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:39.334 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:39.334 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:39.334 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:41.321 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:41.321 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:41.321 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:41.321 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:41.321 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:41.347 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:41.347 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:41.347 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:41.347 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:41.424 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:41.424 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:41.424 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:41.424 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:41.424 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:41.424 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:41.424 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:41.424 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:41.424 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:41.424 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:41.449 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:41.451 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:41.451 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:41.451 DTC Client socket (2) | Closed. | 2023-11-14 10:53:41.451 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:41.451 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:41.451 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:41.451 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:43.474 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:43.474 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:43.474 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:43.474 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:43.474 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:43.500 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:43.500 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:43.500 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:43.500 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:43.577 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:43.577 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:43.577 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:43.577 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:43.577 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:43.577 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:43.577 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:43.577 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:43.577 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:43.577 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:43.603 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:43.612 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:43.612 DTC Client socket (2) | Closed. | 2023-11-14 10:53:43.612 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:43.613 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:43.613 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:43.613 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:43.613 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:45.611 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:45.611 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:45.612 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:45.612 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:45.612 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:45.638 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:45.638 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:45.638 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:45.638 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:45.724 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:45.724 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:45.724 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:45.724 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:45.724 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:45.724 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:45.724 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:45.724 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:45.724 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:45.724 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:45.749 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:45.749 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:45.750 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:45.750 DTC Client socket (2) | Closed. | 2023-11-14 10:53:45.750 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:45.750 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:45.750 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:45.750 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:47.744 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:47.744 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:47.744 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:47.744 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:47.744 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:47.771 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:47.771 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:47.771 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:47.771 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:47.855 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:47.855 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:47.855 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:47.855 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:47.855 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:47.855 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:47.855 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:47.855 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:47.855 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:47.855 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:47.883 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:47.883 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:47.883 DTC Client socket (2) | Closed. | 2023-11-14 10:53:47.883 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:47.883 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:47.883 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:47.883 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:47.883 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 10:53:49.883 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501 | 2023-11-14 10:53:49.883 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 10:53:49.883 DTC Client socket (2) | New receive buffer size: 0 | 2023-11-14 10:53:49.883 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 10:53:49.883 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2023-11-14 10:53:49.910 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2023-11-14 10:53:49.910 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2023-11-14 10:53:49.910 Rithmic Direct - DTC (Data) | Sending logon request message. | 2023-11-14 10:53:49.910 Rithmic Direct - DTC (Data) | Received logon response. | 2023-11-14 10:53:49.996 Rithmic Direct - DTC (Data) | Server Name: . | 2023-11-14 10:53:49.996 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2023-11-14 10:53:49.996 Rithmic Direct - DTC (Data) | Successfully connected. | 2023-11-14 10:53:49.996 Rithmic Direct - DTC (Data) | Trading is not supported. | 2023-11-14 10:53:49.996 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2023-11-14 10:53:49.996 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:49.996 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME. Market Depth data restarted. | 2023-11-14 10:53:49.996 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:49.996 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ23-CME. Market Depth data restarted. | 2023-11-14 10:53:49.996 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-14 10:53:50.023 DTC Client socket (2) | CloseSocket call. | 2023-11-14 10:53:50.023 DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2023-11-14 10:53:50.023 * DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 10:53:50.023 DTC Client socket (2) | Closed. | 2023-11-14 10:53:50.023 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2023-11-14 10:53:50.023 DTC Client socket (0) | CloseSocket call. | 2023-11-14 10:53:50.023 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2023-11-14 10:53:50.023 Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-14 10:53:50.023 Date Time Of Last Edit: 2023-11-14 17:06:38
[2023-11-14 17:05:16] |
Sierra_Chart Engineering - Posts: 17179 |
We definitively cannot help you at all with this. Unless you want to use the Denali Data Feed: Rithmic Trading Platform Service: Rithmic Market Data and Support Policy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-14 17:32:35] |
meeks - Posts: 7 |
I managed to get it to work again. Had to "translate symbols to current service" a few times, but seems to be OK now.
[2023-11-14 19:32:01] |
There should not be a disconnection even if incorrect symbols are used. There still is an issue on the Rithmic side. It does not make sense why you would have to translate the symbols multiple times. Once is enough. We think the resolution of the issue is only coincidental and you are going to have further issues later on. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-14 22:32:18] |
meeks - Posts: 7 |
Not sure if this is the root cause, but I had an instance of Rithmic Trader running at the same time. I tried logging in the RTrader web app at the same time as well and got an error message stating I could only run one instance/connection at a time. I closed out of RTrader completely (web app and desktop app) and then the connection to SierraChart was fine.
