Date/Time: Tue, 22 Sep 2026 11:21:32 +0000
Chart Trade Window Background - Simulation Mode not changing colour!
View Count: 649
| [2023-11-11 23:00:00] |
| J DIDDY - Posts: 156 |
HI The 'Chart Trade Window Background - Simulation Mode' is not changing colour. Pic attached showing I am in sim mode and the background colour should be red as shown in the options. I also changed The 'Chart Trade Mode Box - Simulation' and that HAS changed colour! I am on a mac using Crossover if that make a difference! Thx |
| [2023-11-11 23:11:52] |
| User719512 - Posts: 477 |
When you select the chart, and then choose Chart >> Graphics Settings - Chart, is the checkbox checked or unchecked for Use Global... ??? Also assuming you are on a current build to rule out anything there. works for me on v2564. You should not have to connect/disconnect or close/open your chartbooks, but could be good troubleshooting steps as well. |
| [2023-11-11 23:28:27] |
Thx User719512, Thats sorted it! You're a star! |
