Date/Time: Tue, 26 Nov 2024 14:41:20 +0000
Trading UK & France index futures
View Count: 536
[2023-10-23 16:23:52] |
User132992 - Posts: 34 |
Hi support guys, Is it possible to trade FTSE 100 and CAC 40 futures contracts with SC? If so, what data feed would I need to subscribe to? V much appreciated, ND |
[2023-10-23 17:28:27] |
John - SC Support - Posts: 36287 |
We do not have real-time data for either of these futures products. You would have to see if either CQG or Rithmic have this data and then find a broker that supports that order routing service. You can then get the data into Sierra Chart and trade it with that service. Another option is to check with Interactive Brokers, as we also have support for them. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-23 17:46:20] |
uM8137 - Posts: 183 |
You can use IQFeed for data (e.g. symbols MFCZ23 for CAC40 futures, LFZ23 for FTSE100 futures), and separately, execution through your broker (find a broker that supports them; IBKR almost surely does, others you'll have to ask the broker directly. For data, you rarely want to use IBKR (Interactive Brokers) for data, since it is pulsed (only every 100ms or 250ms, and missing lots of trades). DTN/IQFeed data is very high quality data (but not a broker you can execute through), but measure to see if their latency meets your needs since they will likely ship data to Chicago before coming back to you, which could mean a ~ 200 msec extra latency if you are trying to trade from Europe. You are probably not latency sensitive, but worth mentioning.
[2023-10-24 15:06:57] |
V much appreciated, to both of you. All the best ND |
[2023-11-16 13:27:07] |
Runmar - Posts: 1 |
Hi support. I'm trying to find FTSE100 and DAX ( trading on sim,delayed signal). Is EFPZ23-Euronext correct for FTSE100, get no signal /volume. what should i choose. I see you have in this post LFZ23, but i cant find it Dax is for this : FDAXZ23-EUREX ? i have not connected any brokers or using live data regards RM |
[2023-11-16 19:13:40] |
For DAX, you have the correct symbol - assuming you are connected to "SC Data - All Services". We do not have intraday data for the FTSE100, but if you want end-of-day data, then use the symbol Z?##-LIFFE (for example ZZ23-LIFFE for the December contract). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