[2023-11-14 23:01:05] |
meeks - Posts: 7 |
You were correct. I'm running into a different issue now. Everything was working fine, but now it is no longer able to connect, but the message log is different this time. Are you able to take a look? HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2023-11-14 17:54:11.481 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0 | 2023-11-14 17:54:11.481 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89. | 2023-11-14 17:54:11.481 Reading Internal Order ID file. | 2023-11-14 17:54:11.505 Reading Trade Orders file. | 2023-11-14 17:54:11.540 Reading Trade Positions file. | 2023-11-14 17:54:11.540 Reading Trade Account Data files. | 2023-11-14 17:54:11.540 Software version: 2560 64-bit | 2023-11-14 17:54:11.541 Primary Thread ID: 34996 | 2023-11-14 17:54:11.541 Usage end date: 2023-12-21 | 2023-11-14 17:54:11.541 Enabled for: Advanced Features 2. | 2023-11-14 17:54:11.541 Enabled for: Sierra Chart Historical Data Service. | 2023-11-14 17:54:11.541 Enabled for: Denali Real-Time Exchange Data Feed. | 2023-11-14 17:54:11.541 Enabled for: Delayed Denali Exchange Data Feed. | 2023-11-14 17:54:11.541 Allow Support for Sierra Chart Data Feeds is enabled. | 2023-11-14 17:54:11.541 Current selected Data/Trading service: Rithmic Direct - DTC | 2023-11-14 17:54:11.541 Custom symbol settings values: enabled | 2023-11-14 17:54:11.541 Chart Update Interval: 500 | 2023-11-14 17:54:11.541 Intraday Data Storage Time Unit: 0 | 2023-11-14 17:54:11.541 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2023-11-14 17:54:11.541 2023-11-14 22:54:11 Local computer time in UTC | 2023-11-14 17:54:11.541 2023-11-14 17:54:11 Local computer time in SC Time Zone | 2023-11-14 17:54:11.541 2023-11-14 22:54:10 Server time in UTC | 2023-11-14 17:54:11.541 Local computer UTC time and Server UTC time difference: 1 seconds. | 2023-11-14 17:54:11.541 Program path: D:\SierraChart\ | 2023-11-14 17:54:11.541 Data Files path: D:\SierraChart\Data\ | 2023-11-14 17:54:11.541 OS Version Number: 10.0 | 2023-11-14 17:54:11.541 Locale Setting: C | 2023-11-14 17:54:11.541 DLLs: UserContributedStudies_64.dll | 2023-11-14 17:54:11.541 Allowed protected custom studies: | 2023-11-14 17:54:11.541 Crash reporter started: true | 2023-11-14 17:54:11.541 Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. | 2023-11-14 17:54:11.554 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-11-14 17:54:11.593 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2023-11-14 17:54:11.606 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2023-11-14 17:54:11.606 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | CloseSocket call. | 2023-11-14 17:54:11.607 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 17:54:11.607 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Closed. | 2023-11-14 17:54:11.607 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-11-14 17:54:11.657 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-11-14 17:54:11.657 Received 5 login tokens. | 2023-11-14 17:54:11.782 Symbol settings MD5 received. Request ID: 1. | 2023-11-14 17:54:13.158 Symbol settings are up-to-date for rithmic_v2.trading. | 2023-11-14 17:54:13.158 Requested user files to download. | 2023-11-14 17:54:14.065 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 17:54:16.050 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2023-11-14 17:54:16.051 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-11-14 17:54:16.051 DTC Client socket (1) | New receive buffer size: 0 | 2023-11-14 17:54:16.051 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2023-11-14 17:54:16.051 Rithmic Direct - DTC | Network connection to server complete. | 2023-11-14 17:54:16.077 Rithmic Direct - DTC | Starting socket receive thread. | 2023-11-14 17:54:16.077 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-11-14 17:54:16.077 Rithmic Direct - DTC | Sending logon request message. | 2023-11-14 17:54:16.077 Files to Open on Startup | Opening file: TPA Chartbook.Cht | 2023-11-14 17:54:19.270 ESZ3.CME #1 | Reloading chart. | 2023-11-14 17:54:19.283 ESZ3.CME 5 Min #2 | Reloading chart. | 2023-11-14 17:54:19.296 ESZ3.CME #3 | Reloading chart. | 2023-11-14 17:54:19.381 ESZ3.CME 1 Min #4 | Reloading chart. | 2023-11-14 17:54:19.389 ESZ3.CME 3.00 Range #5 | Reloading chart. | 2023-11-14 17:54:19.408 ESZ3.CME #6 | Reloading chart. | 2023-11-14 17:54:19.427 NQZ3.CME #8 | Reloading chart. | 2023-11-14 17:54:19.445 NQZ3.CME 5.00 Range #9 | Reloading chart. | 2023-11-14 17:54:19.467 ESZ3.CME/MESZ3.CME #10 | Reloading chart. | 2023-11-14 17:54:19.563 ESZ3.CME [CB] #11 | Reloading chart. | 2023-11-14 17:54:19.578 Starting DelayedDownloadMonitoringTimer | 2023-11-14 17:54:19.580 Starting HDTimeoutTimer | 2023-11-14 17:54:19.580 Added historical Intraday data request for ESM3.CME to the queue. | 2023-11-14 17:54:19.580 Triggering next historical data download in