Date/Time: Tue, 26 Nov 2024 17:40:26 +0000
Multiple Data Feeds
View Count: 268
[2023-11-02 12:41:17]
User478380 - Posts: 184
Hi
Where can I tell what data feed I am connected to - I think its Denali at present.
How do you connect and disconnect the actual data feed if I have MORE than one data feed?
[2023-11-02 14:46:23]
John - SC Support - Posts: 36300
In general - you will get the data from us for the exchanges that you have activated with us. Any other data would come from your trading service.
In your case, you have the "CME Non-Professional Top-of-Book" exchange active, so any instrument traded on the CME exchange (not the full CME Group) will come from us, any other data would come from your trading provider (whomever you are connected to in Data/Trade Service Settings).
You can verify that the data is coming from us if you see an [M] showing after the symbol name in the Chart Header. Refer to the following on this:
Chart Data and Chart Data Files: The Meaning of the [M] Designation after a Symbol
If you do not want the data to come from our Denali Exchange Data Feed, then you need to set the option for "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" to "No". Then select OK to close that page and then select "File >> Reconnect" to force the change to take place. Any time you change this setting, you will need to reconnect to the data feed.
If you turn that option to "No" then the data that you were getting from our Denali feed will now come from the service you are connected to in the Data/Trade Service Settings, just like any other data you were not setup to get from us.
[2023-11-02 18:14:00]
If I use both sierra and ninja trader 8, can I switch the denali feed into ninja trader or is that not possible please?
[2023-11-02 19:20:15]
The Denali Exchange Data Feed only works with Sierra Chart. It does not work with any other vendor.
