Date/Time: Tue, 26 Nov 2024 12:48:47 +0000
Delta for TPO chart
View Count: 563
[2023-11-10 14:52:59] |
User117548 - Posts: 28 |
Hi team, I am looking for the way to add delta to my TPO chart. I try to use "Numbers Bars Calculated Values" to show, however, it does not work as expected ( please see the attachments). Please kindly help me to work it out! Thank you |
[2023-11-14 16:51:34] |
Sierra_Chart Engineering - Posts: 17179 |
Refer to: Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-23 02:03:32] |
Hi team, Thank you for your help! I got another issue when I am trying to use Study/Price Overlay study to copy study "Number bars calculated values" ( I put it in another chart, name "1") in TPO chart. It always convert "1" into 1 min timeframe, even I edit the "1" chart to 1 day timeframe, and as result, study "Number bars calculated values" shows in 1 min timeframe in my TPO chart. ( attached image) Could you please help me to work out this issue? Thank you again! |
Screenshot 2023-11-23 100255.png / V - Attached On 2023-11-23 02:03:18 UTC - Size: 86.15 KB - 105 views |
[2023-11-26 23:35:18] |
LudaTrades - Posts: 27 |
The easiest way to add delta to a TPO chart is from the volume profile study. I see in your screenshot you already have volume profile set up for your TPO chart. To add delta to this, go to the study settings for the volume by price and select an option for Show Chart Values On Profile, select a position for the values, and under one of the four chart values to display, select Ask Volume - Bid Volume.
[2023-11-27 15:36:52] |
Why do you want to copy a Numbers Bars Calculated Values study: I got another issue when I am trying to use Study/Price Overlay study to copy study "Number bars calculated values" ( I put it in another chart, name "1") in TPO chart. It always convert "1" into 1 min timeframe, even I edit the "1" chart to 1 day timeframe, and as result, study "Number bars calculated values" shows in 1 min timeframe in my TPO chart. ( attached image) This is not going to work in a TPO Chart anyway: Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-27 15:37:02
[2023-11-28 15:12:24] |
Hi team, I got what I want from Luda reply!! Really thank you |