queue. | 2023-11-14 17:54:19.581 Added historical Intraday data request for ESU3.CME to the queue. | 2023-11-14 17:54:19.582 ESZ3.CME [CB] #11 | Waiting for historical downloads to complete with the IDs: 1, 2, | 2023-11-14 17:54:19.609 Searching for files containing sst_draw_imbalance returned empty result. | 2023-11-14 17:54:19.611 * Error loading: D:\SierraChart\Data\sst_draw_imbalance.dll. File not found or may be missing SCDLLName line. | 2023-11-14 17:54:19.611 Searching for files containing sst_FreeBundle returned empty result. | 2023-11-14 17:54:19.611 * Error loading: D:\SierraChart\Data\sst_FreeBundle.dll. File not found or may be missing SCDLLName line. | 2023-11-14 17:54:19.611 ESZ3.CME Renko 8t #12 | Reloading chart. | 2023-11-14 17:54:19.624 ESZ3.CME [CV] #13 | Reloading chart. | 2023-11-14 17:54:19.643 Added historical Intraday data request for ESZ2.CME to the queue. | 2023-11-14 17:54:19.644 Added historical Intraday data request for ESH3.CME to the queue. | 2023-11-14 17:54:19.644 ESZ3.CME [CV] #13 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2023-11-14 17:54:19.675 ESZ3.CME 1.25 Range #14 | Reloading chart. | 2023-11-14 17:54:19.696 ESZ3.CME 3.00 Range #15 | Reloading chart. | 2023-11-14 17:54:19.721 MESZ3.CME 2.50 Range #16 | Reloading chart. | 2023-11-14 17:54:19.747 ESZ3.CME [C] 3.00 Range #17 | Reloading chart. | 2023-11-14 17:54:19.780 Loading market depth data. | 2023-11-14 17:54:19.794 ESZ3.CME 3.00 Range #19 | Reloading chart. | 2023-11-14 17:54:19.799 ESZ3.CME [C] #21 | Reloading chart. | 2023-11-14 17:54:19.822 ESZ3.CME [C] #21 | Waiting for historical downloads to complete with the IDs: 2, | 2023-11-14 17:54:19.823 ESZ3.CME [C] #22 | Reloading chart. | 2023-11-14 17:54:19.852 ESZ3.CME 10 Sec #23 | Reloading chart. | 2023-11-14 17:54:19.884 Loaded depth data records for MESZ3.CME 2023-11-14 from 2023-11-14 11:06:00.000000 to 2023-11-14 16:59:59.000000. | 2023-11-14 17:54:19.893 Using symbol data fast lookup vector | 2023-11-14 17:54:19.904 HD Request # 1 | Downloading Intraday chart data for ESM3.CME to the file ESM3.CME.scid. Service: rithmic.trading | 2023-11-14 17:54:19.905 HD Request # 1 | Download start date-time: 2023-03-31 11:18:37.000000. File last date-time: 2023-03-31 11:18:37.761018 | 2023-11-14 17:54:19.906 HD Request # 1 | Using server: rsc.rithmic.com port 50502. Use encryption. | 2023-11-14 17:54:19.909 Socket (2) | Creating socket. Using TLS 1.2. | 2023-11-14 17:54:19.909 Socket (2) | New receive buffer size: 0 | 2023-11-14 17:54:19.909 Socket (2) | Connecting to IP: 216.57.156.163. | 2023-11-14 17:54:19.909 MESZ3.CME 2.50 Range #16 | StartDateTimeForLoadingOrderFills: 2023-10-31 16:59:59 | 2023-11-14 17:54:19.918 HD Request # 1 | Sending historical data logon request message. | 2023-11-14 17:54:19.935 Added historical Intraday data request for ESZ3.CME to the queue. | 2023-11-14 17:54:19.949 Intraday data recording state for symbol ESZ3.CME is set to download 'Pending'. | 2023-11-14 17:54:19.949 Triggering next historical data download in queue. | 2023-11-14 17:54:19.949 Loading market depth data. | 2023-11-14 17:54:20.005 HD Request # 1 | Requesting Intraday data. Start date-time: 2023-03-31 11:18:37. Record interval: 0. Symbol: ESM3.CME | 2023-11-14 17:54:20.014 Added historical Intraday data request for NQZ3.CME to the queue. | 2023-11-14 17:54:20.019 Intraday data recording state for symbol NQZ3.CME is set to download 'Pending'. | 2023-11-14 17:54:20.019 Triggering next historical data download in queue. | 2023-11-14 17:54:20.019 HD Request # 1 | Receiving Intraday data for ESM3.CME starting at 2023-03-31 11:18:37.188000 | 2023-11-14 17:54:20.045 Loaded depth data records for ESZ3.CME 2023-11-14 from 2023-11-14 11:06:00.000000 to 2023-11-14 17:45:00.000000. | 2023-11-14 17:54:20.132 Added historical Intraday data request for MESZ3.CME to the queue. | 2023-11-14 17:54:20.240 Intraday data recording state for symbol MESZ3.CME is set to download 'Pending'. | 2023-11-14 17:54:20.240 Triggering next historical data download in queue. | 2023-11-14 17:54:20.241 ESZ3.CME 10 Sec #23 | Reloading chart. | 2023-11-14 17:54:20.383 HD Request # 1 | Timestamp of first Intraday data file record written: 2023-03-31 11:18:37.762000. | 2023-11-14 17:54:20.393 Loading market depth data. | 2023-11-14 17:54:20.491 Loaded depth data records for ESZ3.CME 2023-11-14 from 2023-11-14 11:06:00.000000 to 2023-11-14 17:45:00.000000. | 2023-11-14 17:54:20.603 Loading market depth data. | 2023-11-14 17:54:20.710 Loaded depth data records for ESZ3.CME 2023-11-14 from 2023-11-14 10:06:00.000000 to 2023-11-14 16:45:00.000000. | 2023-11-14 17:54:20.818 ESZ3.CME Renko 8t #12 | Reloading chart. | 2023-11-14 17:54:21.116 Chart #8 has tagged chart #23 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:21.459 Loading market depth data. | 2023-11-14 17:54:22.026 Loading market depth data. | 2023-11-14 