Date/Time: Tue, 26 Nov 2024 20:15:19 +0000
wrong data
View Count: 324
[2023-10-19 10:45:26]
TheFibber - Posts: 83
hi 17th of october there are a lot of wrong data in the intraday bar .are you fixing this problem?
thanks
[2023-10-19 13:22:52]
John - SC Support - Posts: 36307
What is the symbol for which you are having an issue?
Please give us a screenshot showing the errors by following these instructions:
[2023-10-20 06:23:44]
there are countless. in the dj30 the tickers are : Axp Ba cat Cvx dis gs hd jnj jpm Mcd mmm V vz
but in the greater sp500 many more (gm gnrc ir irm itw ivz but i stopped looking fot them..they are too much)
imageivz.JPG / V - Attached On 2023-10-20 06:21:42 UTC - Size: 185.39 KB - 93 views
imagevz.JPG / V - Attached On 2023-10-20 06:22:40 UTC - Size: 176.46 KB - 81 views
imagemcd.JPG / V - Attached On 2023-10-20 06:23:23 UTC - Size: 170.8 KB - 83 views
[2023-10-23 03:01:41]
Sierra_Chart Engineering - Posts: 17182
No. This is data from the exchanges. The data is not actually wrong.
Make sure this is disabled:
Data/Trade Service Settings: Process Known Odd Lot Equity Trades for DTC Services (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings)
And adjust session times to 09:30:00 (start) to 15:59:59 (end) Eastern time:
Chart Session Times: Session Times
Make sure the chart is set to use the New York time zone.
We cannot provide further help.
Date Time Of Last Edit: 2023-10-25 17:26:21
