Date/Time: Tue, 26 Nov 2024 16:42:08 +0000
[Programming Help] - Version 2563 breaks studies compiled with previous sierrachart versions
View Count: 348
[2023-11-08 18:41:49]
erwinbeckers - Posts: 22
We have a few studies that were initially created& compiled using Sierra Chart version 2561.
These studies have been distributed to our customers via Sierra Chart distribution system.
However, today, we received a complaint from a customer who recently updated to SierraChart version 2563, reporting that our studies were no longer functioning properly.
Upon investigation, we found that the issue was related to the sc.Graphics.GetTextSize() function, which was causing crashes.
Importantly, this problem only arises when the study was originally compiled with earlier SierraChart versions.
Interestingly, if we recompile the study with version 2563, it works perfectly again.
Here's the challenge: If we release the recompiled version specifically for SierraChart version 2563, it will cease to function for all our other customers who are currently using version 2561.
In essence, this would require all our customers to update to version 2563.
We would greatly appreciate your guidance on how to address this situation effectively.
Best regards,
Erwin
Date Time Of Last Edit: 2023-11-08 18:57:08
[2023-11-08 19:22:20]
Sierra_Chart Engineering - Posts: 17182
We do not know why this is happening. There were no changes that should cause a problem.
We also do not like passing a structure as a return value. We are changing this to pass it by reference.
We will be changing this function in the next release and we will put this out today, this evening. You will need to make code changes to support the changes we have done and release a new version and those users will have to run version 2564 or higher to use the study. They will be forced, to run that version because simply the study will not work unless they are running 2564 or higher. There is no other possibility.
Date Time Of Last Edit: 2023-11-08 19:22:50
[2023-11-08 19:33:44]
Ok thanks for the quick response
Can we make it more obvious to the user that he needs to upgrade to version xxxx if a study requires that?
Now people start their Sierra Chart and suddenly their study doesn't work any longer
what then happens is that they will start submitting support tickets to our company and our support team has to tell each of them to upgrade
It would be nicer and more user friendly if Sierra Chart presented a popup describing the problem with an update now button
[2023-11-08 19:41:09]
There is a message added in the Message Log that the study requires a newer version and that also is shown in the Chart Studies window with the study.
[2023-11-08 19:43:42]
Yes I have seen that message, but that's not very user-friendly
Many people don't read the log and will just click it away and call us for support
That's why I'm asking if it would be possible to show a popup saying "Hey this study need Sierra Chart version xxxx. Press here to upgrade"
[2023-11-08 19:53:38]
No, this is not supported. This is not something we are going to be doing.
[2023-11-08 20:12:24]
Why not? I mean, of course, I can understand that you will not start on this immediately.
But to me, it sounds like something that would benefit everyone and is not too hard to implement.
It would make the lives of our customers easier since they won't be confused anymore about why the study they bought suddenly stopped working.
And it would also benefit us as study developers/sellers since we don't have to deal with that many support calls when we are forced ( by Sierra Chart breaking changes) to release a new version of the study to support the latest Sierra Chart version
regards
Erwin
[2023-11-08 20:20:02]
Please do not ask further about this. We are not going to do anything further on this and we have made that abundantly clear.
Also the ACSIL graphics functionality is very new and potentially could change early on. While it is intended to be stable, we had to do this one change. Very few users are affected by this.
Date Time Of Last Edit: 2023-11-08 20:27:00
[2023-11-08 20:37:41]
Let me start by saying that I really appreciate Sierra Chart as a great platform.
However, I'm a bit disappointed in the way support has handled the communication regarding people creating studies to promote the Sierra platform.
I genuinely believe that these studies have the potential to attract more customers for both of us and will be a positive addition to the community.
As a developer myself, I understand that breaking changes can happen, but it's frustrating to see these issues being brushed aside, leaving customers and study developers to fix them on their own.
With that in mind, I respect your perspective, and I'll leave it at that.
Erwin
[2023-11-08 21:47:25]
We did make some improvement with this by including in the text message that is shown on the chart and in the Chart Studies window, the text "Select 'Help >> Download Current Version'".
This is all we can do. Otherwise, your request is a development task and we just cannot do that.
This is not true at all:
We are taking immediate action to ensure that ACSIL is working properly. There is nothing for you to fix but there is a code change which will be required.