17:54:22.130 Loaded depth data records for NQZ3.CME 2023-11-14 from 2023-11-14 11:06:00.000000 to 2023-11-14 16:59:59.000000. | 2023-11-14 17:54:22.162 Chart #9 has tagged chart #23 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:22.198 Loaded depth data records for ESZ3.CME 2023-11-14 from 2023-11-14 10:06:00.000000 to 2023-11-14 16:45:00.000000. | 2023-11-14 17:54:22.227 ESZ3.CME #3 | StartDateTimeForLoadingOrderFills: 2023-10-05 18:00:00 | 2023-11-14 17:54:24.109 ESZ3.CME/MESZ3.CME #10 | StartDateTimeForLoadingOrderFills: 2023-10-05 18:00:00 | 2023-11-14 17:54:24.345 ESZ3.CME [C] 3.00 Range #17 | StartDateTimeForLoadingOrderFills: 2023-10-15 18:00:00 | 2023-11-14 17:54:25.371 Loading market depth data. | 2023-11-14 17:54:28.023 Loaded depth data records for ESZ3.CME 2023-11-14 from 2023-11-14 11:06:00.000000 to 2023-11-14 16:59:59.000000. | 2023-11-14 17:54:28.098 ESZ3.CME 3.00 Range #5 | StartDateTimeForLoadingOrderFills: 2023-08-16 18:03:28 | 2023-11-14 17:54:28.099 Loading market depth data. | 2023-11-14 17:54:28.323 Loaded depth data records for ESZ3.CME 2023-11-14 from 2023-11-14 11:06:00.000000 to 2023-11-14 16:59:59.000000. | 2023-11-14 17:54:28.398 Loading market depth data. | 2023-11-14 17:54:28.404 Chart #14 has tagged chart #16 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:28.427 Chart #14 has tagged chart #5 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:28.427 Chart #14 has tagged chart #9 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:28.427 Loaded depth data records for ESZ3.CME 2023-11-14 from 2023-11-14 11:06:00.000000 to 2023-11-14 17:45:00.000000. | 2023-11-14 17:54:28.480 Chart #19 has tagged chart #14 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:28.499 Chart #19 has tagged chart #16 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:28.499 Chart #19 has tagged chart #5 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:28.499 Chart #19 has tagged chart #9 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:28.499 Loading market depth data. | 2023-11-14 17:54:29.778 Loaded depth data records for ESZ3.CME 2023-11-14 from 2023-11-14 11:06:00.000000 to 2023-11-14 16:59:59.000000. | 2023-11-14 17:54:29.855 ESZ3.CME 3.00 Range #15 | StartDateTimeForLoadingOrderFills: 2023-08-16 18:03:28 | 2023-11-14 17:54:29.856 ESZ3.CME 10 Sec #23 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:29.924 ESZ3.CME 3.00 Range #5 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:29.942 NQZ3.CME 5.00 Range #9 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:29.963 Chart #9 has tagged chart #22 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:30.010 Chart #9 has tagged chart #23 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:30.010 ESZ3.CME 1.25 Range #14 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:30.194 Circular chart reference detected. Charts: 19, 14. Chartbook: TPA Chartbook.Cht. | 2023-11-14 17:54:30.242 Chart #14 has tagged chart #5 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:30.242 Chart #14 has tagged chart #9 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:30.242 MESZ3.CME 2.50 Range #16 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:30.251 ESZ3.CME [C] #22 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:30.350 ESZ3.CME 10 Sec #23 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:30.381 ESZ3.CME 3.00 Range #5 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:30.398 NQZ3.CME 5.00 Range #9 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:30.463 Chart #9 has tagged chart #22 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:30.511 Chart #9 has tagged chart #23 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:30.511 ESZ3.CME [C] #22 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:30.850 ESZ3.CME 10 Sec #23 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:54:30.881 HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | Creating socket. Using TLS 1.2. | 2023-11-14 17:54:36.053 HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | New receive buffer size: 0 | 2023-11-14 17:54:36.053 HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | Connecting to IP: 38.79.0.89. | 2023-11-14 17:54:36.053 HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | Socket gracefully closed by remote side. | 2023-11-14 17:54:36.115 HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | Socket gracefully closed by remote side. | 2023-11-14 17:54:36.115 HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | CloseSocket call. | 2023-11-14 17:54:36.115 HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 17:54:36.115 HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | Closed. | 2023-11-14 17:54:36.115 Service connection timed out. Will disconnect and retry. | 2023-11-14 17:55:01.053 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-14 17:55:01.053 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-14 17:55:01.053 Rithmic Direct - DTC | Failed connections: 1 | 2023-11-14 17:55:01.069 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-11-14 17:55:01.069 DTC Client socket (1) | CloseSocket call. | 2023-11-14 17:55:01.069 Rithmic Direct - DTC | Disconnected. | 2023-11-14 17:55:01.069 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-14 17:55:01.069 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-11-14 17:55:01.069 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-11-14 17:55:01.094 DTC Client socket (1) | Closed. | 2023-11-14 17:55:01.094 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 17:55:05.069 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2023-11-14 17:55:05.069 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-11-14 17:55:05.069 DTC Client socket (1) | New receive buffer size: 0 | 2023-11-14 17:55:05.069 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2023-11-14 17:55:05.069 Rithmic Direct - DTC | Network connection to server complete. | 2023-11-14 17:55:05.093 Rithmic Direct - DTC | Starting socket receive thread. | 2023-11-14 17:55:05.093 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-11-14 17:55:05.094 Rithmic Direct - DTC | Sending logon request message. | 2023-11-14 17:55:05.094 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Creating socket. Using TLS 1.2. | 2023-11-14 17:55:25.074 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | New receive buffer size: 0 | 2023-11-14 17:55:25.074 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Connecting to IP: 38.79.0.89. | 2023-11-14 17:55:25.074 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Socket gracefully closed by remote side. | 2023-11-14 17:55:25.135 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Socket gracefully closed by remote side. | 2023-11-14 17:55:25.135 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | CloseSocket call. | 2023-11-14 17:55:25.135 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 17:55:25.135 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Closed. | 2023-11-14 17:55:25.135 Service connection timed out. Will disconnect and retry. | 2023-11-14 17:55:50.075 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-14 17:55:50.075 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-14 17:55:50.075 Rithmic Direct - DTC | Failed connections: 2 | 2023-11-14 17:55:50.090 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-11-14 17:55:50.090 DTC Client socket (1) | CloseSocket call. | 2023-11-14 17:55:50.091 Rithmic Direct - DTC | Disconnected. | 2023-11-14 17:55:50.091 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-14 17:55:50.091 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-11-14 17:55:50.091 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-11-14 17:55:50.116 DTC Client socket (1) | Closed. | 2023-11-14 17:55:50.116 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 17:55:54.089 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2023-11-14 17:55:54.089 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-11-14 17:55:54.113 DTC Client socket (1) | New receive buffer size: 0 | 2023-11-14 17:55:54.113 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2023-11-14 17:55:54.113 Rithmic Direct - DTC | Network connection to server complete. | 2023-11-14 17:55:54.137 Rithmic Direct - DTC | Starting socket receive thread. | 2023-11-14 17:55:54.137 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-11-14 17:55:54.137 Rithmic Direct - DTC | Sending logon request message. | 2023-11-14 17:55:54.137 HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (3) | Creating socket. Using TLS 1.2. | 2023-11-14 17:56:14.089 HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (3) | New receive buffer size: 0 | 2023-11-14 17:56:14.089 HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (3) | Connecting to IP: 38.79.0.89. | 2023-11-14 17:56:14.089 HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (3) | Socket gracefully closed by remote side. | 2023-11-14 17:56:14.178 HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (3) | CloseSocket call. | 2023-11-14 17:56:14.178 HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 17:56:14.179 HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (3) | Closed. | 2023-11-14 17:56:14.179 Service connection timed out. Will disconnect and retry. | 2023-11-14 17:56:39.083 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-14 17:56:39.083 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-14 17:56:39.083 Rithmic Direct - DTC | Failed connections: 3 | 2023-11-14 17:56:39.099 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-11-14 17:56:39.100 DTC Client socket (1) | CloseSocket call. | 2023-11-14 17:56:39.100 Rithmic Direct - DTC | Disconnected. | 2023-11-14 17:56:39.100 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-14 17:56:39.100 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-11-14 17:56:39.100 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-11-14 17:56:39.125 DTC Client socket (1) | Closed. | 2023-11-14 17:56:39.125 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 17:56:43.102 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2023-11-14 17:56:43.102 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-11-14 17:56:43.106 DTC Client socket (1) | New receive buffer size: 0 | 2023-11-14 17:56:43.106 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2023-11-14 17:56:43.106 Rithmic Direct - DTC | Network connection to server complete. | 2023-11-14 17:56:43.133 Rithmic Direct - DTC | Starting socket receive thread. | 2023-11-14 17:56:43.133 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-11-14 17:56:43.133 Rithmic Direct - DTC | Sending logon request message. | 2023-11-14 17:56:43.133 HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (3) | Creating socket. Using TLS 1.2. | 2023-11-14 17:57:03.103 HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (3) | New receive buffer size: 0 | 2023-11-14 17:57:03.103 HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (3) | Connecting to IP: 38.79.0.89. | 2023-11-14 17:57:03.103 HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (3) | Socket gracefully closed by remote side. | 2023-11-14 17:57:03.161 HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (3) | Socket gracefully closed by remote side. | 2023-11-14 17:57:03.161 HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (3) | CloseSocket call. | 2023-11-14 17:57:03.162 HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 17:57:03.162 HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (3) | Closed. | 2023-11-14 17:57:03.162 Service connection timed out. Will disconnect and retry. | 2023-11-14 17:57:28.108 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-14 17:57:28.108 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-14 17:57:28.108 Rithmic Direct - DTC | Failed connections: 4 | 2023-11-14 17:57:28.124 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-11-14 17:57:28.124 DTC Client socket (1) | CloseSocket call. | 2023-11-14 17:57:28.124 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-11-14 17:57:28.124 Rithmic Direct - DTC | Disconnected. | 2023-11-14 17:57:28.124 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-14 17:57:28.124 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-11-14 17:57:28.153 DTC Client socket (1) | Closed. | 2023-11-14 17:57:28.153 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 17:57:32.125 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2023-11-14 17:57:32.125 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-11-14 17:57:32.127 DTC Client socket (1) | New receive buffer size: 0 | 2023-11-14 17:57:32.127 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2023-11-14 17:57:32.127 Rithmic Direct - DTC | Network connection to server complete. | 2023-11-14 17:57:32.154 Rithmic Direct - DTC | Starting socket receive thread. | 2023-11-14 17:57:32.154 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-11-14 17:57:32.154 Rithmic Direct - DTC | Sending logon request message. | 2023-11-14 17:57:32.154 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-11-14 17:57:41.088 DTC Client socket (1) | CloseSocket call. | 2023-11-14 17:57:41.088 Rithmic Direct - DTC | Disconnected. | 2023-11-14 17:57:41.088 Canceling queued historical data download request for ESU3.CME Intraday data. | 2023-11-14 17:57:41.088 Removing historical data download ID 2. | 2023-11-14 17:57:41.088 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-11-14 17:57:41.088 Canceling queued historical data download request for ESZ2.CME Intraday data. | 2023-11-14 17:57:41.088 Removing historical data download ID 3. | 2023-11-14 17:57:41.088 Canceling queued historical data download request for ESH3.CME Intraday data. | 2023-11-14 17:57:41.088 Removing historical data download ID 4. | 2023-11-14 17:57:41.088 Canceling queued historical data download request for ESZ3.CME Intraday data. | 2023-11-14 17:57:41.088 Removing historical data download ID 5. | 2023-11-14 17:57:41.088 Canceling queued historical data download request for NQZ3.CME Intraday data. | 2023-11-14 17:57:41.088 Removing historical data download ID 6. | 2023-11-14 17:57:41.088 Canceling queued historical data download request for MESZ3.CME Intraday data. | 2023-11-14 17:57:41.088 Removing historical data download ID 7. | 2023-11-14 17:57:41.088 HD Request # 1 | Active download canceled. | 2023-11-14 17:57:41.088 Historical data download thread signaled to stop. | 2023-11-14 17:57:41.088 Socket (2) | CloseSocket call. | 2023-11-14 17:57:41.088 Socket (2) | Shutdown started. Waiting for graceful close. | 2023-11-14 17:57:41.089 HD Request # 1 | Received 14888440 Intraday data records from 2023-03-31 11:18:37.188000 to 2023-04-25 16:41:17.919001 (25.2 days. Delay: 203.1 days) and wrote 14887958 records for ESM3.CME | 2023-11-14 17:57:41.089 HD Request # 1 | Completion time: 3m 22s. | 2023-11-14 17:57:41.089 HD Request # 1 | Intraday data download complete for ESM3.CME. Unique request ID: 1 | 2023-11-14 17:57:41.089 Removing historical data download ID 1. | 2023-11-14 17:57:41.089 HD Request # 1 | Enabling Intraday chart updating for symbol. | 2023-11-14 17:57:41.089 No download requests in the queue to start downloads for. | 2023-11-14 17:57:41.089 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-14 17:57:41.089 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-11-14 17:57:41.116 DTC Client socket (1) | Closed. | 2023-11-14 17:57:41.116 Chart #14 has tagged chart #16 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:41.328 Chart #14 has tagged chart #19 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:41.328 Chart #14 has tagged chart #5 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:41.328 Chart #14 has tagged chart #9 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:41.328 Chart #19 has tagged chart #14 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:41.407 Chart #19 has tagged chart #15 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:41.407 Chart #19 has tagged chart #16 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:41.407 Chart #19 has tagged chart #5 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:41.407 Chart #19 has tagged chart #9 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:41.407 Chart #8 has tagged chart #22 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:41.542 Chart #8 has tagged chart #23 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:41.542 Chart #9 has tagged chart #22 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:41.604 Chart #9 has tagged chart #23 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:41.604 ESZ3.CME [CB] #11 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-11-14 17:57:41.608 ESZ3.CME [CB] #11 | Reloading chart. | 2023-11-14 17:57:41.609 ESZ3.CME [CV] #13 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-11-14 17:57:41.671 ESZ3.CME [CV] #13 | Reloading chart. | 2023-11-14 17:57:41.672 ESZ3.CME [C] #21 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-11-14 17:57:41.843 ESZ3.CME [C] #21 | Reloading chart. | 2023-11-14 17:57:41.844 ESZ3.CME [CB] #11 | Reloading chart. | 2023-11-14 17:57:42.110 ESZ3.CME [CV] #13 | Reloading chart. | 2023-11-14 17:57:42.172 ESZ3.CME [C] #21 | Reloading chart. | 2023-11-14 17:57:42.344 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 17:57:45.078 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2023-11-14 17:57:45.078 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-11-14 17:57:45.078 DTC Client socket (1) | New receive buffer size: 0 | 2023-11-14 17:57:45.078 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2023-11-14 17:57:45.078 Rithmic Direct - DTC | Network connection to server complete. | 2023-11-14 17:57:45.102 Rithmic Direct - DTC | Starting socket receive thread. | 2023-11-14 17:57:45.102 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-11-14 17:57:45.102 Rithmic Direct - DTC | Sending logon request message. | 2023-11-14 17:57:45.102 Chart #21 has tagged chart #22 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:45.892 Chart #21 has tagged chart #23 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:45.892 Chart #21 has tagged chart #6 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:45.892 Chart #21 has tagged chart #8 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:45.892 ESZ3.CME [C] #22 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:49.875 ESZ3.CME 10 Sec #23 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:49.906 ESZ3.CME #6 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:49.938 NQZ3.CME #8 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:49.986 Circular chart reference detected. Charts: 21, 8. Chartbook: TPA Chartbook.Cht. | 2023-11-14 17:57:50.006 Chart #8 has tagged chart #22 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:50.006 Chart #8 has tagged chart #23 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:50.006 ESZ3.CME 1.25 Range #14 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:50.281 Chart #14 has tagged chart #16 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:50.333 Circular chart reference detected. Charts: 19, 14. Chartbook: TPA Chartbook.Cht. | 2023-11-14 17:57:50.333 Chart #14 has tagged chart #5 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:50.333 Chart #14 has tagged chart #9 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:50.333 ESZ3.CME 3.00 Range #15 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:50.333 MESZ3.CME 2.50 Range #16 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:50.367 ESZ3.CME [C] #22 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:50.375 ESZ3.CME 10 Sec #23 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:50.406 ESZ3.CME 3.00 Range #5 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:50.424 NQZ3.CME 5.00 Range #9 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:50.518 Chart #9 has tagged chart #22 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:50.566 Chart #9 has tagged chart #23 for full recalculation. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:50.566 ESZ3.CME [C] #22 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:50.875 ESZ3.CME 10 Sec #23 | Performing a full recalculation because it has been tagged. Chartbook: TPA Chartbook.Cht | 2023-11-14 17:57:50.906 HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (3) | Creating socket. Using TLS 1.2. | 2023-11-14 17:58:05.079 HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (3) | New receive buffer size: 0 | 2023-11-14 17:58:05.079 HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (3) | Connecting to IP: 38.79.0.89. | 2023-11-14 17:58:05.079 HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (3) | Socket gracefully closed by remote side. | 2023-11-14 17:58:05.135 HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (3) | Socket gracefully closed by remote side. | 2023-11-14 17:58:05.135 HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (3) | CloseSocket call. | 2023-11-14 17:58:05.136 HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 17:58:05.136 HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (3) | Closed. | 2023-11-14 17:58:05.136 Service connection timed out. Will disconnect and retry. | 2023-11-14 17:58:30.079 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-14 17:58:30.079 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-14 17:58:30.079 Rithmic Direct - DTC | Failed connections: 5 | 2023-11-14 17:58:30.095 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-11-14 17:58:30.095 DTC Client socket (1) | CloseSocket call. | 2023-11-14 17:58:30.096 Rithmic Direct - DTC | Disconnected. | 2023-11-14 17:58:30.096 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-14 17:58:30.096 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-11-14 17:58:30.097 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-11-14 17:58:30.122 DTC Client socket (1) | Closed. | 2023-11-14 17:58:30.122 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2023-11-14 17:58:34.095 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2023-11-14 17:58:34.095 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-11-14 17:58:34.096 DTC Client socket (1) | New receive buffer size: 0 | 2023-11-14 17:58:34.096 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2023-11-14 17:58:34.096 Rithmic Direct - DTC | Network connection to server complete. | 2023-11-14 17:58:34.123 Rithmic Direct - DTC | Starting socket receive thread. | 2023-11-14 17:58:34.123 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-11-14 17:58:34.123 Rithmic Direct - DTC | Sending logon request message. | 2023-11-14 17:58:34.123 HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (3) | Creating socket. Using TLS 1.2. | 2023-11-14 17:58:54.095 HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (3) | New receive buffer size: 0 | 2023-11-14 17:58:54.095 HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (3) | Connecting to IP: 38.79.0.89. | 2023-11-14 17:58:54.095 HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (3) | Socket gracefully closed by remote side. | 2023-11-14 17:58:54.145 HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (3) | Socket gracefully closed by remote side. | 2023-11-14 17:58:54.145 HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (3) | CloseSocket call. | 2023-11-14 17:58:54.145 HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-14 17:58:54.145 HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (3) | Closed. | 2023-11-14 17:58:54.145 File >> Disconnect selected. | 2023-11-14 17:58:59.110 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-11-14 17:58:59.110 DTC Client socket (1) | CloseSocket call. | 2023-11-14 17:58:59.110 Rithmic Direct - DTC | Disconnected. | 2023-11-14 17:58:59.110 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-11-14 17:58:59.110 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-11-14 17:58:59.137 DTC Client socket (1) | Closed. | 2023-11-14 17:58:59.137 Socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2023-11-14 18:00:05.254 Socket (2) | Closed. | 2023-11-14 18:00:05.254 |
[2023-11-15 16:52:42] |
John - SC Support - Posts: 36287 |
The only thing we can say is that you are having a problem connecting to Rithmic per the following lines in your log: Service connection timed out. Will disconnect and retry. | 2023-11-14 17:57:28.108 *
There is no other information given as to what or why this is occurring. You will have to check with Rithmic on this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
